Lot of warning and errors from TPLink smart plug and Philips hue
I am new here, and new with hassio, which I set up on my raspberry pi 3B+ about a month ago.
I always have error and warning in the dev-info part of hassio which makes me think that there is a problem with my configuration, but I am completely unable to debug it. Hopefully someone here will be able to help. My hassio version is 0.86.2 but same problem with the previous update.
Here are the errors/warnings :
Update for sensor.netatmo_bedroom_humidity fails
06:17 components/sensor/netatmo.py (ERROR)
Update of sensor.netatmo_bedroom_humidity is taking over 10 seconds
06:17 util/async_.py (WARNING)
Could not read state for printer_switch: Communication error
06:16 components/switch/tplink.py (WARNING)
Unable to reach bridge 192.168.1.xx ()
06:15 components/hue/light.py (ERROR)
First, they seem to occur at the same time. I didn’t paste each errors here but every tplink smart plugs (HS105) trigger the same error, as well as each sensor of my netatmo weather station (humidity, co2, temperature, etc.)
These errors occurs a lot, more than 40 times in the last 12 hours.
When I check the Log, I can see that the state of every philips hues (+ ikea tradfri) and smart plugs (and even my sonos one) first “changed to unavailable” and then to “turned off”
Hopefully it will help you to see what can be the problem.
Thanks!
Any chance someone could help to troubleshooting this one ?
Since my initial post, I tried to tried to change my router’s wifi 2.4 channel from auto to 6 (hue’s zigbee channel is 11), tried to setup again the hue component, even tried to replace the pi power supply, and yesterday I set static ip for every device on my local network.
I started to try it worked because I didn’t get any error/warnings during the whole day (before that, I got a lot through the day) but it started again around 1am until ~ 9am today - and nothing since then…
It sounds like something is related to these warning/errors, but how to troubleshooting it ?? I don’t have any clue…
I have about 15 TP-Link plugs, the two at the furthest part of my flat do this periodically. Looking at my Unifi Controller I can see the devices are disconnecting and reconnecting. I think your experience is likely to be down to wifi/interference rather than anything in HA.
Actually, I just noticed that I lose samba connection at the same time too…
But again, just don’t know how to troubleshoot this…
I started thinking that it could be caused by the TPLink powerline adapter which the RPI ethernet was connected to, so I tried to connect it directly to my switch behind my router. It’s been two days now and I haven’t got any errors/warnings…
Guess it solved now…
