Lovelace: Bar Card
I look for a history possibility…
On each day I check some sets of sensors, but I cannot see the values from the day before or 2 days before or 1 week before (like in the Energy Dashboard)…
I need this for 16 or 32 or 48 Sensors or for the whole page… please see the picture:
Is there a possibility to solve this? With some Buttons for example similar this:
Energy Sensors Date
type: vertical-stack
cards:
  - type: custom:auto-entities
    card:
      type: custom:bar-card
      title: Individual
      width: 10
      icon: mdi:lightning-bolt
      align: split
      columns: 1
      decimal: 2
      height: 40
      unit_of-measurement: kWh
      max: 50
      severity:
        - color: red
          to: '50'
        - color: orange
          to: '30'
        - color: green
          to: '10'
        - color: blue
          to: '5'
      entity_row: true
    entities: []
    sort:
      method: state
      numeric: true
      reverse: true
    filter:
      include:
        - entity_id: sensor.stube_1_1d
        - entity_id: sensor.kuche_oben_2_1d
        - entity_id: sensor.bad_oben_3_1d
        - entity_id: sensor.kulock_4_1d
        - entity_id: sensor.hauslicht_oben_5_1d
        - entity_id: sensor.boden_6_1d
        - entity_id: sensor.waschhaus_7_1d
        - entity_id: sensor.heizung_therme_8_1d
        - entity_id: sensor.kuche_unten_9_1d
        - entity_id: sensor.stalllicht_10_1d
        - entity_id: sensor.keller1_11_1d
        - entity_id: sensor.keller2_12_1d
        - entity_id: sensor.keller3_13_1d
        - entity_id: sensor.herd1_14_1d
        - entity_id: sensor.herd2_15_1d
        - entity_id: sensor.herd3_16_1d
        - entity_id: sensor.emporia_123_1d
Ronald
Hi all
thx for this helpfull discussions here!
i’m searching for an approach to have a bar starting 0 in the middle.
Specifically, it’s about my electricity consumption from the grid. As I have a solar system, this can be positive (power supply - red) and negative (feed-in - green).Or the battery - charging/discharging…
Bar starting from zero in the centre.
thx
c.
Hi guys, it might be somewhere here in the thread but I am not able to find it :thinking:
Is it possible to change a bar color based on the state of sensor differs to the displayed one?
It is closely related to the @caro question. I would like to change bar’s color (current - sensor 1) if battery is charging/discharging (sensor 2)
tried
              style: |
                    bar-card-currentbar {
                      color:
                        {% if states('sensor.battery_current')| int(0)  > 0  %}
                          rgba(153, 31, 47, 0.5);
                        {% else %}
                          rgba(38, 92, 39, 0.5);
                        {% endif %}
But no way
Start with fixing the card-mod code in accordance to card-mod 3.4.0 requirements.
I am a bit confused,
card_mod documentation:
card_mod:
  style: |
    ha-card {
      --ha-card-background: teal;
      color: var(--primary-color);
and my try
card_mod:
  style: |
      color:
        {% else %}
         {% endif %}
I do not see any difference, well, in the format at least :face_with_raised_eyebrow:
What you posted here was w/o “card_mod” keyword.
As for style itself: a card-mod code must be written based on Code Inspector (not “taken from somewhere” etc).
I see, my negligence.
Anyhow, card_mod is installed and used.
Template itself works in dev tools.
So morelikely it is due to part of code between
style: | and first {% if and seems to be my weakest point :sweat:
This is a selector for the related bar:
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>layout-card$grid-layout$#root>hui-horizontal-stack-card:nth-child(10)$#root>bar-card$#states>bar-card-row:nth-child(3)>bar-card-card:nth-child(2)>bar-card-background>bar-card-currentbar"
Should be quite simple, look at this example:
entities:
  - entity: sensor.bedroom_temperature_humidity_battery
card_mod:
  style: |
    bar-card-currentbar, bar-card-backgroundbar {
      {% if states('sensor.office_temperature_humidity_battery') | int > 100 %}
        --bar-color: #0033ff !important;
      {% else %}
        --bar-color: black !important;
      {% endif %}
Thanks. I found the culprit (me) >> Wrong alignment :sweat_smile:
I have a card:
how to add a dotted line to a bar?
my card code
type: custom:stack-in-card
title: []
cards:
  - type: custom:bar-card
    entities:
      - entity: sensor.iphone_fill_battery_level
    align: split
    columns: 1
    height: 4px
    width: 70%
    animation:
      state: 'on'
      speed: 2
    attribute: null
    color: white
    decimal: 0
    direction: right
    positions:
      icon: 'off'
      indicator: inside
      minmax: 'off'
      value: inside
    unit_of_measurement: null
    max: 100
    min: 0
    severity:
      - color: '#abd25f'
        to: '20'
      - color: '#ffd646'
        to: '50'
      - color: '#bf9540'
        to: '80'
      - color: '#f79c56'
        to: '100'
    card_mod:
      style: |
        ha-card {
          --paper-item-icon-color: rgb(47,186,229);
          border-radius: 2.5px;
          border-width: 0px !important;
          background: none;
          border: none;
          height: 38px;
        ha-icon {
          margin-top: -40px;
          padding-right: 25px;
        bar-card-indicator {
          margin-top: -10px;
          padding-right: 0px;
        bar-card-name {
          margin-top: 0px;
          padding-left: 0px;
          margin-top: 12px;
          margin-top: 12px;
        bar-card-targetbar {
          margin-top: 12px;
        bar-card-animationbar {
          margin-top: 12px;
          padding-right: 0px;
        bar-card-targetmarker {
          margin-top: 40px;
        bar-card-value {
          margin-top: 0px;
          padding-left: 5px;
        bar-card-row {
          margin-bottom: 0px !important;
          margin-top: -10px !important;
          background: linear-gradient(to right, green 5%, orange 50%, red 75%);
          border-radius: 25px;
          background: linear-gradient(to right, green 5%, yellow 25%, orange 50%, red 75%);
          clip-path: polygon(0 0, var(--bar-percent) 0, var(--bar-percent) 100%, 0 100%);
        bar-card-contentbar {
          font-size: 14px; color: white;
        bar-card-value  {
card_mod:
  style: |
    ha-card {
      height: 30px;
      border: 0px;
      background: transparent;
If you are an experienced card-mod user - add a striped mask to the background.
Thank you!
everything worked out
  mask-image: repeating-linear-gradient( 90deg, transparent 0px, black 4px, transparent 0px, black 4px);
Is there a way to reference limits from an sensor (sensor.daily_min, sensor.daily_max, sensor.daily_target …), either there attribute or a sensor directly?
I was not able to get it working with template syntax or any other way.
Reason why i would love to see it, is that i am using it for PV purposes, and i have different min max and target values per day.
Furthermore same for grid import and export.
Bar 2 and 3 are with numeric values bar one is the one where I am again and again trying to use a specific sensor or a sensores attributes to be used as the numeric values
Thanks in advance
Hi. Have you sorted this out?
I am having issues with the decimal values.
bar card
Though I have set the decimals to 2:
    card:
      title: Excess Power
      positions:
        value: outside
        indicator: 'off'
        icon: 'off'
      max: 5
      severity:
        - color: '#ffff00'
          to: 0.99
        - color: '#0066ff'
          to: 2.49
        - color: '#00ff00'
          to: 100
        - color: '#ff0000'
          to: 0
      height: 30px
      style: "\n#states { padding: 0 } \nbar-card-name,\nbar-card-value {\n  \n  color: #ffffff;\n  }\nbar-card-value\t{\n  font-weight: bold;\n}\nbar-card-indicator {\n transform: scaleY(-1);\n}\n"
      stack: vertical
      direction: right
      decimals: 2
    entities: []
    sort:
      method: state
    filter:
      include:
        - entity_id: sensor.grid_export
      exclude:
        - state: unavailable
        - state: unknown
Thankyou
  1. I wonder why to show a simple issue you need to post a tons of unrelated things like auto-entities & wrong card-mod? Like “here is my code, now sort it out”.
  2. The right option is “decimal”.
  1. Wow, sorry for trying to provide context to the issue and question. I bet if i didnt add the whole code you would have complained I didnt include enough. Really sorry I included too much… :face_with_raised_eyebrow:
  2. Thankyou. This was all I needed and has fixed the issue.
Very funny. Keep on.
if you ask, me sorry no
Is there a way to get curved edges on the bars? I’ve gone through past comments explaining what needs to be changed and I can’t figure it out.
