Yes, your code works in my setup:
type: custom:auto-entities
card:
type: custom:bar-card
show_empty: false
filter:
template: >-
{% for state in states.sensor | selectattr('attributes.device_class', '==', 'battery') %}
{% if 90 <= state.state | int(-1) %}
{{ state.entity_id }}
{% endif %}
{% endfor %}
Gives a list of batteries >= 90% (if “90” is specified).
kdzoha
December 8, 2021, 7:48am
633
Thank you so much. This is definitely one of the things I find tricky to do on HA as a noob. I didn’t identify that type in auto entities could be bar-card.
kdzoha
December 13, 2021, 6:05pm
634
So this
card:
icon: mdi:battery
positions:
icon: 'off'
indicator: inside
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
columns: 1
show_empty: false
filter:
template: >-
'battery') %}
{% endfor %}
yields the following
which mostly meets my needs.
Does someone know how to significantly reduce font size to fit the long names… I’m maybe hoping for 2 columns OR, is there a way to select the entities friendly_name
which would remove "Hash Power " from each of the entities listed
scootaash
(Fraser)
December 18, 2021, 9:16pm
635
I am pretty sure I am being stupid, but I can’t for the life of me get the text in the individual bars to change style. Can anyone help? Tried the code below and a whole pile of variations on a theme including putting styles against the various entities but nothing seems to change the font. Would like to centralise the text too.
Card-mod is installed
If anyone is interested it is linked to the excellent sensors for zwift and is a power meter for my home cycling setup.
Thanks!
color: rgba(117,189,111,1.0)
stack: horizontal
style: |-
bar-card-name{
margin-right: auto;
font-size: 10px;
font-weight: bold;
text-shadow: 1px 1px #0005;
positions:
icon: 'off'
title: 'off'
value: 'off'
indicator: 'off'
entities:
- entity: sensor.zwift_power_215592
color: rgb(127, 127, 127)
min: 56
max: 125
color: rgb(55, 138, 245)
min: 125
max: 171
color: rgb(89, 189, 89)
min: 171
max: 206
bar_style:
font-size: 50%
color: rgb(248, 204, 68)
min: 206
max: 240
color: rgb(237, 99, 52)
min: 240
max: 275
color: rgb(236, 49, 35)
min: 275
max: 338
min: 338
max: 1500
kongjudas
(Kongjudas)
January 12, 2022, 6:24pm
636
Any ideas how to use templates in bar-card? I want the target
to show the max entity. Is it at all possible to use templates in this card?
entities:
- name: Badet
target: "{{ 'states('sensor.badet_gulvvarme_electric_consumption_max' ) }}"
unit_of_measurement: w
entity: sensor.badet_gulvvarme_electric_consumption_w
icon: mdi:shower
Put the card into config-template-card
kongjudas
(Kongjudas)
January 12, 2022, 9:30pm
638
Brilliant! That did the trick. Thanks
ZyberSE
January 22, 2022, 12:27pm
639
I’m looking to have a graph (0-100%) showing the current progress of my washing machine, but with a little twist.
Instead of a static name I would like to show time remaining, something I get from a template.
Would it be possible todo this?
Put the card inside config-template-card
Hi, nice card.
Can you share the custom button code?
I don’t get the bars on the correct position.
jchasey
(John Chasey)
January 25, 2022, 4:16pm
642
- type: custom:button-card
icon: mdi:printer
entity: binary_sensor.epsonprinter
aspect_ratio: 1/1
styles:
card:
- border-radius: 5%
- padding: 10%
- font-size: 12px
- text-transform: capitalize
name:
- font-weight: bold
- font-size: 15px
- align-self: middle
- justify-self: start
- padding-bottom: 4px
img_cell:
- justify-content: start
- align-items: start
- margin: none
icon:
- color: '[[[ if (entity.state != "on") return "red"; ]]]'
- width: 70%
- margin-top: -10%
custom_fields: # removing this line buggers up card - why?
tr:
- align-self: start
- justify-self: end
line1:
- align-self: start
grid:
- grid-template-areas: '"i tr" "n n" "line1 line1"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 40% min-content min-content
custom_fields:
tr: >
return `<span>${entity.state}</span>`
line1:
card:
type: 'custom:bar-card'
height: 11
positions:
value: outside
indicator: outside
icon: off
entities:
- entity: sensor.epson_wf_3520_series_black_ink
color: Black
- entity: sensor.epson_wf_3520_series_cyan_ink
color: MediumTurquoise
- entity: sensor.epson_wf_3520_series_magenta_ink
color: MediumOrchid
- entity: sensor.epson_wf_3520_series_yellow_ink
color: Gold
style: |-
ha-card { box-shadow: none;}
bar-card-card { margin-bottom: -8px; }
bar-card-value { padding-left: 10px; padding-bottom: 2px; margin: -1px; }
.card-content { text-align: start; padding: 1px; margin: 0px; margin-bottom: 8px; }
Thx. This works. It was the style part of the ‘custom: bar-card’ that did the trick.
Hello guys!
I’m not able to change the size with fields highlighted in the image.
- type: horizontal-stack
cards:
- type: custom:bar-card
title: Abastecimento Bloco 1
direction: up
height: 400px #altura da barra
width: 150px #largura da barra
stack: horizontal #posição da barra
entity_row: true
positions:
icon: inside
indicator: outside
value: outside
style: |-
bar-card-currentbar, bar-card-backgroundbar { border-radius: 20px;}
ha-card {border-radius: 20px; box-shadow: none; background-image: none; background-color: transparent; color: black;}
bar-card-value { overflow; visible; padding-left: 5px; margin: 0px; font-size: 21px; }
bar-card-title {font-size: 15px; font-weight: bold; }
entities:
- entity: sensor.volume
icon: mdi:water-percent
unit_of_measurement: '%'
decimal: 0
- entity: sensor.sensor_caixa_b
decimal: 0
severity:
- color: '#FF0000'
to: 20
- color: '#FF6347'
to: 40
- color: '#FFA500'
to: 60
- color: '#32CD32'
to: 80
- color: '#228B22'
to: 100
Can anyone help me?
Thanks.
Gluwc
(Lucas Bramlage)
February 11, 2022, 3:56pm
645
bar-card-name
should work as a style element.
Hi everyone,
first, thanks for the great card.
Can someone share the latest .js-File please?
I don’t want to install hacs
Thanks in advance | Best | W
Has anyone managed to get color gradient bars?
Hi all.
I was wondering if there is a way to configure a horizontal bar with 0 (zero) in the centre to display a sensor that can swing to positive and negative, so that the bar could progressively fill either way from that zero (centre) point.
So far, I’ve only had success with bars that fill from the minimum value to the sensor actual value, so basically a zero value shows half the bar, what would be ideal is a zero value shows no fill and then whether the value is positive of negative the bar could fill from that point either to the left or right.
TIA
Greg
MisterTFM
(THOMAS F MELNIK)
April 9, 2022, 7:13pm
650
Is there a way to create a horizontal bar graph, but sort the order of the entities by their values. Similiar to the bar graph in the Energy card.
type: vertical-stack
cards:
- type: custom:auto-entities
card:
type: entities
entities: []
sort:
method: state
numeric: true
filter:
include:
- entity_id: input_number.test_level_*
card:
entities: []
sort:
method: state
numeric: true
filter:
include:
