In the quest for a perfect Alarm Clock, I’m getting closer, thanks to home assistant.
This card was designed for a tablet which I use on my nightstand with a resolution of 1280px on 800px.
The idea is to have a really minimalistic, readable clock with some Home Assistant love.
Screenshots love…
Note:
- This card is still in beta and it scratches my own itch. No support/guarantees/… It may eat your dog or the alarm may not go off and you can thus miss a date with the love of your live, …
- I tried to solve the alarm in the backend using timers, … but did not succeed due to some outstanding bugs. So, this means that the logic to fire the alarm is in the frontend. If you close your browser, it will not go off. But, since it was designed for an always on tablet (for me a Nexus 7 2013 which is always running and has this constantly open), it appears to work
Features
User interface
The card exists out of two parts:
- the clock part (65% of the height of the screen) with:
- the clock of course
- the options to setup alarms
- the option to override/update the next alarm
- a nap timer option
- the lower part (35% of the height of the screen) which:
- can show up to 3 other home-assistant cards
- shows the snooze and dismiss button when the alarm is ringing
a non-disturb mode is activated when clocking on the clock, which then makes the clock 100% of the screen
Alarm - and PreAlarm options
- You can define multiple entities that will turn on when the alarm goes off, including lights, input_booleans, scripts and media_players. Configuration is as follows:
alarm_entities:
- entity_id: input_boolean.alarm_clock
- entity_id: media_player.gpm_desktop_player
- You can also specify pre-alarm options, think off having your Philips Hue light slowly starting an half hour before the alarm. Configuration is as follows:
scripts:
- entity: script.start_lights_bedroom_slowly
when: '-00:30'
- entity: light.bathroom
when: on_dismiss
service: light.turn_on # not necessary as default is homeassistant.turn_on
Holiday integration
But wait, that’s not all! It also integrates with:
- a holiday calendar so that when you have a holiday the next day, your alarm will automatically disable.
- the workday sensor so that when you have a holiday the next day, your alarm will automatically disable.
Updates
- 2018-09-07: more features…
- 2018-09-05: first beta release
Installation instructions
can be found on https://github.com/rdehuyss/homeassistant-lovelace-alarm-clock-card
Note:
In my example, the configuration also uses Simple Weather Card
