Lots of Login attempt failed
I have a bunch of “Login attempt failed” seems to happen every 5 mins or so. Trying to determine where it is coming from. It looks like it is coming from the docker and the IP seems to point to hassio_supervisor.
Any thoughts on where I can look as to why this is happening.
My setup is Home Assistant on a Intel Nuc running in Docker and behind a Nginx Proxy Server.
Have also something similar, after looking for with whois found that the ip is coming from Netherlands, RIPE NCC, I’m not living there. Could it be a service from HA?? Should I ban it??
It is coming from Docker. That is a Docker ip so no need to ban it. Just trying to figure out why it is popping up
Are you running HA Dashboard via AppDaemon 4? I have been getting the same numerous login attempts and have narrowed it down to the wall tablets I have showing the HA Dashboard. The tablets and dashboards work fine, but I am getting tons of these errors in the log. If I shut down my tablets I get no errors, turn them back on and launch the dashboard I start getting them again. My appdaemon.yaml seems correct so I can’t figure out how to stop it from happening.
