Lovelace: Button card
Replace the entity portion with your switch id
This one is working. I can confirm using ā€œaction: seviceā€ cause disability to set the colors.
It solved for my switches, but I canā€™t trigger scenes without using action service call.
Solved by adding the entity (despite the action service call):
Ahh yes, thanks for the tip!
One benefit of having a separate label template is that the button colour status could be based on another entity. Using a Custom UI Tiles example:
- entity: input_boolean.window_is_open
  label_template: "return 'Windows: ' + entities['sensor.windows_open'].state;"
  icon_template: "if (state === 'on') return 'mdi:window-open'; else return 'mdi:window-closed'"
@kuuji Based on the above, could the Button Card state option be expanded to include another entity, e.g.
- type: "custom:button-card"
  entity: sensor.windows_open
  show_state: yes
  state:
    - entity_id: input_boolean.window_is_open
      value: 'on'
      color: rgb(5, 147, 255)
      value: 'off'
      color: rgb(189, 255, 5)
Following on from this, is there a way to alter the icon based upon the entity state? e.g.
Thanks!
A Lovelace version of Custom UI Tiles? Could you point me to where this is please?
Unsurprisingly, the Custom UI Tiles thread on here :slight_smile:
Hi simbesh
Can you please share your code to the switching fan speed?
Thanks.
Is there a way to use this with conditional cards? I know its possible to use conditional cards plus button card but i cant use button card plus button card like a conditional
The best thing i could do is this:
  - type: horizontal-stack
    cards:
    - type: conditional
      conditions:
      - entity: switch.mqtt_switch_light_1
        state: "off"
      card:
        cards:
          icon: mdi:sofa
          color: auto
          action: toggle
          default_color: rgb(255, 233, 155)
          color_type: card
          style:
          - font-size: 12px
          - font-weight: bold
          icon: mdi:sofa
          color: auto
          action: toggle
          color_type: card
          style:
          - font-size: 12px
          - font-weight: bold
    cards:
    - type: conditional
      conditions:
        state: "off"
      card:
        cards:
          icon: mdi:sofa
          color: auto
          action: toggle
          color_type: card
          style:
          - font-size: 12px
          - font-weight: bold
          icon: mdi:sofa
          color: auto
          action: toggle
          color_type: card
          style:
          - font-size: 12px
          - font-weight: bold
But i have to create a conditional for each line. Is this correct?
    entity: input_select.bedroom_fan
    icon: mdi:fan
    show_state: true
    action: service
    service:
      domain: input_select
      action: select_next
        entity_id: input_select.bedroom_fan
    color_type: card
    state:
      - value: 'low'
        color: rgb(252, 243, 207)
      - value: 'medium'
        color: rgb(247, 219, 110)
      - value: 'High'
        color: rgb(241, 196, 15)
      - value: 'off'
        color: var(--paper-card-background-color)
Yes would love this config option! would make the button useful for so much more!
First off - donā€™t get discouraged. Once I master the options, this is certain to be one of my most-used card types. But for right now, Iā€™ve got an issue.
I used the trick of lining up a couple blank cards on either side of the ā€œactionā€ card to make it smaller and neatly center the one I want.
However, I cannot get a color applied.
Hereā€™s my code:
          cards:
            color_type: blank-card
            color_type: card
            icon: mdi:speaker
            color: rgb(28, 128, 199)
            action: service
            entity: script.vizio_toggle
No matter what technique I find, I canā€™t get anything but a dull grey icon.
If I try to use color_type: icon, it crashes all of Lovelace with an ā€œUnexpected Error Occurred.ā€
Iā€™m running the latest code from your git repo. And I bumped the ?v=x parameter on the include.
The card in question calls a simple service to send a ā€œPowerToggleā€ command to my Vizio soundbar, which turns itself off after 10 minutes of silence. No fancy states or anything.
What do I have wrong?
You have to change the color type from card to icon (ā€œcolor_type: cardā€ >> color_type: icon")
Still no joy.
   color_type: icon          <--------
   icon: mdi:speaker
   action: service
I still get nothing but this ugly grey icon:
Screenshot_20181114_230438
Itā€™s kinda bugging me. I want/need to make a row of different-colored buttons for ease of use. But I canā€™t even color a single one!
Did you refresh your browser? Im asking this because everything is fine with your codeā€¦ I got a blue icon. Maybe you can also try the ā€œcolor_off:ā€
Refreshed the browser, tried different browsers, viewed it on my phoneā€¦
Does HA have its own cache somewhere?
color_off was the magic formula!
Thank you, thank you!
Perhaps, because itā€™s a toggle, itā€™s never ā€œonā€ or ā€œoffā€, but somewhere in between? I dunno. Hopefully the maintainer of this add-on will read this saga and sort it out.
BUT I HAVE A BLUE ICON!
Thanks again!
Did you work this out?
Iā€™m trying to make a button that toggles two automations, but Iā€™m struggling with the show_state.
Iā€™m guessing that I need some sort of boolean or something?? anyone got any ideas?
Here is my code:
    entity: script.wifi_away_toggle_mart
    icon: mdi:wifi
    action: toggle
    show_state: true
and this is the script:
wifi_away_toggle:
  sequence:
    - service: automation.toggle
      entity_id: automation.wifi_away_mart_day
      entity_id: automation.wifi_away_clare
I know this has been asked before but just curious if the long press function has been released yet?
Iā€™ve got a couple scripts i run with buttons that control my blinds. Basically, i have dual roller blinds and iā€™ve setup the following button cards.
As the open and close buttons control both blinds, i like to just open the block out blind on its own regularly, iā€™d love to be able to just hold down the open/close button and it would run a separate entity/script which would open my block out blinds only. That way i dont have to add extra buttons to run these scripts.
Keep up the good work :slight_smile:
Entitycard that is default in lovelace now has long press funcion if you need it :slight_smile:
