I think they mixed in config-template-card
in there to get it working like you’re expecting.
Yeah starting to think this is to messy to make happen and don’t want to leave static info in there. Like I’m replacing a hard drive this weekend so would have to remember to go back here and update the max value with the new hard drive space. Thinking I’ll back away from trying to use HA to monitor my servers for now. Or maybe if I switch to a percentage method would be more dynamic.
So for now went with this:
You need to use the latest version of https://github.com/iantrich/config-template-card to make this work.
3.1.0 now with visual editor! There might still be some bugs in the card itself since I had to rewrite most of it to fit the boilerplate template.
Getting an error with 3.1.0:
Uncaught SyntaxError: Unexpected token 'export' bar-card.js:5219
How can I use this editor when I am in YAML mode for the UI?
You can’t, for each Dashboard it’s either YAML or GUI.
I have my main yaml dashboards (cos doing anything repetitive or complex with the GUI is highly irritating / impossible). I have a seperate Dashboard that’s GUI managed and enables me to ‘play’ with GUI editors a bit and then copy the yaml if I like what I saw.
This is in my configuration.yaml
lovelace:
mode: storage
dashboards:
db-mobile:
mode: yaml
title: Mobile
icon: mdi:cellphone-android
show_in_sidebar: true
filename: db_mobile.yaml
db-pc:
mode: yaml
title: PC
icon: mdi:laptop-chromebook
filename: db_pc.yaml
Gives me two yaml dashboards and as many more as I want configured in the UI. I make the yaml dashboards default on my devices and can navigate to the UI one(s) if I wish.
That is an interesting idea! I think I will have to take a look how this works.
Just updated and all my Bar cards are broken:
And how do I get the visual editor?
It’s now requirered to load this card as a module
resource instead of js
. I’ve added this to the breaking changes.
Also the visual editor should just work out of the box as long as you don’t have it embedded inside another card, it even shows up in the card picker.
Ok, so I need to change “js” to “module” in the lovelace_resources file? Or is there more to it?
Yes you have to change it in the resources file if you’re using YAML mode or in the Lovelace config page if you’re using GUI.
Thank you. So much easier to edit the cards now. Love it.
Can you please advise how to remove the “margin-bottom” only from the last row in case of multiple rows, now that I see that specific ID’s were removed.
Please see for example:
Here is the code:
- type: custom:bar-card
style: |
.card-content {
padding: 6px;
#states > * {
margin-top: 0;
bar-card-iconbar {
color: var(--bar-card-icon-color);
unit_of_measurement: "%"
#stack: vertical
positions:
icon: "inside"
value: "inside"
indicator: "off"
entities:
- entity: sensor.synology_zeg_volume_used_volume_1
icon: mdi:harddisk
color: 'rgba(117,189,111,1.0)'
- entity: sensor.synology_zeg_cpu_load_system
icon: mdi:chip
color: 'rgb(43, 154, 249)'
- entity: sensor.synology_zeg_memory_usage_real
icon: mdi:memory
color: 'rgb(87, 0, 127)'
Also, not related, seems to be something wrong with “stack: vertical” definition, had to comment it out, although this seems to be the default configuration anyway. The “stack: horizontal” on my other cards working just fine.
Thanks in advance.
@Gluwc absolute legend!!!
Adding entity_row:true
to each entity got rid of the black space. Thanks heaps!
This has been fixed in 3.1.1 to match the default margins of the standard HA cards for the rows inside #states
. This means you only really have to reduce the #states
padding to get the same result:
#states {
padding: 8px;
Also having the bar-card doesn’t exist error. Should the install from the community store take care of installation changes? So what needs to physically be done? The concept that it needs to load as a “resource” not sure what that means. Are we saying it needs to be in our configuration.yaml or something?
The loading of resources for custom cards has been moved to Configuration>Lovelace Dashboards>Resources.
If you had this loaded a js
file before this was moved to the config panel it’s probably still defaulting to js
Thanks. So delete the www/community/barcard folder?
