Despite all the awesomeness that is Home Assistant, I have always found that scene functionality is a little over complicated from a GUI perspective, with no clean way of being able to save the current state of lights into a scene. I realize that something like this is in the works for the upcoming ‘Simple Mode’ (Simple Mode in Home Assistant 1.0 | Home Assistant Developer Docs), but thought I’d have a bash (no pun intended) at it anyway.
After lots of googling I found the excellent external tool ‘Scene Gen’ (https://www.home-assistant.io/docs/ecosystem/scenegen/) which can capture the state of any given set of lights and switches (I’m focusing on lights only for now) and output a scene.yaml file with those states for use later as a scene.
Here’s what I’ve created in Lovelace:
Under the hood:
Disclaimer: I’ve only been running HA for about 6 months, so am still learning. If anyone can make the below steps cleaner or more efficient, I’d much appreciate it!
- Get scenegen.py to work in hassio
So the first step is to clone the scenegen respository into your config folder. As we will be using the shell_script component, this was the only way I could get HA to be able to access the scenegen.py script as the component is pretty locked down and doesn’t seem to allow access to the host file system (I’m running hassio in docker). Being a python script, scenegen requires the import of some dependencies for it to work (requests and pyyaml), which it would appear are not available in hassio shell, which I found out by trying to run scenegen.py directly as a shell command using HA’s configurator addon (in the top right of the addon, click the gear icon then ‘execute shell command’) and I got errors saying something like ‘module not found: requests’.
To get around these errors, I just installed each missing module by typing the following into the execute shell command box:
For requests, “pip install requests”
For yaml, “pip install pyyaml”
Please note that from what I understand, these dependencies do not persist on host restarts of hassio, but at this stage we just want to ensure scenegen is running correctly so that doesn’t really matter. I seem to get around this with a bash script (details of this in later steps).
Execute shell command
Command executed: ./scenegen.py: 1
File "./scenegen.py", line 9, in <module>
import requests
ModuleNotFoundError: No module named 'requests'
Command executed: pip install requests: 0
Collecting requests
Downloading https://files.pythonhosted.org/packages/51/bd/23c926cd341ea6b7dd0b2a00aba99ae0f828be89d72b2190f27c11d4b7fb/requests-2.22.0-py2.py3-none-any.whl (57kB)
Collecting chardet<3.1.0,>=3.0.2 (from requests)
Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl (133kB)
Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 (from requests)
Downloading https://files.pythonhosted.org/packages/e0/da/55f51ea951e1b7c63a579c09dd7db825bb730ec1fe9c0180fc77bfb31448/urllib3-1.25.6-py2.py3-none-any.whl (125kB)
Collecting idna<2.9,>=2.5 (from requests)
Downloading https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl (58kB)
Collecting certifi>=2017.4.17 (from requests)
Downloading https://files.pythonhosted.org/packages/18/b0/8146a4f8dd402f60744fa380bc73ca47303cccf8b9190fd16a827281eac2/certifi-2019.9.11-py2.py3-none-any.whl (154kB)
Installing collected packages: chardet, urllib3, idna, certifi, requests
Successfully installed certifi-2019.9.11 chardet-3.0.4 idna-2.8 requests-2.22.0 urllib3-1.25.6
WARNING: You are using pip version 19.2.3, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
File "./scenegen.py", line 10, in <module>
import yaml
ModuleNotFoundError: No module named 'yaml'
Command executed: pip install pyyaml: 0
Collecting pyyaml
Downloading https://files.pythonhosted.org/packages/e3/e8/b3212641ee2718d556df0f23f78de8303f068fe29cdaa7a91018849582fe/PyYAML-5.1.2.tar.gz (265kB)
Building wheels for collected packages: pyyaml
Building wheel for pyyaml (setup.py): started
Building wheel for pyyaml (setup.py): finished with status 'done'
Created wheel for pyyaml: filename=PyYAML-5.1.2-cp37-cp37m-linux_x86_64.whl size=44103 sha256=17e6ffb42a929ea1a55a9b10bacd4e6395a8a98f86710b1994816b99b4c9e75b
Stored in directory: /root/.cache/pip/wheels/d9/45/dd/65f0b38450c47cf7e5312883deb97d065e030c5cca0a365030
Successfully built pyyaml
Installing collected packages: pyyaml
Successfully installed pyyaml-5.1.2
Command executed: ./scenegen.py: 2
usage: scenegen.py [-h] [-k KEY] [-s SCENENAME] [-m MAPFILE] [-f FILTER]
[-c {xy_color,rgb_color,color_name,color_temp}] [-t TYPES]
[--no-sslverify] [--cacerts CACERTS]
url
scenegen.py: error: the following arguments are required: url
As you can see from the final output above, scenegen.py is ready to be fed some arguments.
Scenegen has a lot of options, so I would advise reading up on how it works from its own docs. However for our purposes we just need to feed it the following arguments:
./scenegen.py https://someurl.ui.nabu.casa -k someLongLivedAccessToken -m somemapfile.cfg --scenename somescenename -f groupsToFilter >someSceneName.yaml
To break this down:
The first argument is simply the address to find your HA instance. I switched from Duckdns to NabuCasa for simplicity sake and of course to support the awesome HA project, however I don’t see why this wouldn’t work if you are using duckdns or even just your internal ip address (untested).
You need to create a token for scenegen to be allowed access to HA. Follow instructions here Authentication API | Home Assistant Developer Docs
-m somemapfile.cfg
You need to create a map.cfg file in the same folder where scenegen.py is located. This cfg will contain a list of your lights and their groups. See here for how to format the mapfile https://www.home-assistant.io/docs/ecosystem/scenegen/#maps-and-filters
-f grouptofilter
Following on from the mapfile, this allows you to select the specific light groups from the mapfile that you are interested in creating a scene out of.
somescenename.yaml
This is the final piece of the puzzle, and instructs scenegen to create a .yaml file with the states of all the entities that you are interested in.
So to fully test the functionality, using the ‘run shell command’ menu item, I ran the following:
./scenegen.py https://someurl.ui.nabu.casa -k someLongLivedAccessToken -m mapfile.cfg --scenename "bedroom warm" -f "Bedroom Lights" >"bedroom warm.yaml"
The result was the creation of ‘bedroom warm.yaml’ in my config directory:
- Create a bash script to run from lovelace provided arguments.
As I mentioned above (but please correct me if I’m wrong), the pythin dependencies get wiped when rebooting the hassio host, so simply creating a shell command with scenegen.py won’t cut it. Through lots of trial an error however I found that if you run it with python3 in a bash script called from shell_command, it seems to work. I have no idea why, but it does!
So I created a file in my config directory called ‘exportSceneGen.sh’ with the following:
#!/bin/bash
SCENENAME="$1"
ROOM="$2"
echo $SCENENAME >>exportSceneGen.log
echo $ROOM >>exportSceneGen.log
python3 "scenegen.py" https://[myHomeAssistantAddress].ui.nabu.casa -k [myLongLivedAccessToken] --scenename "$SCENENAME" -m map.cfg -f "$ROOM" >scenes/"$SCENENAME".yaml
You can of course omit the log output once everything is working.
We can now pass SCENENAME and ROOM into the scenegen.py script by simply running the command:
./exportSceneGen.sh "bedroom warm" "Bedroom Lights"
and a new file ‘bedroom warm.yaml’ is created in your /config/scenes directory. (To make HA pick up scenes in this directory you must use the !include command in your configuration.yaml as described here https://www.home-assistant.io/docs/ecosystem/scenegen/#advanced-usage)
- Create your HA entities to allow lovelaced based scene creation.
Create the following entities in your configuration.yaml (based on your own light groups of course):
input_select:
scenegen_room_select:
options:
- Bedroom Lights
- Bathroom Lights
- Wardrobe Lights
- Courtyard Lights
- Balcony Lights
- Living Room Lights
- Dining Room Lights
- Office Lights
- Kitchen Lights
- Garden Lights
name: Scene Gen Room Selector
initial: Office Lights
input_text:
scenegen_scene_name:
name: Scene Gen Scene Name
initial: newscenename
And finally define your shell_command:
shell_command:
scene_gen_save: 'bash "exportSceneGen.sh" "{{ scene_name }}" "{{ room }}"'
Last of all, we just need to create the script to tie this all together.
Sample of scripts.yaml
alias: Scenegen Save
sequence:
- data_template:
room: '{{ states("input_select.scenegen_room_select") }}'
scene_name: '{{ states("input_text.scenegen_scene_name") }}'
service: shell_command.scene_gen_save
- service: scene.reload
- data_template:
message: Scene name '{{ states("input_text.scenegen_scene_name") }}'
title: New Scene for '{{ states("input_select.scenegen_room_select") }}'
service: persistent_notification.create
All that’s left now is to add the above elements to lovelace as follows:
And that’s it. Bob’s your father’s uncle! Now you can set up your lights how you want, save them as a scene and they should become immediately available to home assistant.
If you’ve made it this far, congrats on following what I can only imagine is a very long winded approach to achieve GUI Scene simplicity. I only just finished creating this so I’m sure there’s more efficient ways to achieve the same thing. Would of course welcome any feedback, specifically with these ‘nice to have’ improvements
- Automatically build map.cfg file based on HA defined light groups. No idea how to achieve that
- Avoid having to hard code the long lived access token into the Shell Script. Ideally as this is designed to run on the same host as HA, it would be nice to remove the need for authentication entirely (but maintain security)
- Auto populate the input_select.scenegen_room_select with all light groups.
- Find a more efficient way to run scenegen.py without having to use any bash script.
Thanks for you time
