Lovelace: Bar Card
Yeah the clearing of your cache is probably what did it. It’s a common mistake, but as far as I know if you’re using HACS to update your cards you shouldn’t have issues with clearing cache anymore.
Yeah I’m using Hacs and I got to looking and only 2 of my bar cards where giving me issues. So I don’t know. Please keep up the awesome work.
Because of your bar car I have this setup. Yes percent shows me how much is used but the visual with the bar card is awesome.
My issue is caused by the browser caching.
I knew I had installed the 1.7.1 version but it kept using the previous one. A clear out has appeared to fix it.
Thanks!
Clearing the cache didn’t work for me but uninstalling and reinstalling via HACS did the trick (even though according to HACS I was already running version 1.7.1).
Card reinstall and clear browser cahce, fixed the problem, thanks!
Hi, just updated to latest Homeassistant 0.106 and it broke all my bar card lovelace cards:
I got error: Cannot assign to read only property ‘min’ of object ‘#< Object>’
the card itself:
entities:
  - cards:
      - align: split
        animation: auto
        attribute: false
        background_style: false
        card_style:
          border-radius: 5px
          box-shadow: 0px 0px
        charge_entity: false
        color: 'var(--custom-bar-card-color, var(--primary-color))'
        decimal: false
        delay: 5000
        direction: right
        entities:
          - entity: sensor.zigbee2mqtt_linkquality
          - entity: sensor.ikea_switch_wall_lights_linkquality
        height: 15px
        icon: false
        icon_position: 'off'
        icon_style: false
        indicator: auto
        limit_value: false
        max: 150
        min: 0
        minmax_style: false
        padding: 4px
        rounding: 3px
        saturation: 50%
        severity:
          - color: '#ec515f'
            value: 20
          - color: var(--primary-color)
            value: 150
        show_icon: false
        show_minmax: false
        show_value: true
        speed: 1000
        tap_action: info
        target: false
        title: false
        title_position: inside
        title_style: false
        type: 'custom:bar-card'
        unit_of_measurement: false
        value_style: false
        visibility: false
        width: 100%
    type: 'custom:hui-horizontal-stack-card'
show_header_toggle: false
style: |
  ha-card {
    border-radius: 20px
  .card-header {
    font-size: 18px;
    padding: 5px 25px;
    font-weight: bold;
title: ZigBee devices link quality
type: entities
Not aware how to troubleshoot this, maybe someone had some similar issue?
GOT IT WORKING, UNINSTALLED AND REINSTALLED TWICE, THEN DOWNGRADED TO 1.7.0 THEN UPGRADED TO 1.7.1 AND IT WORKED
I’m also getting an error:
Attempted to assign to readonly property
Here’s my config, its just the relevant part since it’s inside a much larger vertical card.
      - cards:
          - align: center
            animation: auto
            attribute: false
            card_style: false
            color: green
            decimal: false
            delay: 5000
            direction: up
            entities:
              - entity: sensor.smappee_solar_today
            height: 120px
            icon: false
            icon_style: false
            indicator: auto-vertical
            limit_value: false
            max: 150
            min: 0
            minmax_style: false
            padding: 4px
            rounding: 3px
            saturation: 50%
            severity: false
            show_minmax: false
            show_value: true
            speed: 1000
            tap_action: info
            target: false
            title: Solar
            title_position: bottom
            title_style: false
            value_style: false
            visibility: false
            width: 100px
          - align: center
            animation: auto
            attribute: false
            card_style: false
            color: red
            decimal: false
            delay: 5000
            direction: up
            entities:
              - entity: sensor.smappee_power_today
            height: 120px
            icon: false
            icon_style: false
            limit_value: false
            max: 150
            min: 0
            minmax_style: false
            padding: 4px
            rounding: 3px
            saturation: 50%
            severity: false
            show_minmax: false
            show_value: true
            speed: 1000
            tap_action: info
            target: false
            title: Power
            title_style: false
            value_style: false
            visibility: false
            width: 100px
          - align: center
            animation: auto
            attribute: false
            card_style: false
            color: blue
            decimal: false
            delay: 5000
            direction: up
            entities:
              - entity: sensor.smappee_always_on_today
            height: 120px
            icon: false
            icon_style: false
            limit_value: false
            max: 2.3
            min: 0
            minmax_style: false
            padding: 4px
            rounding: 3px
            saturation: 50%
            severity: false
            show_minmax: false
            show_value: true
            speed: 1000
            tap_action: info
            target: false
            title: Always On
            title_style: false
            value_style: false
            visibility: false
            width: 100px
        title: Energy
I’ve uninstalled and reinstalled the Bar Card plugin, cleared browser cache and updated my instance to 0.106.4, didn’t work.
I also just tried it in a different browser, got the:
Cannot assign to read only property ‘min’ of object ‘#< Object>'
Any clues?
I copied the file from:
https://raw.githubusercontent.com/custom-cards/bar-card/4adbf529513ef90fe5775c5a109b6c4c27de5668/bar-card.js
And renamed moved to www/custom-ui. No need to reload HA, just reloading the page should get that sorted.
Try it out.
I upgraded to 0.106.5 and now i get this error with the bar-card:
How to fix it?
Update the card to 1.7.1 and clear your browser cache.
i have a same problem after the update to 106.5
what can i do with it ?
i tried to update the bar-card.js but it’s still same.
thnx.
This is how to fix it if you’ve updated the card.
I’m having the same issue. Updated the card (which had file type ts not js). I changed to js and still not working.
I’d recommend using HACS to download custom cards, but if you want to use the latest version without HACS you’ll have to download it from the release page. https://github.com/custom-cards/bar-card/releases/tag/1.7.1
Big update 2.0.0 :tada:. Not many new features and even some breaking changes :sob:.
This update unifies some of the card style to work better with the default lovelace layout.
Updates
  • Converted to TypeScript.
  • Code cleanup.
  • Updated undefined entity warning to ha-warning element.
Fixes
  • Added deepcopy function.
  • Moved individual cards into a single ha-card element.
  • Removed default card padding.
  • Set default border-radius to use theme variable.
Breaking Changes
  • severity array no longer requires definition of first color.
The severity array was always a bit confusing since you had to define the start color with a value that didn’t do anything. It will now fall back to the color config value whenever it is above the highest value.
The order of your array entries now also does not matter anymore as they are automatically sorted by value.
color: Green
severity:
  - value: 50
    color: Yellow
  - value: 25
    color: Red
  • Removed *_style config options.
Styles config options have been removed in favor of card-mod, which allows restyling of many more elements than this card should support.
style: |
  bar-card-value {
    font-size: 20px;
    color: Red;
  • Removed padding config option.
  • Removed rounding config option.
Trying to set the styles back with the new update here…
Could not define the rounding option with card mod in any way.
What am I missing here?
I’m using HA Core 107.7 but I’ve this error
I installed bar-card v2.0 via HACS as all the other custom cards I use.
What is it missing?
Are you sure the resource is included in your lovelace?
I don’t think you’re missing something, currently it’s only possible to override the CSS using the element ID. However that’s not really too great, I’ll have to fix that in my code so you can override the CSS using the element name instead of the ID.
Currently the default border radius is based on the card border radius set in your theme ha-card-border-radius. I’ve also added a custom theme variable to 2.0.1 bar-card-border-radius which you can set in your theme (if you have one) to override the border radius specifically for the bar card.
Theme YAML example:
  bar-card-border-radius: '8px'
Thanks for your answer, I understand the changes.
What happens when I have several entities under one card, using 2 columns? Until now the padding setting would set a space around each element. Currently I am able to set padding using card mod, however this sets space above and below each bar, but not between them. Also there is some extra margin appeared in the bottom of them both, I can see in dev tools.
Can you please advise on that?
YAML:
        - type: custom:bar-card
          style: |
            ha-card {
              border-radius: var(--border-radius);
              padding: 5px;
          columns: 2
          title_position: 'inside'
          icon: mdi:harddisk
          unit_of_measurement: "%"
          align: split
          color: 'rgba(117,189,111,1.0)'
          entities:
            - entity: sensor.dimka_hdd_usage_c
              title: "Disk C"
            - entity: sensor.dimka_hdd_usage_d
              title: "Disk D"
Screen:
2020-03-30_14-16-12
