Lovelace: Advanced calendar card
No way… i tried also only type2 icon
Is it possible to list the events showed in a better way than this?
Schermata 2020-04-20 alle 11.02.44
I mean maybe in vertical list, one event for line?
Great Card, spent my Sunday afternoon working on it.
I’m using it over a Picture Elements Card.
is it possible to give it a clear background so it can go nicely in my grey box?
Version 1.3.0 now has that feature, much nicer UI Design and a list instead of a confusing line of text.
Hope this helps.
I have just inspected the elements and cant see that a background color is added, i also dont see that in the code.
Could you possibly send a screenshot of the element in html. most likely looks like a theme issue.
Yes, thanks, now the view is better and better.
I have a question for you:
How to set colors for sat and sun days?
I tried this:
            Sat: rgba(2, 250, 52, .05)
            Sun: rgba(2, 250, 52, .15)
But it doesn’t work…
Please see documentation
The options are at the bottom:
CalEventSatColor
CalEventSunColor
Thanks, i read the documentation but did not find anything related… but maybe it’s my fault!
No worries, there are a lot of options :slightly_smiling_face:
I actually solved that same night, installing card-mod and changing the style in CSS
Is there any way to confine the displayed calendar items? I would like to keep them in that box part of the background but it varies every day depending on the upcoming events…
for now I reduced to only displaying 2 days.
anyway the CaleEventSatColor or Sunday, is not working for me …
Hi
I am looking for a way to have available all my events for a day (usually 3-4) from my google calendar in order to send them in my morning report (tts in google home). With google calendar integration I only get the first event of day. Is there a way if I install this card to be able to sent the event to google tts?
All the card does is displays the data that home assistant has available. It has no way to interact with tts.
Hey All,
I’ve recently released v1.5.1, a lot has changed recently so I thought I would list these here.
  • New documentation this is still being built out to include much more information
  • Added to HACS default plugin repo
  • New look calendar mode, UI more appealing.
  • Calendar summary, now clearly identify a full day event or a short event from the calendar summary
  • Set a calendar specific color for quickly identifying which calendar an event is from
  • Calendar view will now highlight the current day and selected day
  • Saturday and Sunday can be set to different colors to easily identify them
  • Added the ability to show calendar names in event mode
  • Various bug fixes
There are some changes that may change options so please check the release notes before upgrading: https://github.com/marksie1988/atomic-calendar-revive/releases
Hopefully this is a great improvement for everyone and any issues please report on GitHub. https://github.com/marksie1988/atomic-calendar-revive/issues
Thank you for continuing to improve the Calendar Card, just updated from the original.
Did the ability to go to a different month go away with 0.110? I see that it goes to google when I click on the current month but sometimes for example I just want to see what day the forth Friday is.
Also is there a way to remove the grid?
thanks
Hey,
No that’s a bug introduced by the icon update in 110 currently logged on GitHub. Hoping to get that fixed soon.
You can click to the left or right where the arrows were and it will change month.
What about removing the grid lines?
I haven’t made that an option but you could set the grid Line color to hide it that way.
Just installed today’s update, thanks for the month handles.
The calendar widget grew by about a vertical inch.
Was this by design?
Anyway to shrink it?
Thanks again
Interesting… That shouldn’t have happened. Could you share a screenshot?
