Use auto entities and bar card together.
type: custom:auto-entities
filter:
include:
- entity_id: '*sensor.*battery'
exclude: []
sort:
method: state
numeric: true
card:
type: custom:bar-card
filter:
include:
exclude: []
sort:
method: state
numeric: true
card:
Is this card still available in HACS? I only can find bar card timer!
Thank you @Ildar_Gabdullin . But it does not come out when I type bar. See screenshot!
Have you tried pressing âexplore & download repositoriesâ?
That did it ! Thank you very much!
How may I change the icon color? Iâve tried the below (with card-mod installed)
- entity: sensor.hp_laserjet_200_cyan_cartridge_hp_cf211a
color: cyan
style: |
:host {
--card-mod-icon-color: cyan;
I canât get it to sort, the card is the same as the bar-card.
filter:
include:
- entity: sensor.candeeiro_current_consumption
- entity: sensor.meross_maq_lavarsecar_power
- entity: sensor.tomada_pilhas_power
- entity: sensor.tomada_powerbanks_power
exclude: []
sort:
method: state
numeric: true
reverse: false
card:
title: Consumos instantâneos
entities:
icon: mdi:desk-lamp
max: 9
[etc...]
Using the card in a wrong way.
Start with removing âentitiesâ.
If I remove entities from bar-card, Iâm not able to configure some specs as severity or max individually.
Then WTH are you trying to use auto-entities for 4 entities?
And with different individual options )))
Assume you have 10 entities in a list.
Assume you have SAME options like severity etc.
Then list these entities in ONE âincludeâ filter; then define a common âoptionsâ section with commonly used options.
Assume you need to have DIFFERENT options for each entity.
Then you need to define TEN âincludeâ filters with individual âoptionsâ.
itâs great card, I used to use it but suddenly after card mode updated the animation not working any more. Can you please help. Iâm sure the style feature changed, but I donât know how to fix. Thank you
You will sort it out by yourself! With my help.
Thank you very much, after reading the releasing notes for the latest card-mod update, I knew the missing part. ![]()
hi can you please explain how to download this card with HACS
Go to your HACS page. Click the 3 dot menu
Click custom repositories
Is it possible to have the card driven by a sensor which can be positive (bar to the right) or negative (bar to the left), when value is zero, nothing (or a single line in the center)
DIfficult to do? Hint?
Its a sensor of a wheel of a boat, if the wheel is turned right/left it should show in the card. Hope I am clear
