Hi all,
Last weekend I noticed that some automations did not work anymore. I had a lot of errors but I found out that my SD card was full. This was caused by my “home-assistant_v2.db” file. This was over 4GB’s. So I stopped HA with the “systemctl stop” command, deleted the .db file, and started HA again. After that and some reboots/HA restarts the most stuff started working again. However, I still have some problems. After a restart I get this errors in my log:
Log Details (ERROR)
Mon Feb 04 2019 16:05:46 GMT+0100 (Central European Standard Time)
Error while setting up platform spotify
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/spotify.py", line 85, in setup_platform
token_info = oauth.get_cached_token()
File "/srv/homeassistant/lib/python3.5/site-packages/spotipy/oauth2.py", line 132, in get_cached_token
token_info = json.loads(token_info_string)
File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.5/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
And this one:
Log Details (ERROR)
Mon Feb 04 2019 16:05:52 GMT+0100 (Central European Standard Time)
Error doing job: Task exception was never retrieved
File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/__init__.py", line 256, in async_start
info = await self.hass.async_add_job(load_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/__init__.py", line 254, in load_config
return json.loads(file.read())
And I get this error for 3 of my Zwave devices:
Z-Wave node 7 not ready after 30 seconds, continuing anyway
I tried some things like “Heal network” and “Soft reset” in my Zwave config panel, but no results there.
