Lovelace: Bar Card
Try using stack-in-card instead. Afaik vertical-stack-in-card is no longer being maintained.
Update: issue #75 created.
Iā€™m having the same issue, I switched to stack-in-card, doesnā€™t help.
When I move the card outside of the stack-in-card, this error is in the log:
http://192.168.xxx.yyy:8123/local/community/bar-card/bar-card.js:5349:1 Uncaught SyntaxError: Unexpected token 'export'
Bar-card == v3.1.5
This means youā€™re not loading the card as a module. You can fix this in the Lovelace resources config panel.
@Gluwc: There is another problem. Since the rewrite, the level is displayed with 100% if the attribute is not available, e.g. the brightness level of Z-Wave lamps when they are switched off. Can you please change this to the previous behaviour?
Thanks. That was what broke my cards.
How did that change all of a sudden?
bar-card used in picture-element as curtain states for each rooms. (blue means curatin are opened)
after update direction for right/down are not working anymore. ( refer center blue bar ā€¦ only work for left )
Is there any posibillity to used old method?
        - type: custom:bar-card
          entity: sensor.curtain_livingroom_current_position
          height: 4px
          width: 100%
          color: '#99d3ff'
          direction: left
          entity_row: true
          positions:
            icon: 'off'
            value: 'off'
            indicator: 'off'
          style:
            top: 86.6%
            left: 42.5%
            width: 15%
          height: 4px
          width: 100%
          color: '#99d3ff'
          direction: right
          entity_row: true
          positions:
            icon: 'off'
            value: 'off'
            indicator: 'off'
          style:
            top: 86.6%
            left: 58%
            width: 15%
Currently not directly supported but you could use card-mod to rotate the bar:
style: |-
  bar-card-background {
    transform: rotate(180deg);
@Gluwc Iā€™m back my friend a new issue since either latest version of your card or ha v 0.109 unsure as I upgraded both at the same time :frowning: . The gap between entities on a multi-entity bar card is huge now.
Before
After
Hi @Gluwc
did you get a chance to check this yet? https://github.com/custom-cards/bar-card/issues/79
not sure if HA update or Barcard update caused the error, so hope you can fix this?
thanks!
thx that fixed it for me too, indeed strange this changed
Whatever I do, the custom bar card canā€™t be found. I import via:
- url: /local/bar-card.js
  type: module
- type: custom:vertical-stack-in-card
        title: EPSON XP 830
        cards:
            columns: 5
            direction: up
            entities:
              - color: MediumTurquoise
                entity: sensor.epson_xp_830_series_cyan_ink
              - color: MediumOrchid
                entity: sensor.epson_xp_830_series_magenta_ink
              - color: Gold
                entity:  sensor.epson_xp_830_series_yellow_ink
              - color: Black
                entity:  sensor.epson_xp_830_series_black_ink
              - color: Black
                entity:  sensor.epson_xp_830_series_photo_black_ink
            height: 200px
            max: 100
            min: 0
            padding: 2px
            target: 20
            title_position: bottom
            icon_position: inside
            unit_of_measurement: '%'
            width: 100%
Erorr:
Custom element doesn't exist: bar-card.
type: 'custom:bar-card'
columns: 5
direction: up
entities:
  - color: Gold
  - color: Black
  - color: Black
height: 200px
max: 100
min: 0
padding: 2px
target: 20
width: 100%
the ink levels is very cool, @Mariusthvdb - do you have the code in github, or can you share it?
sure:
type: entities
title: Epson printer
show_header_toggle: false
entities:
  - device_tracker.epson_printer
  - entity: script.update_epson_cartridge_sensors
    action_name: Update
  - type: custom:hui-glance-card
    style: |
      ha-card {box-shadow:none;}
    entities:
      - entity: sensor.epson_ink_level_black
      - entity: sensor.epson_ink_level_cyan
      - entity: sensor.epson_ink_level_magenta
      - entity: sensor.epson_ink_level_yellow
      - entity: sensor.epson_ink_level_waste
    style: |
      bar-card-value {color:darkgrey;}
      bar-card-title {word-break:break-all;}
    stack: horizontal
    entity_row: true
    direction: up
    entities:
       - color: black
       - color: cyan
       - color: magenta
       - color: yellow
       - color: grey
    height: 150px
    max: 100
    min: 0
    target: 20
    width: 100%
    positions:
      icon: 'off'
  - input_number.ink_level
  - automation.printer_ink_alert
  - type: custom:fold-entity-row
    head:
      type: section
      label: Low ink levels
    padding: 0
    entities:
        style: |
          ha-card {
            box-shadow: none;
            background-image: url('/local/devices/epson/official/epson_background.png');
            background-size: cover;
        entities:
          - entity: binary_sensor.ink_level_black_threshold
          - entity: binary_sensor.ink_level_cyan_threshold
          - entity: binary_sensor.ink_level_magenta_threshold
          - entity: binary_sensor.ink_level_yellow_threshold
          - entity: binary_sensor.ink_level_waste_threshold
be ware though, the bottom section for the glance card isnā€™t yet styled as I want it, (to use the full width of the card) Apparently Glance card behaves differently when styling is concerned.
thanks mateā€¦
I get an error I canā€™t resolve with the Bar Cardā€¦ has anyone seen this before? doesnā€™t matter what I do with ā€œindicatorā€ it throws this error. was also throwing an error for title_position and roundingā€¦ Home Assistant running non-HASSIO on Raspbian - I suspect Iā€™m missing a dependency but the logs arenā€™t telling me as much
From reading the documentation, arenā€™t inside, outside and off the only possible settings for indicator:? Iā€™m probably wrong, but it might be choking on your use of auto.
itā€™s also supposed to have a default, but fails if I leave it blank as wellā€¦
Straight from the repo these are the valid options for postions
so you either need to select one of these or donā€™t put it in there at all if you want it auto
@Gluwc just want to say bar card is awesome I use it in so many of my cards
Is there anyway to increase the gap between the bar and the value? I canā€™t relly get it to work.
        - type: 'custom:bar-card'
          entity: sensor.glances_ram_used_percent_2
          positions:
            indicator: off
            value: outside
          width: 70%
          height: 15px
          style: |
            bar-card-card	 {
              margin-right: auto;
              margin-left: auto;
              margin-bottom: 0px;
              margin-top: -50px;
          entity: sensor.glances_data_used_percent
          positions:
            indicator: off
            value: outside
          width: 70%
          height: 15px
          style: |
            bar-card-card	 {
              margin-right: auto;
              margin-left: auto;
              margin-bottom: auto;
              margin-top: -50px;
and I want to steal your usage for my own cards, hurry up and share :wink:
