I don’t quite see what you mean by overlap from this screenshot with just a fragment of the rendered card. Could you share a screenshot with more data; Possibly redact it with black boxes if there’s anything you don’t want to show like entity names or values Or describe it a bit better
Do I understand you correctly in that you want the entity name to be right/left aligned not centered? If so no that is not something you can do.
When I use rounded corners the bottom corner gets like this:
All other cards looks like this:
In my view it’s the same thing
I think you can use card-modder with overflow: hidden
as part of the config. There was a discussion on the same issue in the button-card thread and using that config in the styles:
section was the apparent fix. I haven’t tried it myself however.
EDIT: Mistake corrected. I shouldn’t post when I’m tired. Thanks for pointing out my error @nervetattoo
Yes, you will have to set overflow: hidden
(not overlap) yourself
Hi, how do I change the heading icon?is there a list of the codes for every icon?
t
great thank you
great card. I like to show icons instead of text for my motion sensor (binary_sensor).
So I put
- entity: binary_sensor.motion
map_state: {on: mdi:run, off: mdi:walk}
to the banner card but it throws an error
while scanning a plain scalar in "/config/ui-lovelace.yaml", line 1087, column 23 found unexpected ':' in "/config/ui-lovelace.yaml", line 1087, column 26
Even if I copy your code @ github I got this error.
Hope somebody could help me
Looks awesome, might find a place for this in the future. Great work!
Sorry about that; I had added invalid example code in the docs.
You can write it almost as my example, just add quotation marks around the keys and values inside the object: {"off": "mdi:icon", ...}
, but the only reason I wrote it as that in the docs was that line breaks in a table cell in a Github markdown file doesn’t work well … I’m digressing
Use the regular syntax you are used to for key<->value pairs like so:
map_state:
"on": mdi:run
"off": mdi:walk
I will improve the docs to instead have some full examples when I find time
Thanks. This works perfect.
This looks great!
Can the entity option be excluded?
It would be helpful to use this as a redirect button.
Turns out that “feature” were actually broken in the last release. It is fixed in the steaming fresh 0.5.0 release that I just cut
I just released a 0.5.0 with several nice to have features like:
- Filter entity with a
when
rule - Display images
- Simple buttons to trigger a service call
- A few bug fixes
Full release notes:
just a few questions.
I assume this is not correct to just show the banner.
- type: horizontal-stack
cards:- type: custom:banner-card
background: “#00B9FF”
heading: Home
link: /lovelace/0
Any chance anybody could show a example of how this would work?
also how do i use icons in the config.
Im going to get full use out of this card! Thanks for making it!!!
That is correct for just showing a linkable heading.
For icons someone wrote about how they did it earlier in this thread. I want to make it easier to find emoji codes and construct heading strings, but its hard to carve out time for
For overall usage refer to the docs. If something in the docs is unclear, let me know here or preferably as a Github issue (easier to track).
