sskom
(sskom)
February 2, 2025, 8:57am
1003
Is it possible to use dynamic (template) names?
- type: custom:bar-card
entities:
- entity: sensor.deye_sum_daily_production
color: "#ffa600"
- entity: sensor.solcast_pv_forecast_forecast_today
name: "{{ states('sensor.day_today') }}"
color: "#ffa600"
- entity: sensor.solcast_pv_forecast_forecast_tomorrow
name: "{{ states('sensor.day_tomorrow') }}"
color: "#d6bc8b"
- entity: sensor.solcast_pv_forecast_forecast_day_3
name: "{{ states('sensor.day_after_tomorrow') }}"
color: "#d6bc8b"
- entity: sensor.solcast_pv_forecast_forecast_day_4
name: "{{ states('sensor.day_4') }}"
color: "#d6bc8b"
- entity: sensor.solcast_pv_forecast_forecast_day_5
name: "{{ states('sensor.day_5') }}"
color: "#d6bc8b"
- entity: sensor.solcast_pv_forecast_forecast_day_6
name: "{{ states('sensor.day_6') }}"
color: "#d6bc8b"
- entity: sensor.solcast_pv_forecast_forecast_day_7
name: "{{ states('sensor.day_7') }}"
color: "#d6bc8b"
This syntax does not work… (
The card does not support templates.
In fact, very few cards do.
What is the syntax for the values in card mod if you have multiple entities?
Example
{% set entity = {
"state": states('counter.regenwater_filter') | int(9999999999),
"name": "Levensduur",
"unit": " d"
How can state and name become dynamic based on what is entered in the config itself?
arnocl
(Arnocl)
February 17, 2025, 8:30am
1006
I only made this to reflect the state of one entity. An embedded tile card design, as it is the standard for Home Assistant, would be nice here. My code certainly has its limitations, I see it as a dirty inbetween option, but it functions.
Card-mod is not supposed to replace config options, ie round state values.
I needed a template name also, but as I realised it is not possible, after reading this thread, I applied the a markdown card (which accepts template) on top of bar-card as follow:
type: vertical-stack
cards:
- type: markdown
content: >-
{{ states('sensor.ebusd_ctlv3_z1timer_monday2_htm') + " - " +
states('sensor.ebusd_ctlv3_z1timer_monday2_htm_1') }}
entities:
- entity: sensor.ebusd_ctlv3_z1timer_monday2_slottemp
width: 100%
positions:
direction: up
height: 150px
stack: horizontal
icon: mdi:temperature-celsius
min: 0
max: 30
the result looks like this:
…of course, no inside name possible.
Now I have another question. Would it be possible to use a template value in width option?
It would be nice for me to size the width of the column proportionally with the time period of the day
Thank you
The card does not support templates - nether for “name” nor for “width” .
But you may try card-mod supporting jinja.
Lewis_P
(Lewis)
March 2, 2025, 2:40pm
1011
Made good use of this card on my tablet, along with some card-mod stuff to refine the size/shape/padding/formatting etc:
KKlausl
(KKlausl)
March 10, 2025, 1:50pm
1012
I try to rebuild an amazon air quality sensor in home assistant, which is quite nicely built within the alexa app, but I am too noobish to accomplish that. I read all posts here and assume, that my css skills are to low.
here is my (raw) code (i do not post all my tries, since they may come closer to my goal, but are flawed, but I tried card-mod with style and padding, margin, allign-text):
entities:
- entity: sensor.wz_kohlendioxid
min: 0
max: 2000
- entity: sensor.first_air_quality_monitor_particulate_matter
min: 0
max: 300
- entity: sensor.first_air_quality_monitor_volatile_organic_compounds
min: 0
max: 100
- entity: sensor.first_air_quality_monitor_carbon_monoxide
min: 0
max: 50
positions:
icon: outside
value: outside
indicator: inside
height: 7
this is what it looks like, but I want it to be symmetrical (red lines), bars shoud start and end at the same position and should be in line with the text:
I would really appreciate your help! Thank you very much!
It is possible by card-mod. You will have to learn css.
KKlausl
(KKlausl)
March 11, 2025, 2:14pm
1014
Thank you for your reply! I am on my way to learn it, but maybe a css - star, like you, has a hint where to start… That would really be a help!
The hint I can give is a standard one: go to the main card-mod thread - 1st post - fantastic link at the bottom - bar-card, use it as a starting point.
KKlausl
(KKlausl)
March 12, 2025, 8:55pm
1016
Allready read that. Sorry, that was no help for me, infos about bar card are very small in your reference. I thought, the community is there for helping each other, but maybe its about „educating“ each other. I appreciate your efforts and I am nothing compared to you but if you want to teach us something, link to that: CSS Tutorial
There are many good tutorials in web, and the link you gave is my FIRST and FAVOURITE one.
Examples in the main card-mod thread are not covering 100% of possible cases, should be used as a starting point.
Note that bard-card Readme contains a list of DOM elements which can be used.
Zenia
(Yevgeniy)
March 13, 2025, 5:00pm
1018
is it possible to use text value for severity? I read almost all posts, but couldn’t find any answer. Try to uniform my auto-entity cards
type: custom:auto-entities
filter:
include:
- entity_id: sensor.nash_dom_air_quality*
state: hazardous
state: high
state: low
state: moderate
state: unhealthy
exclude: []
card:
columns: 1
height: 25
icon: mdi:molecule
#color: purple
title_position: inside
align: split
rounding: 0px
severity:
- value: 'moderate'
color: var(--bar-red)
- value: 'high'
color: var(--bar-yellow)
- value: 'good'
color: var(--bar-green)
grid_options:
columns: full
to match:
I create a template, but dont know where to use it
{%if states.sensor.nash_dom_air_quality_0d.state == 'good' %}green{% elif states.sensor.nash_dom_air_quality_0d.state == 'low' %}darkgreen{% elif states.sensor.nash_dom_air_quality_0d.state == 'moderate' %}gold{% elif states.sensor.nash_dom_air_quality_0d.state == 'high' %}orange{% elif states.sensor.nash_dom_air_quality_0d.state == 'unhealthy' %}red{% elif states.sensor.nash_dom_air_quality_0d.state == 'hazardous' %}violet{% endif %} !important;
Hanzie82
(Hanzie82)
March 15, 2025, 6:18pm
1019
I tried to make this bar card, but im trying to get some color into it but not succeeding.
Everything else works fine, targets are set correctly.
Just the colors arent working. I dont know why.
(And yes i even asked GPT for some help wioth the colors saved me some work).
Current look:
Current YAML:
min: 0
height: 25
positions:
indicator: "off"
icon: "off"
value: inside
animation:
state: "on"
speed: 3
entities:
- entity: sensor.p1_meter_3c39e72ca7d2_active_power
max: 10800
target: 3600
name: Total power Use
severity:
- value: 0
color: "#1b3a6f"
- value: 1200
color: "#1f5f3a"
- value: 3780
color: "#a55f1e"
- value: 6000
color: "#7a1e1e"
- entity: sensor.wasmachine_power
max: 3600
target: 2750
tap_action:
action: call-service
service: switch.toggle
entity_id: switch.wasmachine_socket_1
severity:
- value: 0
color: "#1b3a6f"
- value: 1000
color: "#1f5f3a"
- value: 2887
color: "#a55f1e"
- value: 3500
color: "#7a1e1e"
- entity: sensor.droger_power
max: 3600
target: 2750
tap_action:
entity_id: switch.droger_socket_1
severity:
- value: 0
color: "#1b3a6f"
- value: 1000
color: "#1f5f3a"
- value: 2887
color: "#a55f1e"
- value: 3500
color: "#7a1e1e"
- entity: sensor.tv_en_geluid_slaapkamer_power
name: TV en Geluid Slaapkamer
max: 40
target: 30
tap_action:
entity_id: switch.tv_en_geluid_slaapkamer_socket_1
severity:
- value: 0
color: "#1b3a6f"
- value: 10
color: "#1f5f3a"
- value: 31.5
color: "#a55f1e"
- value: 40
color: "#7a1e1e"
- entity: sensor.kledingkast_verlichting_power
name: Kledingkast Verlichting
max: 100
target: 75
tap_action:
service: light.toggle
entity_id: light.kledingkast_verlichting_socket_1
severity:
- value: 0
color: "#1b3a6f"
- value: 30
color: "#1f5f3a"
- value: 78.75
color: "#a55f1e"
- value: 100
color: "#7a1e1e"
What did i do wrong? Thanks in advance.
EDIT: i know now what i did wrong after another good read trough the documentation.
I blatently copied over the AI suplied YAML but it broke the severity syntax.
That need a “from” and “to” value.
Like this small example (from the earlier YAML):
severity:
- color: Blue
to: 900
- color: Green
to: 3780
- color: Red
to: 6000
- color: Purple
to: 10800
People are thoughtlessly writing a wrong code - then post it in Internet.
Chatgpt-like stuff uses this for learning.
People use these chatgpt-like stuff to get solutions - and get some BS - then post it in Internet.
And so on.
Keep on using chatgpt and post it here.
KKlausl
(KKlausl)
March 17, 2025, 7:36pm
1021
I finally managed to achieve what I was looking for - a segmented bar card, which is symetrical and horizontal and looks like this:
…with this code:
title: Air Quality Wohnzimmer
entities:
min: 200
max: 2000
icon: mdi:molecule-co2
target: 800
severity:
- color: Orange
to: 1500
- color: red
to: 2000
min: 0
max: 300
icon: mdi:blur
target: 100
severity:
- color: rgb(163,142,36)
to: 200
- color: rgb(214,82,34)
to: 300
min: 0
max: 100
icon: mdi:molecule
target: 33
severity:
to: 66
to: 100
min: 0
max: 50
target: 17
severity:
to: 34
to: 50
height: 7
width: 100%
decimal: 0
positions:
icon: outside
value: outside
indicator: inside
bar_style:
border-radius: 5px
margin-bottom: 3px
height: 15px
card_mod:
style: |
bar-card-name {
padding-right: 20px !important;
padding-left: 30px !important;
width: 100px !important;
text-align: left;
bar-card-value {
text-align: left;
width: 120px !important;
bar-card-backgroundbar {
border-radius: 5px;
padding-left: 0px;
background: rgb(24,77,97);
outline: rgb(150,150,150) solid 2px;
bar-card-indicator {
position: absolute;
left: 185px !important;
bar-card-markerbar {
background: rgb(34,87,107);
width: 65px !important;
outline: rgb(40,70,90) solid 3px;
bar-card-targetbar {
But there is one problem: when I “refresh” the website (F5) or the app (dragging down the view) the card-mod breaks somehow and the card looks the following:
that means, especially the padding/width does not function anymore. I tried to skip or add !important value, which does not change anything. When I close and reopen the website or app, everything looks normal again.
Is this a bug or is my code bad?
patmtp35
(fau)
March 18, 2025, 8:23am
1022
Continuing the discussion from Lovelace: Bar Card :
time ago i made some thing like that for my instant conso with autoentities and barcard . it’s perfectible but working like i want
filter:
include: null
template: >-
{% for state in states.sensor | selectattr('attributes.device_class', '==',
'power') | rejectattr('state','in',['unavailable','unknown','0','0.0']) %}
{%- if state.entity_id | regex_match("sensor.*(muti|power|prise|puissance|w_)", ignorecase=False)
and not state.entity_id | regex_match("sensor.*(power_ch|msun|prod*|cptlinky)", ignorecase=false)
'entity': state.entity_id,
'name': state.attributes.friendly_name|replace(" Puissance","") |replace("Detect","") |replace("Power","") |replace("W","") |replace("power","") |replace("Prises","") |replace("Prise","") |replace("zwave","" ) |replace("Disjoncteur","" ) |replace("Multi","" ),
{%- endif -%}
{%- endfor %}
sort:
method: state
numeric: true
reverse: true
show_empty: false
card:
title: Consos Instantanées
show-icon: true
align: split
columns: "2"
height: 38px
min: 0
direction: right
entity_row: false
stack: vertical
positions:
value: inside
icon: inside
indicator: outside
unit_of_measurement: W
max: 100
severity:
- color: cyan
to: "10"
icon: mdi:lightning-bolt
- color: green
to: "60"
- color: green
to: "250"
icon: mdi:lightning-bolt-outline
- color: orange
to: "251"
- color: red
to: "3500"
card_mod:
style: |
bar-card-currentbar, bar-card-current, bar-card-backgroundbar {
height: 5px !important;
margin-top: 30px;
ha-card {
background: none;
box-shadow: none;
border: none;
ha-icon{
color: white !important;
bar-card-iconbar {
margin-bottom: 10px;
animation:
state: "on"
speed: "2"
bobbasli
(Bobbasli)
March 25, 2025, 9:39am
1023
I would like to have the bar card 0-value centered. Then the sensor value is negative, it should extend to the left and when the value is positive it should extend to the right.
I tried setting this up with:
severity:
- color: Green
to: 0
- color: Amber
to: 3735
max: 3735
min: -3735
Unfortunately the bar keeps starting on the far left side, extending to the right (I do not use the direction setting!).
Anyone a solution how to get this working?
