I wanted to split my ui-lovelace.yaml into several files and include the same card multiple times, so I made a tool for it…
Here it is, if you think it might be useful:
This functionality should be in the core @balloob , to be able to define a UI across multiple files.
I was told on the discord channel that there actually is a way to include files built in now, but it will be removed in the future to accomodate for a web-based configuration interface.
So either this tool will become useless because it’s replaced with better core functionality, or it will become more useful for people who - like me - prefer text based configuration.
Exactly. I actually prefer text based configuration over web based, too. This makes sharing and portability much easier.
I’m sure there’s a plan for sharing, portability and version control. We’ll see what the future holds.
In the mean time, there’s this.
There’s been an update to the generator.
You can now include resources, like .js and .css files (for example if you’re using custom cards) using !resource [<path>/]<filename>
This will copy the file into www/lovelace/
and insert the correct path into ui_lovelace.yaml
Edit: I just realized that this could also be used to include images
image: !resource my_photo.png
Brilliant, first thing i thought when i switched to love lace was, man is this conf file going to start getting big !
As @teachingbirds found out, the script can be run in hass.io via shell_command
Instructions for this are in the readme.
It is now possible to use jinja2 templates to generate the lovelace config.
This allows for loops, variables, macros and flow controll.
See usage example on github.
And now you can access the home-assistant state from the templates as well.
Again, see readme for example use case.
This is great I was doing a cpl of ugly work around to get attributes I wanted to display having templating available is huge for me thanks
Just remember that it’s the state at “compile” time. It won’t update dynamically.
This is a great facility. Unfortunately, it is not compatible with the Custom_Updater component and the tracker-card.
Yes it is. There’s a special clause in the updater to handle lovelace-gen
It does not work with the !resource
statement, though.
Thank you, Thomas.
When using a generated ui-lovelace.yaml, my experience is that the Tracker-Card shows properly until either the “Check” or “Update All” button is pressed. After that, the Custom Cards disappear. I have tried replacing the generated resources section with the usual yaml, but I get the same result.
If I understand this correct, this is a way to make different sets of views? Like I describe in this tipic:
In that case, how do I do this manually without the script? And where is the lovelace folder?
No, sorry.
This tool is mainly for dividing the ui-lovelace.yaml
file into more manageable parts. It doesn’t affect the interface.
There’s currently no way to do what you’re asking for, but you can kind of fake it using a combination of the lovelace kiosk script and using imges with navigation_path
set.
You can also name a view " "
(a single space inside quotes)…
I’m trying to make a header file that I will include in the top of all my views. The header has the weather-forecast in it as well as a couple of presence detection entities and some other entity cards relevant to each room. I can edit the ui-lovelace file and make it come out like I want, but I can’t seem to get the header.yaml file correct. Here is what it should look like. My presence tags are wrong, but that’s ok, it’s because of re-configuring owntracks and not part of this problem.
This is the ui-lovelace.yaml file that I modified to make it work.
- cards:
- cards:
- cards:
- entities:
- {entity: device_tracker.turboc1208_cc1208, name: Chip}
- {entity: device_tracker.scox1209_scox1209, name: Susan}
title: Presence
type: entities
- type: weather-forecast
entity: weather.dark_sky
- entities:
- sensor.date
- sensor.time
- {entity: sensor.master_temperature, name: Bedroom Temperature}
- {entity: sensor.master_bath_sensor_temperature, name: Bathroom Temperature}
- {entity: sensor.master_bath_sensor_relative_humidity, name: Bathroom Humidity}
type: entities
type: horizontal-stack
- cards:
- entities: [light.master_fan_level, light.master_light_level, light.master_floor_light_level,
switch.master_cove_outlet_switch]
title: Lights and Fan
type: entities
- cards:
- {entity: media_player.mbr_directv, name: Directv, type: media-control}
- {entity: media_player.mbr_roku, name: Roku, type: media-control}
type: vertical-stack
panel: true
title: Master BR
Here is what my MBR.yaml file looks like
- title: Master BR
panel: true
cards:
# The filter card will filter entities for their state
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- !include header.yaml
- type: entities
entities:
- sensor.date
- sensor.time
- entity: sensor.master_temperature
- entity: sensor.master_bath_sensor_temperature
- entity: sensor.master_bath_sensor_relative_humidity
cards:
- type: entities
entities:
- light.master_fan_level
- light.master_light_level
- light.master_floor_light_level
- switch.master_cove_outlet_switch
cards:
- type: media-control
And here is the header file that is giving me problems.
cards:
type: entities
title: Presence
entities:
- entity: device_tracker.turboc1208_cc1208
- entity: device_tracker.scox1209_scox1209
What am I doing wrong?
Try pasting it in manually and see what happens:
You’ll get:
cards:
cards:
- cards:
type: entities
title: Presence
Doesn’t look quite right now, does it?
it’s the weather I’m having problems with when I run it through the converter.
