Lovelace: Bar Card
No you have to change the type of bar-card in the resources config to Javascript Module instead of Javascript File.
Cool that worked. So now my card is different.
First row one is bigger than the rest and have those eye icons on the left now.
Hereā€™s my Lovelace code for reference:
cards:
  - entities:
      - sensor.homeserver_ping_google
    font_size: 60
    height: 20
    hours_to_show: 168
    line_width: 2
    points_per_hour: 0.25
    show:
      extrema: true
      fill: true
      icon: false
      state: false
    type: 'custom:mini-graph-card'
  - entities:
      - entity: sensor.homeserver_up_time
      - entity: sensor.homeserver_c_drive_used
        height: 30px
        max: 100
        min: 0
        name: C Drive Used
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          '--paper-card-background-color': 'rgba(84, 95, 108, 0.7)'
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
        type: 'custom:bar-card'
      - entity: sensor.homeserver_d_drive_used
        height: 30px
        max: 100
        min: 0
        name: D Drive Used
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
      - entity: sensor.homeserver_e_drive_used
        height: 30px
        max: 100
        min: 0
        name: E Drive Used
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
      - entity: sensor.homeserver_f_drive_used
        height: 30px
        max: 100
        min: 0
        name: F Drive Used
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
      - entity: sensor.homeserver_memory_used
        height: 30px
        max: 100
        min: 0
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
      - entity: sensor.homeserver_cpu_used
        height: 30px
        max: 100
        min: 0
        rounding: 5px
        saturation: 50%
        severity:
          - color: Green
            to: 50
          - color: Orange
            to: 79
          - color: Red
            to: 100
        style:
          border-radius: 8px
          left: 1%
          overflow: hidden
          top: 37.5%
          transform: none
          width: 48%
title: HomeServer
type: vertical-stack
NOTE: Just noticed the icon: off option in the docs which either is new or wasnā€™t showing before. So I added that to each section and itā€™s gone now but now I have whitespace on the left side. Think this update makes it standard with how HA normally works? Not that I like that it doesnā€™t adjust but think Iā€™ve seen other things in Lovelace do that. Kind of the this is where the icon goes, if you donā€™t want one, this is still where the icon goes.
Youā€™re making it much more complicated that it needs to be and you have a couple of things in there that wonā€™t even work at all. This should probably do what you want:
entities:
  - entity: sensor.example
    name: C Drive Used
    name: D Drive Used
    name: E Drive Used
    name: F Drive Used
height: 30px
positions:
  icon: 'off'
severity:
  - color: Green
    to: 50
  - color: Orange
    to: 79
  - color: Red
    to: 100
You da man. Thanks Lucas that works out much better.
Am I doing something wrong, expecting too much or is there a bug?
  - type: custom:bar-card
    entities:
      - sensor.loungemotion_battery_level
      - sensor.kitchendoor_battery_level
      - sensor.kitchendoorlock_battery_level
    severity:
      - color: firebrick
        to: 10
      - color: darkorange
        to: 28
      - color: gold
        to: 69
      - color: Green
        to: 100
I get the following:
The icons are eyes, whereas the actual icons for the entities are batteries at various levels of discharge e.g.
Shouldnā€™t the entity icon be used?
Iā€™m not really sure. The icons are part of the custom-card-helpers module, Iā€™ll have to look into that. For now I guess the best option is to just set the icon for the bar.
Thanks - ideally Iā€™d like to use the entity icon, it automagically reduces as the battery level does.
For now, Iā€™ll probs just turn it off.
Great card though, it works fine for a number of other scenarios.
How do I get the bar card to have the same dimensions (hxw) as the other cards in a stack ?
title: Nieuw
panel: true
cards:
  - type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
          - !include
            - '../templates/graph.yaml'
            - entity: sensor.verbruik_water_uur
              line_color: red
              icon: mdi:water
              aggregate_func: "max"
              points_per_hour: 1
              show_name: true
              show_icon: true
              align_icon: "right"
          - !include
            - entity: sensor.zonneboiler_temperatuur
              line_color: red
              icon: mdi:thermometer
              show_name: true
              show_icon: true
              align_icon: "right"
          - !include
            - '../templates/button.yaml'
            - entity: sensor.verbruik_water_huidige_douche
          - type: 'custom:bar-card'
            positions:
              icon: 'off'
              indicator: 'off'
            entities:
              - sensor.verbruik_douche_min_3
              - sensor.verbruik_douche_min_2
              - sensor.verbruik_douche_min_1
              - sensor.verbruik_water_huidige_douche
#               title: Direction
            direction: up
            stack: horizontal
            style: |-
                bar-card-card {
                    height: 100%;
Hmmā€¦ so a variable changed with the latest updateā€¦ ok fixed that. But the % value has jumped down the bottom again. I am using this css:
                    style: |-
                      bar-card-value {
                        margin-top: auto;
                        margin-bottom: auto;
                        font-weight: bold;
I want the percentage in the middle of the bar. It is also ignoring the font-weight.
Hi thank you for the work, just updated to the last version and i notice that if several bars are listed (not entity row) there is only 1 indicator for 1 bar, the other bars doest have it.
Yeah mine all went to pit also, managed to correct the value position manually with adjusting the top position.
The indicator only shows up when the value has changed, so thatā€™s probably why you donā€™t see it on all bars?
Should be fixed in 3.1.2. I had removed the ha-card element when the card is being used as an entity_row however this caused issues with card-mod. So now Iā€™ve just hidden the ha-card element instead.
3.1.2 Should now correctly scale inside a horizontal stack if you just set the height to 100%.
Since updating ot the most recent version I am getting ā€œCustom element doesnā€™t exist: bard-cardā€ in the front end and this error in my log. Any suggestions:
Log Details (ERROR)
Logger: frontend.js.latest.202004072
Source: components/system_log/__init__.py:209
First occurred: 12:32:49 PM (5 occurrences)
Last logged: 12:49:30 PM
http://192.168.10.25:32500/hacsfiles/frontend-20200422201603.js:1:17185 Uncaught NotSupportedError: Failed to execute 'define' on 'CustomElementRegistry': the name "hacs-frontendbase" has already been used with this registry
http://192.168.10.25:32500/hacsfiles/bar-card/bar-card.js:5332:1 Uncaught SyntaxError: Unexpected token 'export'
http://192.168.10.25:32500/hacsfiles/custom-header/custom-header.js:1:15191 Uncaught TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'.
http://192.168.10.25:32500/hacsfiles/bar-card/bar-card.js:5332:1 Uncaught SyntaxError: Unexpected token export
@VMCosco, take a look at this post: Lovelace: Bar Card
@mirekmal Thanks, I should have scrolled up further first
since latest update Iā€™m unable to use card-mod for following elements
bar-card-title:
bar-card-targetmarker:
I used to use the bar-card-background to adjust them but that no longer works the way it used either.
Also the width: has no bearing the bar just auto scales the card.
@Gluwc any chance to get in some future version bar gradient? Something like is implemented for horse-shoe-card? Iā€™m currently working on Ookla (speedtest.net) inspired theme and it would be fantastic!
Iā€™ll have a look, I had to change the way the CSS is applied so some things a slightly more tricky to get working (or are hard-coded as element style which should be fixed anyway). Could you post your config for one of the bars so I can debug it?
