There is an issue on git opened related to your problem and a PR ready to fix the issue.
a fix has been released, install via hacs (it took me twice, one initial upgrade and then a âreinstallâ through HACS for it to work).
Well, yes, it is achievable in a ânot guaranteed-to-work in future versionsâ way
Basically do something like this:
- entity: weather.today
image: true
attribute: optionally_the_svg_path_from_an_attribute
The magic comes from image: true
which will force the value to be rendered in a <state-badge>
. You can configure this entity/attribute look-up inside a map_state
as well. Heck, you can even do value: /working-url.svg
to manually set the icon. Just make sure its accessible over http(s).
Now, the image in state-badges arenât huge either but they are of a bit bigger size than the icons.
No, it is directly linked to the actual state of the entity. Changing it would be a breaking change and makes the name map_state
into a bit of a misnomer. Iâll think about its implications and how it could be supported
But I see no reason why it shouldnât also respect the attribute config. Should
That sounds great! Will try as soon as I have the time. Thanks!
I have buttons still missing. Tried reinstall, uninstall, install⌠all with restarts between.
On 99.3 until IOS 2.0 is fixed⌠thinking that could by why buttons are not working???
Well yes. Without checking I donât think you can use the latest release of banner-card without HA 0.100. They added a new switch button component and removed the old one which is why I had to change it. Try grabbing the previous version and see if that doesnât do the trick for you
No dice. I installed 0.8.1 and buttons still missing.
cards:
- entities:
- entity: switch.garage_light
- entity: cover.megs_garage_door
name: Megs Garage Door
- entity: cover.pauls_garage_door
name: Pauls Garage Door
- entity: switch.driveway_spot
- entity: binary_sensor.garage_motion
map_state:
'off':
value: Clear
'on':
value: Tripped
- entity: sensor.garage_temperature
heading: "\U0001F698 Garage"
link: /lovelace/2
row_size: 3
type: 'custom:banner-card'
I can just wait for IOS 2 to be update to .100; no big deal
Thanks for posting this config, I was battling with this for a while before getting it to work by copying what you have done! Thanks!
I did an update to 100.2 and the latest banner card, that resolved all the issues for me
No one? Really need some advice. This is an awesome card!
I can tsee banne card in my home assistant add ons store to install, do i need to add in another repository to add this in ?
thanks
Is there a way to use When: with another device status ?
I am using TV with embedded Roku, The On/Off can be done via the Remote entity
while getting the status if TV is on or off can be done from the Media_Player entity
I would like to achieve something like that:
- entity: media_player.noam_s_room
when:
state: sensor.noam_tv
(sensor.noam_tv is a sensor i created:
noam_tv:
value_template: '{% if state("media_player.noam_s_room") == "off" %}off{% else %}on{% endif %}'
Is it possible?
The Banner Card is in the Community HACS store.
Install HACS add-on, then youâll get the community icon in your sidebar.
Very nice layout and function on this banner-card. Only thing Iâm missing is the option to change the icon from emoji to an mdi.
Reason: mdiâs are shown the same way regardless of what OS or browser you use.
Is that possible?
Keep up the nice work
Thanks Andrew, i wasnt aware of this addon
Why cant I add a swith entity???
- background: "#EDE7B0"
entities:
- entity: switch.lyxlage
- entity: sensor.bt6_hw_load
- entity: sensor.alarm
heading: false
link: /lovelace/bathroom
row_size: 3
style: |
ha-card {
border: solid 1px var(--primary-color);
background: {% if is_state('sensor.alarm', '1') %} red {% endif %};
box-shadow: none;
overflow: hidden;
I would also like to remove the background color for a transparency effect. Possible?
Nobody!? I cant understand why my switches is unavailable in banner card?
Also trying to have a Timer entityto show, but that dont either work as expected!! Why!?
background: transparent
should work but Iâm not sure how it would look
