Lovelace: Bar Card
Thank you very much, saved me a lot of time.
Alternatively, this may be achieved by card-mod based on this cool method from a card-mod-theme cookbook:
  - type: custom:auto-entities
    card:
      type: entities
    entities: []
    sort:
      method: state
      numeric: true
    filter:
      include:
        - entity_id: input_number.test_level_*
          options:
            card_mod:
              style: |
                :host {
                  {% set battery = states(config.entity) %}
                  background: linear-gradient(to right, rgba(0,255,0,0.5), {{battery}}%, white {{battery}}%);
For real battery sensors their states will be displayed instead of sliders.
no success so far. Thomas, would you mind sharing your code? best Florian
See above posted code by [Ildar_Gabdullin]
Well, that’s what I did. So I thought looking at a second configuration might help in order to figure out what I will have to change. never mind…
Team,
Is it possible to have 3 bars and give one a different background-bar color? (and possibly label-font-color)
Example:
Current config (all with the same color):
type: custom:bar-card
entities:
  - entity: sensor.temphum_blokhut_temp
  - entity: sensor.motion_x_frontdoor_temp
  - entity: sensor.temp_rfx_garage_temperature
direction: up
height: 200px
min: 0
max: 28
stack: horizontal
Use card-mod
To monitor my raspberry, I have a vertical stack + bar-card, but I have the problem that every bar takes different size depending on the value as shown below:
Is there a way to have them with the same size?
Current code is:
              - type: vertical-stack
                cards:
                  # CPU
                  - type: custom:bar-card
                    positions:
                      value: outside
                      indicator: 'off'
                    height: 20px
                    width: 60%
                    entities:
                      - entity: sensor.cpu_usage_raspi4
                        icon: mdi:speedometer
                        severity:
                          - color: rgb(26,204,147,0.33)
                            to: 10.9
                          - color: rgb(206,133,0,0.60)
                            to: 25
                          - color: rgb(163,0,0,0.60)
                            to: 150
                  # Temperature
                    positions:
                      value: outside
                      indicator: 'off'
                    height: 20px
                    width: 60%
                    entities:
                      - entity: sensor.temperature_raspi4
                        icon: mdi:thermometer
                        severity:
                            to: 69.9
                            to: 85
                            to: 150
                  # Disk
                    positions:
                      value: outside
                      indicator: 'off'
                    height: 20px
                    width: 60%
                    entities:
                      - entity: sensor.disk_use_raspi4
                        icon: mdi:harddisk
                        severity:
                            to: 69.9
                            to: 85
                            to: 150
Having problems to get different colors for each bar.
Background: I want to show colors of ink filled from my printer and display it with appropriate color.
Thanks for help, Ralf
Use card-mod
This works but with a caveat.
With card-mod I can change the colors but not one of the 3 bars.
So in the above scenario with 3 bars I had to use a horizontal-stack with 3 separate bars of which the middle one gets a different color.
Let me clarify.
The bar-card may include a list of bars (or just one bar).
Card-mod may be specified for all bars or some particular.
Do you mean you can have a single bar-card with 3 bars and use card-mod to change the color of 1 of these bars? (vs. adding 3 bar-cards of which 1 uses card-mod)
Tnx!
DJ
title: different styles
entities:
  - entity: sensor.memory_use_percent
    min: '0'
    max: '100'
    min: '0'
    max: '100'
    min: '0'
    max: '100'
card_mod:
  style: |
    bar-card-row:nth-of-type(1) bar-card-name {
        color: orange;
    bar-card-row:nth-of-type(2) bar-card-name {
        color: red;
Thank you Ildar!
With your example I was able to make it work for my bars.
  • The CSS had to be changed as I use direction:up and stack:horizontal
  • The actual bar color is stored in a CSS variable so this had to be changed: --bar-card-color
Result:
CODE:
entities:
  - entity: sensor.motion_x_garage_temp
  - entity: sensor.temp_x_living_temp
title: Temperature comparison
direction: up
height: 200px
min: 0
max: 28
stack: horizontal
card_mod:
  style: |
    bar-card-row bar-card-card:nth-of-type(2) {
        --bar-card-color: red;
As you can see I had to
  • go to bar-card-row (with a horizontal stack you only have 1 row)
  • Go through the bar-card-card's and use :nth-of-type(2) to modify the 2nd one.
Then…
…a crazy idea came to mind: why not use severity colors?
A short version of your example would look like this:
entities:
    severity:
      - color: Red
        to: 99999
resulting in 3 bars with the middle one being red.
I still like the one with card_mod better, just because I can :slight_smile:
ILDAR )
Mmm, may be, I was not thinking about settings for bars, just wanted to show how to style particular bars.
Can someone help me on how to change the bar color (or hide it) if the entity state is “unknown”?
Kind of this:
entities:
  - entity: sensor.battery_samsung_p6800
    direction: right
    icon: mdi:battery
card_mod:
  style: |
    bar-card-row {
      {% if states("sensor.battery_samsung_p6800") in ['unavailable','unknown'] %}
      --bar-card-color: var(--disabled-text-color);
      {% endif %}
Hide what?
Thanks, that works. By hiding it, I meant hiding the bar itself. I found that the “severity” option can have a “hide” option, but how do I format the boolean? hide: {{ is_state('sensor.tpms_f1a819c8', 'unknown') }} doesn’t seem to work.
  1. Check this example:
    entities:
        direction: right
        icon: mdi:battery
    severity:
        to: 20
        icon: mdi:battery-alert
        to: 30
        hide: true
Then change a value of the sensor.battery_samsung_p6800:
And if the value = 29:
In some cases this “hiding the bar” may not look fine for you due to it’s vertical sizes.
Probably, if the bar-card is placed between entity-rows the hiding will look better, check it by yourself.
  1. You cannot use this:
    severity:
        to: unknown
  1. Here you are trying to use a template:
which is not supported.
  1. How to hide by using “card-mod”:
    Let’s consider a bar-card inside a stack:
cards:
  - type: entities
    entities:
      - sun.sun
    entities:
        direction: right
        icon: mdi:battery
    card_mod:
      style: |
        ha-card {
          display: none;
          {% endif %}
  - type: entities
    entities:
      - sun.sun
Now change a value of the sensor to "unknown":
The card is not displayed but still there is vertical spacing after the hidden card - which leads to a DOUBLE spacing.
Also you may try using a custom:state-switch card.
