AllHailJ
(J Gent)
March 7, 2022, 8:49pm
1
I upgraded from 3.1 to 3.2 this morning.
I hit Ctrl F5 while I was upgrading and when it was done upgrading I didn’t have any of my Z-wave devices available. There were present but not available.
I tried the following things in this order
reboot - no go
re-interviewing a node - no go
reboot - no go
restore back to 3.1 - no go
reseat my z-wave dongle - no go
restart z-wave add-on - no go
re-install 3.2 and just be patient - success
I am not certain if any of the order mattered, if Ctrl F5 caused the hiccup or if it was just reinstalling 3.2 and being patient.
I am on Ubuntu running HAOS on VirtualBox. I also ran updates this morning and one of the updates was VirtualBox.
Hope this helps someone.
Did you install build .32 of VB? I tried several weeks ago and had major issues, and I’m seeing a few others also running into problems.
Hello
I run HA on VirtualBox.
I updated VB to the latest version and now i can’t get HA to work…
I get those errors :
[IMG_5983]
[IMG_5984]
Any ideas ?
opened 10:29AM - 04 Mar 22 UTC
closed 12:02PM - 12 Aug 23 UTC
bug
board/ova
stale
### Describe the issue you are experiencing
I update to 7.4 and as had been the… case lately, updates to new home assistant os versions crashes the virtualbox emulator.
I decided to update from 30 to 32 and was unable to boot at all.
I did a clean install of 7.4 and the issue remained.
Downgrading virtualbox to .30 fixed the issue
Here's a photo of the issue
![IMG_20220304_112244](https://user-images.githubusercontent.com/15817790/156745939-5387a6e3-a451-4c1c-9cbc-e4897f9cc593.jpg)
Now the system does keep booting.
CPU usage on host is very high and the boot takes a very long time.
Eventually giving this error
waiting for the home assistant cli to be ready
Followed by
Cannot connect to the docker daemon at Unix:///var/run/docker.sock. is the docker deamon running?
### What operating system image do you use?
ova (for Virtual Machines)
### What version of Home Assistant Operating System is installed?
7.4
### Did you upgrade the Operating System.
No
### Steps to reproduce the issue
1. Install virtualbox 6.1.32
2. Try booting an existing or new home assistant os. I tried 7.4, 7.3 and 6.x
3. Booting will fail
4.
### Anything in the Supervisor logs that might be useful for us?
```txt
Can't get logs if you can't get to cli
### Anything in the Host logs that might be useful for us?
```txt
N/a
### System Health information
N/a
### Additional information
I tried older versions to rule out the grub change being the cause
another maybe?
What version of VirtualBox?
AllHailJ
(J Gent)
March 8, 2022, 12:34am
3
Yes
6.1.32-dfsg-1~ubuntu.20.04.1 amd64
security
6.1.16-dfsg…
After the reinstall HA is running perfectly.
