Have/had a fine running homeassistant. After sucessfully implemented a handfull of lights via MQTT I tried to implement some automation, before ha core check runs without any errors. My version is 2021.1.4 After adding some lines in automations.yaml I did a check again and I got lot of errors and the default includes in configuration.yaml had been marked with a “!”. I remove the “!” and removed all my changes in automation. Then I did a check again and things got worst.`root@hass:~# ha core check
Error: Testing configuration at /config
ERROR:homeassistant.helpers.check_config:Unexpected error validating config
File “/usr/src/homeassistant/homeassistant/helpers/check_config.py”, line 145, in async_check_ha_config_file
await config_validator.async_validate_config( # type: ignore
File “/usr/src/homeassistant/homeassistant/components/script/config.py”, line 44, in async_validate_config
for object_id, cfg in config[DOMAIN].items():
AttributeError: ‘str’ object has no attribute ‘items’
ERROR:homeassistant.config:Invalid config for [automation]: expected dictionary. Got OrderedDict([(‘frontend’, {}), (‘updater’, {‘include_used_components’: False, ‘reporting’: True}), (‘sun’, {}), (‘group’, ‘include groups.yaml’), (‘automation’, ‘include automations.yaml’), (‘script’, ‘include scripts.yaml’), (‘mqtt’, OrderedDict([(‘discovery’, False), (‘broker’, ‘localhost’), (‘port’, 1883)]))]). (See ?, line ?).
ERROR:homeassistant:Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/core.py”, line 1393, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service persistent_notification.create
Failed config
group:
- Invalid config for [group]: expected a dictionary for dictionary value @ data[‘group’]. Got ‘include groups.yaml’. (See ?, line ?).
- automation: include automations.yaml
frontend: ?
group: include groups.yaml
mqtt: [source /config/configuration.yaml:24]
broker: localhost
discovery: False
port: 1883
scene: include scenes.yaml
script: include scripts.yaml
sun: ?
switch: [source /config/configuration.yaml:29]
- platform: mqtt
command_topic: command/Wohnung/Licht/AZ1
name: Arbeitszimmer Licht 1
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/AZ1
- platform: mqtt
command_topic: command/Wohnung/Licht/AZ2
name: Arbeitszimmer Licht 2
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/AZ2
- platform: mqtt
command_topic: command/Wohnung/Licht/Flur1
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/Flur1
- platform: mqtt
command_topic: command/Wohnung/Licht/Flur2
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/Flur2
- platform: mqtt
command_topic: command/Wohnung/Licht/Bad
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/Bad
- platform: mqtt
command_topic: command/Wohnung/Licht/SZ
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/SZ
- platform: mqtt
command_topic: command/Wohnung/Licht/EZ
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/EZ
- platform: mqtt
command_topic: command/Wohnung/Licht/WZ1
payload_off: OFF
payload_on: ON
qos: 1
state_topic: state/Wohnung/Licht/WZ1
updater: ?
weather: [source /config/configuration.yaml:109]
- platform: openweathermap
api_key: 3031e5f6cbdf193692cb50b258aafb46
script:
- Unexpected error calling config validator: ‘str’ object has no attribute ‘items’
- include scripts.yaml
scene:
- Invalid config for [scene]: expected a dictionary @ data[‘states’][0]. Got None. (See ?, line ?).
frontend: ?
broker: localhost
discovery: False
port: 1883
sun: ?
updater: ?
Successful config (partial)
group:
script:
scene:
root@hass:~# ’
A lot off errors I do not understand
All the mqtt thing in configuration. yaml works still fine as I did not restart hass.
I also have nothing changed in configuration.yam than removeing the “!” in the includes
Realy need help!
Rainer
