Lovelace: Banner card
Can anyone help me with how to center text for an entity.
The bottom right section does not center for some reason. It does not matter where i place it. Thanks
I’ve noticed that issue when the text is too big for that section. For me, the solution was to find a way to shorten the text in the affected section, or to expand the section.
Looks like this may be a bug - I opened an issue for it here: https://github.com/nervetattoo/banner-card/issues/83
when cards have sensor values, it seems the sizing changes a bit. notice the height difference between “Küche” and “Schlafzimmer”, where “Schlafzimmer” has a sensor value and “Küche” does not.
I tried to reduce the font size for the entity value, but this did not resolve the issue:
Is it possible to implement light popup card (https://github.com/DBuit/light-popup-card) into a banner card by using hold_action? I tried it but with no success. I would be thankful if somebody could help and give me a hint or an example. Thanks a lot!
Is there a way of restricting an entities pop-up box?
Been meaning to look at this card for a while.
Awesome work!
Wife loves it.
Is there a way to make a light an icon instead of a toggle like with a sensor?
I searched for a long time, the answer for those who are still searching
             map_state:
                  'on':
                    color: yellow
                    value: mdi:run
                  'off':
                    color: lightblue
                    value: mdi:human-male
Did you ever figure out a solution to this?
No, unfortunately
Since the update to 0.117.0 I am getting an exclamation mark over the every picture
banner
Same issue here.
OK thanks. Will open an issue with the code owner but not sure how active they are at this time.
Raised Issue
Is it possible to change the text color if the value/output hit’s a kind of threshold?
Example, I use CO2 sensor data in my card, but I want to change the text color if my values is =>1500 to yellow, and =>2500 to red.
Is this possible?
Thx,
 Jurgen
How do we change the image in front of the name of the banner (bathroom). see put a photo in the background
the only images I know of are the emoji. The banner card can display any of the images listed on the Unicode Emoji List.
the frying pan and the noodles are Emoji!
i did find this example in the documentation on the Git repo…
heading: "\U0001F373 Kitchen  \U0001F35C"
background: url("/local/header_images/kitchen-header2.png")
type: 'custom:banner-card'
is this what you are looking for?
I added a picture from breakfast as a texture background…
thank’s for reply
Hi Guys,
I love this card. Right now iḿ trying to setup a card with multiple media players, but I only want to show them when they are playing. Unfortunately I cannot seem to get this to work. Either one is showing all the time or none is showing at all. Does anyone have an example yaml i could use?
Thanks!
Never mind! I figured it out :slight_smile:
If anyone wants to know, this was how I did it:
heading: "\U0001F6CB Woonkamer"
link: /lovelace/test
entities:
  - light.dimmable_light_2
  - light.dimmable_light_12
  - sensor.temperature
  - entity: media_player.tv
    when: playing
  - entity: media_player.hub
    when: playing
  - entity: media_player.surround
    when: playing
I think it has to do with the value for the state:
Your fan state is “OFF” with all capitals, but the state of your Gym TV is “off” with all small caps…
I’m a newbie so i can’t give you a solution but it’s just what caught my eye…
