My buttons are displaying weird since 0.88 upgrade, i have lost the icon in the top right corner.
The card is still usable, but it looks not good now
Any idea to solve this? Thanks.
I tried your card, and have 1 question and one issue.
My code is
type: 'custom:alarm_control_panel-card'
entity: alarm_control_panel.house
show_keypad: true
I run Hass.io 0.89.0, browser Chrome 72.0.3626.121 64-bit
I’m hoping to get better buttons than those you can see on the right of my screenshot.
I’m not op. But yes the idea is to look like the original with extra features.
The keypad should show if you’ve defined code = 1234 (or another code) in your configuration.yaml
I know that you’re not the op
Do you mean that I need to define code inside my alarm entity?
If yes, then it’s already there (I’m using this alarm)
And the original one shows the keypad, but this one doesn’t…
Might be a new “feature” in 0.89. I haven’t upgraded yet.
Same here
Too many “nice” features from HA team recently…
How can we find out for sure?
Looks like all having issue on HA 0.89.1. Same for my side.
Comparison between Original 0.89.1 (alarm-panel) and Lovelace 0.89.1:
Hope this can be solved asap.
Just to confirm, you are testing on HA 0.88 or 0.89?
Thanks.
I have upgraded to 0.89.0 and 0.89.1. My version of the card is working without any issues.
Finally it is working now.
Looks like it is due to browser cache issue, cause this weird displays issue.
Anyway, is there any way I can change the label icon to old big icon for keypad like below?
Thanks.
You mean the icon/shield in the top right corner which shows the arm state? The new icon is the same size except the circular border is larger to accommodate the state text.
Sorry for wrong explanation that caused confusion.
I am referring to following keypad style (Right hand side).
Thanks.
That makes sense. It was caused by a breaking change in 0.88. I’m unsure how to fix it but the official alarm card changed too.
Note for Lovelace custom card developers: if you relied on the availability of
<paper-button>
in your code, you will have to update it to<mwc-button>
to get a similar component.
Thanks for the info.
I am not aware of this official changes.
Quick fix:
Open the .js file and replace all “paper-button” for “mwc-button” then you will be good to go.
Don’t forget to increase the version number in your dependency declaration.
