I am wondering is there a way that if a sensor is open it will not allow the alarm to be activated? I have tried creating an automation but cant figure it out. Thanks!
+1
I have the same question! As far as i know is hardcoded into Hassio Core, i want to know how to access hassio core files to edit that, but i found nothing yet. I will tell you if i find anything
If you are using this custom one, you may be able to modify alarm_control_panel-card.js in your local directory. Check out the last entries in the file.
Oh yes i know, but i have this issue using this card : Cannot add property scale, object is not extensible
A guy answer Hollapm which seem to have the same issue, but i couldnt find a way to fix it.
Any tutorial on how to fix it will be aprecciated!
That file is the custom card, you need to install that card and then modify it (or modify it and the install it), there is a explanation on how to do it here: Lovelace: Alarm card
must say I am confused to the use of the bypass, would have thought it is to bypass the alarm, in which case it should be armed_bypass_alarm? what is the difference now between arm_xx and arm_bypass_alarm.
Nono, you have the default alarm panel, and this custom alarm panel type: custom:alarm_control_panel-card, they are different! The custom one cand be edited with a lot more option than the default.
Guys Whole point of Alarm Panel is to have security, but when installed in lovelace and armed it does not prevent access to the HA, or at least I couldnât configure it so.
Is it possible to get that panel to blure everything else till correct pin entered? like modal window in htmlâŚ
Developer Tools, Supervisor and Configuration are not lovelace views they are system views. To hide them you need something like kiosk beowser or similar.
I need solution to blur/disable everything for everyone including admin and on every machine where HA is tried to be accessed if correct password is not entered in Alarm Security Panel - that is itâs purpose not just hide other cards in lovelace using condition. Can that feature be added into this cart? I mean I guess this would have more sense, sorry, maybe you are not able to help. Thanks for you suggestions dude.
