Lovelace: Button card
Nice work…
For anyone who, like me, wants to change the icon based on the state - I’ve managed to get this working by nesting this custom card inside of a conditional. Here is a sample of the settings.
      - type: conditional
        conditions:
          - entity: switch.kitchen_pendant
            state: on
        card:
          type: custom:button-card
          icon: mdi:toggle-switch
          action: toggle
          show_state: true
      - type: conditional
        conditions:
            state: off
        card:
          icon: mdi:toggle-switch-off-outline
          action: toggle
          show_state: true
Yes, this is a lot of work for an icon change but it’ll suffice for the time being. Hopefully we’ll see this button card receive the ability to switch mdi:icons with a simple state entry the same way button coloring is applied.
You could actually do this a couple of ways already. I did create this but then thought it was redundant since you can fetch the icon from the attributes. At least in my case since I was using a Cover template. So instead we added the attribute option for icon.
But if your switch is not a template switch you can create one from your current switch, https://www.home-assistant.io/components/switch.template/. Use templating to set the icon based on state. Ex.
icon_template: >-
          {% if is_state('cover.garage_door', 'open') %}
            mdi:garage-open
          {% else %}
            mdi:garage
          {% endif %}
Then use icon: attribute in your card config.
If this does not help let me know. I think I saved the code to add icon_on: and icon_off option instead.
Hi
If I use this code in the “UI-editor” for lovelace… It works, but it locks up the editor so I’m not able to edit it in UI or Raw mode anymore… can only delete the card…
Anyone else with this issue?
type: 'custom:button-card'
icon: mdi:sofa
action: service
service:
  domain: scene
  action: turn_on
    entity_id: scene.library_full
Can one call any service with this button card? Or only scripts?
I have the below in my ui-lovelace.yaml but no action is fired when pressing the button?
      - type: horizontal-stack
        cards:
          - type: "custom:button-card"
            color_type: label-card
            color: auto
            action: service
            service:
              domain: input_select
              action: select_option
                entity_id: input_select.home_mode
                option: Home
            color: rgb(44, 109, 214)
            action: service
            service:
                option: Away
Intact, no matter what action I chose, nothing works?
HA version 0.82.1
Same here, i cannot style card with picture-elements… @thomasloven told me i can style only the card excluding the elements, but i still cannot get it styled…
@tobben I’ve been getting the same issue using the following, so it’s not just you:
  entity: light.hallway
  icon: mdi:lightbulb-outline
  color: auto
  color_type: icon
  default_color: rgb(255, 255, 255)
  action: toggle
  style:
    - font-size: 12px
    - font-weight: bold
I’m on Home Assistant v0.84.1 running in a Docker Container on a Synology NAS if that is of any help.
Edit: Updated to HA 0.84.5 and issue still persists
I did this for my lock since toggle wouldn’t work and I wanted to be able to see if it was locked or unlocked on the front end (in both a horizontal and vertical stack):
      - type: conditional
        conditions:
          - entity: lock.schlage_deadbolt_47
            state: locked
        card:
          action: service
          service:
            domain: lock
            action: unlock
              entity_id: lock.schlage_deadbolt_47
          card_style: ''
          color: var(--primary-color)
          color_type: icon
          default_color: var(--primary-text-color)
          icon: mdi:lock
      - type: conditional
        conditions:
            state: unlocked
        card:
          action: service
          service:
            domain: lock
            action: lock
          card_style: ''
          color: var(--paper-item-icon-color)
          color_type: icon
          icon: mdi:lock-open-outline
Hope this helps anyone looking to do that.
All my buttons appear on the same row. How can i get a row for every three buttons (for example) ?
I allready tried changing size, but that did not help.
My code
        cards:
        #name: kamerlampen
          entity: input_boolean.kamerlampen
          icon: mdi:floor-lamp
          color: auto
          color_type: card
          default_color: rgb(255, 233, 155)
          action: toggle
        #name: kamerlampen
          entity: group.tuinlampen
          color: auto
          color_type: card
          action: toggle
          #name: kamerlampen
          entity: group.slaapkamer
          color: auto
          color_type: card
          action: toggle
          style:
            - font-size: 12px
            - font-weight: bold
          entity: switch.studeerkamer
          icon: mdi:lightbulb
          action: toggle
          style:
            - font-size: 12px
            - font-weight: bold
          entity: switch.boudoir
          icon: mdi:lightbulb
          action: toggle
          style:
            - font-size: 12px
            - font-weight: bold
Start a new horizontal-stack?
I tried a new horizontal stack. But when I don’t have three buttons left, the rest get a different size. (I know I could add one or two blanc buttons), but what is more important, the buttons are not grouped anymore.
When I see some examples of other users I assume there must be another possibility to achieve my goal.
One off my buttons is slighty larger than the rest only on a small view-port (mobile). Don’t know if this is a lovelace issue, or a custom card issue though:
Works on larger view-port just fine though:
cards:
  - type: vertical-stack
    cards:
        cards:
          - type: custom:button-card
            color_type: card
            entity: switch.staande_lamp
            action: toggle
            color: rgb(255, 131, 0)
            color_type: card
            entity: switch.eettafel_lamp
            action: toggle
            icon: mdi:ceiling-light
            color_type: card
            entity: switch.oude_lamp
            action: toggle
            icon: mdi:lightbulb
            color_type: card
            entity: switch.zithoek_lamp
            action: toggle
            icon: mdi:sofa
      - type: thermostat
        entity: climate.verwarming
        cards:
            color_type: card
            entity: switch.sonoff_1
            action: toggle
            icon: mdi:pine-tree
            color_type: card
            entity: light.tv_licht
            action: more_info
            icon: mdi:television
            color_type: card
            entity: light.boekenkast_licht
            action: more_info
            icon: mdi:book-open
            color_type: blank-card
Something like this? Is that what you want?
Vertical-stack, then horizontal-stack with three buttons, horizontal-stack with five buttons, etc. Last horizontal-stack has two blank-buttons (left and right).
this is awesome, could you share the code?
Thank you, this was indeed what I was searching for.
Sure, this is the code for my TV tab: https://pastebin.com/zH8Djv4v (too long to paste here unfortunately)
The buttons are conditional based on the Logitech Harmony activity that is active.
Hmm, I guess it has to do with the label being too long and not cut of. If I make the name shorter the button has the same height.
thanks a bunch, i had tiles button, but they were too clunky
@kuuji I successfully have implemented longpress functionality into this button-card. I went ahead created a PR for it: https://github.com/kuuji/button-card/pull/40
Anybody can help figuring this out?
I’m trying to configure a virtual remote for my Harmony home remote:
Trying to follow the instructions for this custom component, this is an example of one of the buttons:
        entity: remote.harmony_salon
        icon: mdi:volume-plus
        service:
          domain: remote
          action: send_command
            entity_id: remote.harmony_salon
            device: "60012590"
            command: "VolumeUp"
It doesn’t work; it turns off everything when I press it…
Using the default entity button works so I know it works:
      - type: entity-button
        tap_action:
          action: call-service
          service: remote.send_command
          service_data:
            device: "60012590"
            command: "VolumeUp"
So what did I do wrong, how can I do the same as above using this custom component?
In the example there is no argument so I’m unsure how to apply mines (or even if it’s possible)
  color_type: card
  color: rgb(223, 255, 97)
  action: service
  service:
    domain: media_player
    action: volume_up
      entity_id: media_player.livimg_room_speaker
Anybody configured an Harmony remote using this component who could give me a hint?
Thanks in advance!
