no maybe should I remove default url?
After you corrected the entity_id?
Exactly, I hadnāt been paying attention, thank you so much for your help.
last question, can we make the background change automatically every 3 hours for example?
Yes, if you make a template sensor that changes every 3 hours based on a time sensor.
All right, how do we do that? And how do we integrate it into custom-header?
Both of those questions are really beyond the scope of Animated Background. I suggest asking for help in the HA discord or starting a new thread in the forum
All right, thanks for your help.
Were you running into issues with it the way that it was? I donāt understand why that would be necessary
Hello
Iām using animated background with weather control⦠all okā¦great jobs
I have a request:
I would exclude animated background based on the value of an input or variable
How can I do?
I would turn on and off animated background from lovelace
thanks you
It is already possible to control the background based on an entity state change. If you wish to disable based on an input boolean then I suggest making a template sensor that reports the weather state only if the input boolean is on, otherwise report off. Something like
{{ states('weather.home') if states('input_boolean.background') == 'on' else 'off' }}
then you would just add 'off': none to your Animated Background config.
Hey guys!
Just wanted to share a cool little config I did, cycling through different videos every 3 minutes.
I used the section on the github about āCombination of entities.ā
Since there are multiple videos for each weather state, I figured why not change it up every 3 minutes kind of like a digital photo frame!
All it really takes is an input_boolean helper and an automation that runs every 3 minutes (using trigger > time pattern > minutes ā/3ā) to trigger the boolean switch. Now Im on the search for even more nature weather videos I can cut and loop for this!
Thanks for all your hard work in creating/maintaining this feature!
Hi All! Desperately trying to get this to work. Getting the following error in my log:
āhttp://192.168.1.50:8123/hacsfiles/lovelace-animated-background/animated-background.js:531:21 Uncaught TypeError: Cannot read property ābackgroundā of nullā
Running the latest version, and Iām using a theme from HACS. Would love any thoughts since Iāve tried uninstalling, and reinstalling several times but have been unable to make it work.
It looks like your configuration for Animated Background is incomplete. Post what you have
Hi Villhellm,
I followed, the repo instructions, so hereās what I did:
Installed Animated Backgrounds from HACS. When the installation was complete, I validated that the resource had been added by going to āConfigureā --> āLovelace Dashboardsā --> āResourcesā here it is:
Added the following to my Lovelace Raw by going to āOverviewā --> āConfigure UIā --> āRaw Configuration Editorā:
animated_background:
default_url: 'https://cdn.flixel.com/flixel/ypy8bw9fgw1zv2b4htp2.hd.mp4'
entity: weather.upstairs
state_url:
clear-night: 'https://cdn.flixel.com/flixel/v26zyfd6yf0r33s46vpe.hd.mp4'
#etc since I can't post more than 2 links as a new user
custom_header:
chevrons: false
compact_mode: true
editor_warnings: false
voice_hide: true
title: Clan HQ
The earlier error seems to have been replaced by the following:
Log Details (ERROR)
Logger: frontend.js.latest.202007160
Source: components/system_log/init.py:209
First occurred: 9:46:44 AM (39 occurrences)
Last logged: 9:57:40 AM
- */hacsfiles/custom-header/custom-header.js:1:13663 Uncaught TypeError: Cannot read property āquerySelectorā of null
- */lovelace/downstairs:0:0 Uncaught
- */hacsfiles/lovelace-animated-background/animated-background.js:501:19 Uncaught NoModificationAllowedError: Failed to execute āinsertAdjacentHTMLā on āElementā: The element has no parent.
Thank you again for your help!
Oh whoops, there has been a beta release that fixed that error out for a while. Something to do with non-compliant browsers handling shadow doms incorrectly.
I just pushed a full release with the fix. All you have to do is update.
I applied the update, and rebooted. Now getting a different error message:
Log Details (ERROR)
First occurred: 11:38:38 AM (73 occurrences)
Last logged: 11:44:01 AM
Thatās the same error message. It looks like v0.6.2 was released from the wrong branch. v0.6.3 has the fix
