Hello guys,
I want to add a url-list (clickable url’s) to lovelace. I tried weblink but the url’s i add are NOT clickable. Could someone give me a hint? (please state in which file i should add/edit…)
Thnx!
ps: i tried this in configuration.yaml
weblink:
entities:
- name: Router
url: http://192.168.0.1/
icon: mdi:router
In lovelace-UI (0.84.6) i added a entities-card (choosing: weblink.router)
ps2: in the editor (Toggle editor, in lovelace UI) is looks like this;
type: entities
title: URL’s
entities:
(strange that the icon (router) is not visable in the UI and not in the code)
try (this tab/view):
title: Weblinks
path: Weblinks
icon: mdi:web
cards:
- type: entities
title: HomeAssistant
show_header_toggle: false
entities:
- type: weblink
name: Home Assistant
url: https://home-assistant.io
icon: mdi:home-assistant
- type: weblink
name: Configuring Home Assistant
url: https://home-assistant.io/getting-started/configuration/
icon: mdi:assistant
- type: weblink
name: Available Components
url: https://home-assistant.io/components/
icon: mdi:briefcase-check
- type: weblink
name: Troubleshooting your configuration
url: https://home-assistant.io/docs/configuration/troubleshooting/
icon: mdi:wrench
- type: weblink
url: https://home-assistant.io/help/
icon: mdi:help
- type: weblink
name: Home Assistant Forum
url: https://community.home-assistant.io
icon: mdi:comment-multiple-outline
if i add it to configuration.yaml i get these errors:
Configuration invalidCHECK CONFIG
Component not found: cards Component not found: path Component not found: title Component not found: icon
my code isn’t for configuration.yaml, it is a Lovelace view…
and, there not mentioning of a card in the code since it uses the native entities card and weblink: https://www.home-assistant.io/lovelace/entities/#weblink
this view looks like this:
Timbo66
(Tim Schroeder)
December 1, 2022, 7:35pm
6
Weblink cards have been deprecated. Suggest use a Markdown card instead:
type: markdown
content: Sample link to [Google Maps](https://maps.google.com)
What is deprecated?
A standard Entities card?
Depricated = no longer used.
I know what “deprecated” may mean)))
My question was about a particular person’s post.
GlennHA
(Glenn)
December 27, 2022, 1:27pm
10
I have used entities card for years for weblinks; so I guess he is referring to a specific card; since weblinks are still supported:
https://www.home-assistant.io/dashboards/entities/
rudolff
January 24, 2023, 3:29am
11
I tried to make a link with markdown type but it did not work, is this for a lovelace card?
Marius’ code works a treat, thanks for that!
DHLF
(Dhlf)
May 14, 2024, 5:48pm
12
Sorry for necromancing, but maybe helpful:
If you are using uBlockOrigin(and blocking WebWorkers) then anything using markdown will NOT be shown. Therefore you must have WebWorkers enabled for homassistant if you are using markdown.
