Lovelace Badge Not Disappearing After Turning Off Philips Hue Lights
Description: Hello Home Assistant community,
I’m encountering an issue with my Lovelace setup, specifically related to a custom card and automation. I’m using Home Assistant to control Philips Hue lights and have created a Lovelace card with a badge that indicates the brightness level of a Philips Hue light entity. The badge color and icon are intended to change dynamically based on the brightness level. However, I’ve noticed that the badge doesn’t disappear immediately after turning off the Philips Hue light, even though the brightness level should be 0.
Lovelace Card Code: Here’s the code snippet for the Lovelace card, including the badge_color
and badge_icon
properties. I’m using the custom mushroom-template-card
for this configuration:
primary: 25%
secondary: Eethoek
icon: mdi:ceiling-light
icon_color: orange
tap_action:
action: toggle
entity: input_boolean.lampen_dimmen_25
layout: vertical
badge_color: >-
{{ 'green' if (state_attr('light.tafel_eethoek', 'brightness') / 255 * 100) | round(0) == 25 else 'transparent' }}
badge_icon: >-
{{ 'mdi:check' if (state_attr('light.tafel_eethoek', 'brightness') / 255 * 100) | round(0) == 25 else 'null' }}
hold_action:
action: none
double_tap_action:
action: none
Automation Code: I have also set up an automation to update the binary sensor state based on the Philips Hue light’s brightness level:
- id: "1"
alias: Toggle Philips Hue light
description: ""
- platform: state
entity_id: input_boolean.lampen_dimmen_25
condition: []
- service: light.toggle
entity_id: light.tafel_eethoek
brightness_pct: 25
mode: single
Troubleshooting Steps Taken:
- Checked entity states and attributes for
light.tafel_eethoek
. - Verified the status of
binary_sensor.light_tafel_eethoek_on_25
. - Confirmed Lovelace card configuration.
- Tried refreshing Lovelace UI after turning off the light.
- Ensured compatibility of custom
. - Reviewed automation configuration for the binary sensor.
Despite these efforts, the Lovelace badge still does not disappear immediately after turning off the Philips Hue light. The badge remains visible until I manually refresh the page.
I would greatly appreciate any insights or suggestions from the community on how to troubleshoot and resolve this issue. Your expertise and guidance would be invaluable in helping me address this problem.
Versions
- Home Assistant v2023.8.1
- Supervisor v2023.08.1
- Operating System v10.4
- Frontend v20230802.0 - latest
- Mushroom v3.0.5
Thank you in advance for your assistance!!
