I’m keen to reuse the same chunk of dashboard code in several dashboards/views. I’ve read some old posts which talk about !include, which seemed like a perfect solution. However I understand that in recent times dashboard code has moved away from static YAML files, so !include no longer works. I’ve seen that you can change the configuration of HA so that you can continue using YAML for dashboards, but I’m concerned that if I did that I would be moving away from the standard way of working and so would miss out on functionality in future. Or is switching the UI into YAML mode a reasonable safe/future-proof way of doing things?
Alternatively, is there a new way of reusing code/elements/views within different dashboards?
Thanks for helping me work this out!
