I just updated to V110 of HA and I’m on the latest version atomic calendar revive.
I’ve got a three issues but I don’t know if (but I don’t think) it’s on my end.
the first is that the calendar events aren’t showing on the correct days. I’ve had my work calendar in google for a couple of years and have always displayed it correctly in the card. Now it’s not correct but I haven’t been able to figure out why.
Here is a screenshot of the calendar card (days icon is green sun, nights icon is red moon):
as you can see the calendar card is 1 week behind the actual calendar - it thinks that the events for last week are supposed to be in the current week.
second, and as you can see from the first screenshot the icons are way bigger now and don’t fit into the day box like they used to.
lastly, and again as you can see in the screenshot, the right & left chevrons for navigating the month aren’t visible. They are there and they work but you just can’r see them.
here is the config for the card:
- type: "custom:atomic-calendar-revive"
name: "My Work Calendar"
defaultMode: 2
firstDayOfWeek: 7
CalEventIcon1Filter: days
CalEventIcon1: mdi:weather-sunny
CalEventIcon1Color: green
CalEventIcon2Filter: nights
CalEventIcon2: mdi:weather-night
CalEventIcon2Color: red
CalEventIcon3Filter: DD
CalEventIcon3: mdi:star
CalEventIcon3Color: orange
entities:
- entity: calendar.my_email_gmail_com
type: icon1,icon2,icon3
Other than the schedule offset, your screenshot looks similar to my original atomic calendar card following 110.0. I just switched to revive and the look is quite different.
only version 1.5.1 upwards resolves the issue that you see with the large icons.
only version 1.5.2 fixes the missing date icons
If you have installed the latest version you may need to clear your browser cache.
Without upgrading to the latest version it makes it hard for me to look at the issue, i haven’t seen any issues with calendars showing the incorrect week, especially not on the latest version of the card which i have in my test platform.
I checked the console and it indeed had the version as 1.2.0.
then I checked for any versions of atomic-calendar still around and in doing that I found I had two folders for atomic-calendar-revive - one from 5/7/20 and one from today. I deleted the old one and restarted.
It’s now all working. Even the days are correct again.
I still have no idea how I was able to have two folders with the same name but with two different sets of files inside. I’ve only ever used hacs to install and update the card.
Maybe it was the switch over from the custom repo to when it got added to the default repo list.
thanks for the help and nudging me in the right direction.
Now I just have to figure out how to get the correct icons with the right colors back again. All three are all shown at the same time in any day that has an event and they are all blue right now.
I’ll work on it and if I get stuck i’ll be back.
Yeah, it definitely looks way different now.
I guess that should have clued me in since there was an announcement in the release notes about a new prettier display. Every time I updated I never saw any difference in the display so I thought it was something I needed to add to get it to change. Apparently not.
I still can’t get the calendar mode to respect the keywords or the icon options.
it still always shows all three of the default icons in the default color (blue) for any day that there is any of the keywords in the event.
see above for the google calendar, the latest atomic calendar card and my code.
I’ve tried different iterations of the config options but I always end up with the same result or no results at all - the card shows but it doesn’t show any events.
Sorry to keep bugging you about this but I just don’t see why the config isn’t taking. It worked fine before the update to 110 & the latest card version.
I have just released v1.8.5 which resolves issues with icon color / progress bar and a couple of other little tweaks.
In your config could you change all of the lines to start lower case Cal..... to cal..... I changed the first letter to lower case and all after that start with a capital because all other options are formatted this way
Once you have updated this i believe that is should work as expected
I looked at those options for an hour trying to figure out what the differences were between the options listed and mine but I never even noticed the change in the first letter to lower case.
It’s now really all working again.
And I didn’t need to update for it to work.
Thanks again for pointing the trees thru the forest.
Do you mean that they are dimmed or that they show with a border around them?
If they are dimmed when they shouldn’t be please check that the correct card version shows in the browser console.
If it does please send me a copy of your config for the card and I will see what’s happening.
