@Gluwc Is there a chance that target option could be entity value instead of number?
hi guys, is there a way to have the bar that refers to a value with respect to that of the entity? let me explain; I would like to have the bar that shows the hours or days and the entity that measures electricity consumption for example. itâs possible?
Iâm combining the button card and bar card and largely happy with the results, just one minor niggle as per this graphic.
As you can see the middle two bars are longer given the text to the right is shorter - I canât seem to discover what settings would make the bars the same width irrespective of the value?
The code for the bar-card section is below:
type: 'custom:bar-card' height: 11 width: 60 positions: value: outside indicator: outside icon: off name: off entities: - entity: sensor.epson_wf_3520_series_black_ink color: Black name: Black - entity: sensor.epson_wf_3520_series_cyan_ink color: MediumTurquoise name: Cyan - entity: sensor.epson_wf_3520_series_magenta_ink color: MediumOrchid name: Magenta - entity: sensor.epson_wf_3520_series_yellow_ink color: Gold name: Yellow style: | ha-card { background-color: transparent; box-shadow: none;} bar-card-card { margin-left: -10px; margin-bottom: -3px; margin-top: -3px; } bar-card-currentbar, bar-card-backgroundbar { border-radius: 0.5em; } bar-card-value { overflow; visible; padding-left: 10px; margin: 0px; } .card-content { text-align: start; padding: 0px; }
[quote=âjchasey, post:572, topic:87503â]
I copied your code and made no changes except for my printer entities and this is how mine looks:
This is viewing with FireFox.
height: 11
width: 60
positions:
value: outside
indicator: outside
icon: 'off'
entities:
- entity: sensor.hp_officejet_pro_8620_black_ink
color: Black
- entity: sensor.hp_officejet_pro_8620_cyan_ink
- entity: sensor.hp_officejet_pro_8620_magenta_ink
color: MediumOrchid
- entity: sensor.hp_officejet_pro_8620_yellow_ink
color: Gold
style: |
I think will only become apparent when one of the numbers drops below 10% to become a single digit.
I also added to a vertical-stack just to see and it still shows the same:
type: vertical-stack
cards:
- entities:
- entity: binary_sensor.ping_hp_officejet_8625
title: Printer
type: entities
state_color: true
- type: 'custom:bar-card'
height: 11
width: 60
positions:
value: outside
indicator: outside
icon: 'off'
entities:
color: Black
color: MediumOrchid
color: Gold
style: >
ah, ok
Let me play around then. Quick fix might be formatting the percent to with a forward 0 (Iâve never tried this but might work.)
Not the best fix but if you change positions\value: to inside it will keep a constant line width.
I changed the indicator to inside also to make it more compact.
positions:
value: inside
indicator: inside
icon: 'off'
Edit: nevermind
I used it this way
type: 'custom:button-card'
entity: sensor.hp_laserjet_100_colormfp_m175nw
color: gray
show_state: true
styles:
card:
- padding: 0 5px 5px 0
grid:
- grid-template-areas: '"i barcard" "n s"'
custom_fields:
barcard: null
custom_fields:
barcard:
card:
entities:
- entity: sensor.hp_laserjet_100_colormfp_m175nw_imaging_drum_hp_ce314a
color: Grey
- entity: sensor.hp_laserjet_100_colormfp_m175nw_black_cartridge_hp_ce310a
color: Black
- entity: sensor.hp_laserjet_100_colormfp_m175nw_cyan_cartridge_hp_ce311a
- entity: sensor.hp_laserjet_100_colormfp_m175nw_magenta_cartridge_hp_ce313a
color: MediumOrchid
- entity: sensor.hp_laserjet_100_colormfp_m175nw_yellow_cartridge_hp_ce312a
color: Gold
width: 50px
direction: up
columns: '5'
entity_row: true
positions:
icon: null
indicator: inside
value: outside
style: |
bar-card-value { overflow; visible; padding-left: 5px; margin: 0px; }
.card-content { text-align: start; padding: 1px; }
Iâm updating a lot of stuff at the moment, and it seems this wonât work anymore at all?
severity:
- color: '#6CA51F'
value: Er is iemand thuis
- color: '#EF1107'
value: We zijn allebei weg
I loved this option, with the colours it was pretty easy to see states very quick (like red = alarm / orange is warningâŚ)
Helo, i found a problem with bar-card and config-template-card.
I use barcard to show temperature in room and target option to visualize current setpoint of thermostat
When i use cards together target option is working fine but there is a problem with refreshing bar, i noticed that temperare values changes but not updates
When i remove config-template card everything is working fine. To be honest old method of target entity was waaay beter (or charging entity)
Code below:
edit: for some reason github is not parsing code well so i remove it and put on pastebin
You need to add the entities youâre watching to the entities list of config-template-card or they wonât update.
Point, bar is updating but animation is not working.
+1 , animation seem to be broken?
Has anyone managed a timer with the bar card?
I have converted the timer into seconds but the remaining time does not update in real time but only when the timer is paused.
I canât for the life of me figure out why the names of my entities are still showing as per the below!
style: |
ha-card {
border-radius: 12px;
box-shadow: none;
background-image: none;
color: var(--primary-color)
stack: horizontal
height: 8
entities:
- sensor.robomac_battery_level
- sensor.robomac_filter
- sensor.robomac_brush
positions:
minmax: 'off'
indicator: 'off'
title: 'off'
value: inside
icon: outside
unit_of_measurement: '%'
severity:
- value: 70
- value: 85
color: var(--light-primary-color)
- value: 95
- value: 100
color: '#F5AB98'
No matter what I change in the positions: code they donât disappear. Have reset cache and everything.
Help!
Your code is strange.
First, in my setup (default theme) it looks like this:
Second, there are errors in the code:
- The
"title"is not supposed to be inside the"positions"section (https://github.com/custom-cards/bar-card#positions-options). - The
"severity"section is wrong - https://github.com/custom-cards/bar-card#severity-options
Thanks for the feedback. Strange that even using my code on yours it looks different to what I am getting.
Iâll rebuild it from the ground up and see whatâs going on!
Try to:
- clean browserâs cashe
- check if âbar-cardâ is updated
