Why not just delete them?
Itâs what I currently do, but having a filter would show only the ones I want automatically.
I get an error:
aftership: Error on device update!
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/app/homeassistant/helpers/entity.py", line 375, in async_device_update
await self.async_update()
File "/usr/src/app/homeassistant/components/aftership/sensor.py", line 190, in async_update
'last_checkpoint': track['checkpoints'][-1]
IndexError: list index out of range
Can you post that to the GitHub, please
I published
I have same issue. I did a configuration of sensor as itâs described into the documentation, but the sensor is missing into HA. So the card is not working
Is there any solution?
The situation in my case become very strange:
As Iâm using docker I made few very simple tests:
- install other container with HA - aftership works without issues
- deleted entire HA container (just keeping the config foder) - and rebuilding container - problem persist.
Now I have no ideas what I can do - may be something is written in some files into /config folder - but I cannot find anythings⌠Any ideas will be highly appreciated.
can you link to the aftership docker?
What do you mean by âAftership Dockerâ?
I have 2 absolutely the same configs of HA - one is porduction installed long time ago and second one -test with just aftership configuration.
In first one Iâm receiving error, second one - works as expected.
Hi, on my instance Aftership worked correctly for a long time. After an update (Iâm not sure which version but +/- 2 updates ago) it fails with the error mentioned above. My present version is 0.94.1. Are you sure that on both your installations you have the same version od Hassio?
First Iâm using ânativeâ ha in docker, not HASSIO. Both were in different versions - production is - latest, test is dev. But in a few minutes Iâll try.
I try to install it for the first time in 93.x and it doesnât work.
In 0.95 problem is fixed. So aftership integration works without issues. Now I have problem with the After ship card - but will try to reinstall it first.
Hi All
I¨m on HA 0.95.1 on HASSIO on a Raspberry Pi.
Iâve been able to add two trackings through the card, and I can see the trackings in the sensor, but after adding a series of packages, the card is not showing up any longer?
Sensor reports â3â
And the content looks like this:
"attribution": "Information provided by AfterShip",
"intransit": 2,
"pending": 1,
"trackings": [
"name": "Sonoff Basic",
"tracking_number": "Hidden",
"slug": "postnl-international",
"link": "https://track.aftership.com/postnl-international/Hidden",
"last_update": "2019-06-29T09:11:08+00:00",
"expected_delivery": null,
"status": "InTransit",
"last_checkpoint": {
"slug": "danmark-post",
"city": "Brøndby",
"created_at": "2019-06-29T09:08:08+00:00",
"location": "Brøndby Pakkecenter - BRC, Brøndby, 2605, Danmark",
"country_name": "Danmark",
"message": "Forsendelsen behandles pĂĽ vores sorteringscenter",
"country_iso3": "DNK",
"tag": "InTransit",
"subtag": "InTransit_003",
"subtag_message": "Arrival scan",
"checkpoint_time": "2019-06-28T11:11:03",
"coordinates": [],
"state": null,
"zip": "2605"
"name": "Hidden",
"last_update": "2019-06-29T09:09:02+00:00",
"city": null,
"created_at": "2019-06-29T09:05:45+00:00",
"location": null,
"country_name": null,
"message": "The item is on transport to the country of destination",
"country_iso3": null,
"tag": "InTransit",
"subtag": "InTransit_007",
"subtag_message": "Departure Scan",
"checkpoint_time": "2019-06-28T14:37:00",
"coordinates": [],
"state": null,
"zip": null
"name": "Havelys",
"last_update": "2019-06-29T09:05:08+00:00",
"status": "Pending",
"last_checkpoint": "Shipment pending"
"unit_of_measurement": "packages",
"friendly_name": "aftership",
"icon": "mdi:package-variant-closed"
So the sensor seems to hold the data, but the card is not being displayed (itâs still there).
Error in the browser console?
Just a thought from another one living in Denmark.
The character âøâ in the response, could be the problem.
HA usually doesnât have a problem with UTF-8 character sets, but yes, itâs always interesting when danish letters appear in the texts.
Similar for me. I added a package that has no update yet. And the whole card was removed.
Content:
attribution: Information provided by AfterShip
pending: 1
trackings: [object Object]
unit_of_measurement: packages
friendly_name: aftership
icon: mdi:package-variant-closed
This is not HA related, itâs JavaScript related. Please log an issue on the repo, not sure when Iâll get around to looking into it. @AlmostSerious same goes for your issue.
