Hey how can I run the loveace from scratch ? to update new items added?
You are trying to update the interface in Home Assistant?
When in Overview mode you cal select the UI Editor from the upper right menu. You can either edit there or select the upper right menu gain to get to the raw configuration.
After you edit manually, Lovelace no longer adds new components automatically to the UI.
i understand it … is there a way to run automatically from scratch ?
I assume that new components must be added to configuration files.
where is the lovelace files located? i did some changes but don’t see them on the UL lovelace file in configuration folder
My guess would be somewhere in the hidden .storage
folder in the configuration folder. I think it is hidden do people do not mess with it directly.
so how can backup this files??
