I’m using the bar as part of a custom:stack-in-card and I’m manipulating it’s position within that card.
Here is my thermometer inspired temperature bar-card.
I’m sure that the code could be cleaner, but I’m not a CSS mage. Btw it works fine.
entities:
- entity: sensor.shelly_homerseklet_halo
- entity: sensor.heating_temperature
- entity: sensor.shelly_homerseklet_pince
- entity: sensor.dark_sky_temperature
decimal: 1
max: 40
min: 10
severity:
- color: '#0080FF'
to: '19'
- color: '#40bf40'
to: '22'
- color: '#bf9540'
to: '25'
- color: '#c0392b'
to: '40'
direction: up
height: 150px
width: 24px
positions:
indicator: inside
icon: 'off'
style: |-
.card-header {
font-size: 18px;
bar-card-value, bar-card-name {
font-size: 12px;
transform-origin: 0 0;
transform: rotate(270deg);
text-shadow: 1px 1px #0008;
white-space: nowrap;
bar-card-value {
margin-right: auto;
margin-left: 6px;
margin-bottom: auto;
margin-top: auto;
bar-card-name {
margin-right: auto;
margin-left: 0px;
margin-bottom: -130px;
margin-top: 130px;
right: 20px;
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 12px;
border: 1px solid #DDD9;
stack: horizontal
title: Hőmérséklet
type: 'custom:bar-card'
Getting tons of this error after upgrading to the latest release:
2020-04-29 15:39:53 ERROR (MainThread) [frontend.js.latest.202004072] https://xxxxxxxx.duckdns.org/hacsfiles/bar-card/bar-card.js:5340:1 Uncaught SyntaxError: Unexpected token 'export'
2020-04-29 15:42:46 ERROR (MainThread) [frontend.js.latest.202004072] https://xxxxxxxx.duckdns.org/hacsfiles/bar-card/bar-card.js:5340:1 Uncaught SyntaxError: Unexpected token 'export'
2020-04-29 15:43:17 ERROR (MainThread) [frontend.js.latest.202004072] https://xxxxxxxx.duckdns.org/hacsfiles/bar-card/bar-card.js:5340:1 Uncaught SyntaxError: Unexpected token 'export'
And in the frontend i get ‘Custom element doesn’t exist: bar-card.’
How to fix?
Go to:
Configuration -> Lovelace Dashboards->Resources
and check if you have it like this:
I had the same problem and when I changed it from “JavaScript File (deprecated)” to “JavaScript Module”, it worked!
thx to @hajo62
Yes i got it! Thanks
I had this set up fine before but I am guessing that I missed a change or something. What element do I have to change to have the right margin, match the left? The is in just a bit from the edge. I have the margins under bar-card-card both set for 7px. This used to work.
style: |-
bar-card-card {
margin-left: 7px;
margin-right: 7px;
margin-top: 10px;
bar-card-value {
font-size: 18px;
font-weight: bold;
margin-right: 215px;
bar-card-title {
font-size: 14px;
font-weight: bold;
margin-left: 20px;
Change bar-card-title to bar-card-name
Thanks. That actually fixed another issue. I was actually referring to this margin
You can use margin or padding right / left where you are using it no longer applies as I discovered. You will need to apply it the the bar-card-bar elements instead. I am not at my pc but background and another should get it done.
shouldn´t
style: |
bar-card-background {
color: var(--dwains-theme-names);
change the color of the background?
Depends on what background you’re trying to change, but that element only contains all the bar elements including the bar background. You probably either want bar-card-backgroundbar
or ha-card
i´m an idiot. got it working with
style: |
ha-card {
background-color: var(--dwains-theme-primary);
This is my current setup still on bar-card version 2.0.2. It uses horizontal and vertical stacks.
Is there a way to have the same thing with ver 3.x?
Thank you.
Having the name and value like that requires some custom CSS, however you can get the layout very easily by putting all the entities in a single barcard and setting columns
to 4.
After some fiddling around, I was able to get this:
Only two things missing now. To add a shadow to the sensor itself and to make the indicator arrow to be on the right side.
mind sharing your code?
Ok here you go
- type: custom:bar-card
entities:
- entity: sensor.yatak_sicaklik_offset
- entity: sensor.banyo_sicaklik_offset
- entity: sensor.hol_sicaklik_offset
- entity: sensor.kurutma_sicaklik_offset
- entity: sensor.calisma_sicaklik_offset
- entity: sensor.mutfak_sicaklik_offset
- entity: sensor.broadlink_sensor_temperature
- entity: sensor.camasir_sicaklik_offset
- entity: sensor.kapi_onu_sicaklik_offset
- entity: sensor.balkon_dis_fark
min: -30
max: 30
severity:
to: -3
color: '#4095bf'
to: 3
color: '#40bf40'
to: 30
color: '#a93636'
- entity: sensor.balkon_sicaklik_offset
- entity: sensor.purifier_aqi
min: 0
max: 300
severity:
to: 50
color: '#40bf40'
to: 150
color: '#4095bf'
to: 300
color: '#a93636'
- entity: sensor.dark_sky_humidity
min: 0
max: 100
severity:
to: 40
color: '#a93636'
to: 85
color: '#ffbf40'
to: 100
color: '#40bf40'
- entity: sensor.holbme_air_quality
name: Hol Hava Kalite
min: 10000
max: 25000
severity:
to: 15000
color: '#40bf40'
to: 20000
color: '#ffbf40'
to: 25000
color: '#a93636'
animations:
state: 'on'
positions:
icon: 'off'
title: inside
value: inside
style: |-
.contentbar-direction-right {
flex-direction: column;
.min-direction-right {
margin: 0px;
margin-bottom: -20px;
bottom: 10px;
bar-card-value {
margin: 0px;
font-size: 13px;
margin-left: auto;
margin-right: auto;
font-weight: bold;
text-shadow: 1px 1px #0005;
bar-card-name {
margin: 0px;
margin-top: 5px;
font-size: 14px;
font-weight: bold;
bar-card-max {
margin: 0px;
margin-left: auto;
margin-top: -20px;
top: 10px;
bar-card-divider {
display: none;
ha-card {
background-color: #383C45;
width: 100%
min: -10
max: 40
columns: 4
severity:
to: 16
color: '#4095bf'
to: 26
color: '#40bf40'
to: 40
color: '#a93636'
I’m running HASSIO and everything was fine until a couple of updates ago. Since then all my bar-cards have stopped being displayed. Now I just get the big red box of doom saying;
I’m using the custom:layout-card by Thomas Lovren. Bar cards displayed outside of this appear to work fine.
Any ideas what’s wrong & how to fix it?
Thanks.
Same here after updating to 0.109.1.
bars sitting inside a custom vertical-stack-in-card
That’s how I am using it too!
