Most of the people are running HA on raspberry PIs, and running that on the backend through jinja2 is only going to increase the load instead of reducing it.
Your phone, iPad, tablet, computer where your browser is displayed they are all fast (and JS is super fast on all the devices). Your backend is slow unless you have a high end server and this is far from being the case for everyone.
Evaluating a template in the frontend is not taking time, what is taking time is all the JS around it (a template is what, 10 lines?), the whole code for button-card is 120kB !!
I’m not going to add jinja2 through the backend support to the card, but PRs are welcome
Feature requests on github is the way to go so that I can track that down. I’ll take some time to deliver them in the future but I have so much work right now it’s just not possible. I’m almost never at home and traveling all the time for work. Right now I’m in Austin, TX for example
Don’t worry, no hurries. I will open another feature request for it. Take your time, you have already put in so much time for us. I can hardly complain!
Guess this is what it’s all about, and I agree with your remarks on frontend vs backend. Still, although using js templates in customize is fast and trouble free as one could wish, using js in custom Lovelace cards can bog the system significantly. Can’t explain it, it simply does.
I wonder if you can explain what you say here: ‘what is taking time is all the JS around’
(must stress that on my new RPi4, this is much less obvious, and my Hue config stays online much of the time, which is something to hurray about. Before, even reloading Lovelace would make the Hue lights of unavailable signaling capacity issues on the system)
Using the states of backend jinja template sensor can relieve that, let alone make the configs of these Lovelace cards much simpler, which is a feat on its own.
Now this sounds like music to my ears. Though I am far from capable to create a PR as such, I would gladly offer my time and assistance in testing and aiding such a development.
Since it apparently is feasible, looking at ThomasLovens cards, why wouldn’t it be for the other cards I wonder.
This might depend on the technique used though. Using Customizing entities - Home Assistant isn’t the same as using the custom-ui js templates, which would be done in the frontend, or as people sometimes say, on the fly, in browser. Which is rather fast with modern day devices.
And, of course, its is not only icons we can customize…
might I ask you to hop over here, and see if you can help me out with some niftier nested JS templates then Ive been able to come up with…
apreciated if you would
You should share the decluttering-card that you use with this that gives this error. A logical thing to me would be that you have set the entity in your variables, but not set the entity_id. If you want them to be the same you won’t need a service-call. A tap_action toggle would do exactly that.
Edit: and @Mariusthvdb is correct, you seem to use the exact same icon in both the ‘on’ state and any other state. Again if you want them to be the same just put the icon instead of a template. So icon: mdi:power-socket-eu.
Ok, about the icon you’re right, it’s my fault.
About the decluttering-card (if with this you mean the original card without configuration template), it’s this:
The entity and the entity_id point to the same entity, but i think the entity: switch.ciabatta1 is not so necessary as the entity_id: switch.ciabatta1 in the toggle action.
if you don’t have a decluttering template, the code unposted will never work, and you should write a full button card config first to see what you want.
since you’re new to HA, you better start getting a more fundamental understanding of the inner workings, before using something as complex, and simply copying other configs, or parts of it. It wont work like that
Hmmm… i don’t have a decluttering template and the full button card config is what i posted in my last message. Or am i wrong? I have others configuration templates without the [[ ]] variables, so i tried to learn putting those variables but at the actual state i am wrong.
Is it possible to have a config template for that button-card without the [[ ]] variables?
Maybe i am not so clear, but i already coded some configuration templates and all are working as i expected.
Now i am having troubles as never did a config template with a toggle action and with an entity_id inside it. I have many button-card like that i posted, so i was thinking to create a config template to use with those card to avoid to repeat every code inside every card like i did with other card but without toggle actions… Hope to be more clear now about what i would like to have…
you don’t need that if using a switch and toggling that. See my post above. In fact, you dont even need to define the tap-action since toggle is default for entities in these domains
Ok, so for every similar card i must put the same in every card? Is there a way/option to create something inside button_card_templates to avoid to repeat the same in every card?
Yes, ok that’s what i wanted since the beginning of our conversation… Now i’ll study your config and make for my needed… thanks again for your support!
