It works really well together with custom button-card to create an interface similar to Apple Home.
If the device doesnt support 3D tuch, such as a desktop, it will simply work the same as the regular hold_action in Lovelace except adding a blur effect.
See github for instructions, but in short you just add this mod to your ui-lovelace.yaml resources sections and add deep_press: true to any card you want it to apply to.
Notes: It is only really tested on button-card and entity-button
If you have any problems or further ideas, make a github issue.
Also, I am NOT a javascript developer so this can probably be done in a better way but its working really well so far.
The technique to apply changes to existing cards is based off of card-mod
It is working really great and it is actually better than I had expected. This is what I have been looking for for a while now (only thing left to look for is a vertical brightness slider to use with this so it will be more Homekit-esque).
Thanks a lot for sharing this, only thing I have found is that sometimes the blur will stay, another 3d touch press will eliminate the blur, but it is definitely there.
Anyways awesome work, I have this adapted throughout my setup right now and I love it.
Nothing much really, I just press it a few times in a row. Doesn’t seem very prominent, but it does it sometimes after repeatedly trying to 3d touch the button (I don’t think this will happen on normal use, but it might bug out sometimes). It looks like it is hanging on the blur, only way to fix it is either a reload or another 3d touch on a button. It does go away on conditional cards when the condition changes though.
I can’t seem to reproduce it anymore now, I think the update fixed it. Will test it some more, but for now it works great.
Thank you, you made my wife extremely happy as this was the one thing she hated about HA vs Homekit (all other stuff she prefers HA over Homekit a million times, but the long press for brightness pff). So thanks a lot!
New release 1.1.0.b1
This beta version aims to fix issues where a deep press would activate buttons or other interactive items on a popup-card, for example a color-wheel.
Testers appreciated
Thanks a lot for sharing this! Works really nicely in combination with the Button Card and the hold-action!
I’ve ran into an issue though. I also use it in combination with Browser Mod. I actually want to open a popup window showing the Light Entity Card which works fine by itself, but in combination with deep_press: true it doesn’t work. Changing the Light Entity Card to something else (e.g. not a custom card) also results in this error.
This is the basic (relevant) configuration (I’m actually also using the Decluttering Card, but I don’t think that is relevant to the issue, so I removed it from the below configuration):
type: custom:button-card
entity: light.living_room
hold_action:
haptic: heavy
action: call-service
service: browser_mod.command
service_data:
command: popup
title: Living Room
card:
type: custom:light-entity-card
deviceID:
- this
I get the following error when I add deep_press: true to the above configuration:
Uncaught TypeError: Cannot read property 'callService' of null
at ee (deep-press.js:1)
at HTMLDivElement.startDeepPress (deep-press.js:1)
at i.value (deep-press.js:1)
@roflcoopter Is this an issue with your mod or should this be reported in a Browser Mod related issue? Also, if you rather want me to create a Github issue, I could do that as well.
Edit: I am running version 1.1.0.b1 through HACS btw.
Just looked into this a little bit. It indeed doesn’t seem to be a Browser Mod issue.
Removing the Browser Mod functionality and simply using a simple service call (shown below) results in the same TypeError (Uncaught TypeError: Cannot read property 'callService' of null).
The error shown seems to be triggered in the custom-cards-helper package you included. For some reason the hass object here is null. I have no clue why though.
Edit:
Actually… I do know why its null, you’ve set it to nullhere. @roflcoopter Is there any reason as to why you’ve done that?
