Lovelace: Button card
Just a quicky, is it possible to specify different actions (eg tap_action) for custom_fields?
In an effort to minimise custom cards and to keep maximum control over my designs, I have basically recreated the multiple-entity-row card using button-card, so have 2 different entities show in one button-card, and I would like to show the relevant more-info for each entity ?
If an entity name is too long for the button, is it possible to break the text in a new line?
I tried css attributes overflow-wrap, line-break and word-break but nothing worked.
Hm, I actually had this problem too. What I currently do now is put the first line in name and the second line in label. This way it does do a bit what you want, though you won’t be able to use the same label for something else this way.
Try this:
if (states['switch.fibaro_system_fgwpef_wall_plug_gen5_switch'].state
            =='on') return 'green'; return 'grey';
Yes it is possible if the embedded card supports tap_action or whatever else
Should be possible, try with those styles:
- white-space: initial
- text-overflow: initial
- overflow: initial
This works very nice! Thank you.
Check this post @jimz011: Lovelace: Button card
Hello. Did you find any solution for dynamic color change?
It’s [[[...]]] for templates, not ${...} @Jay_Heavner
Could anyone give me some guidance on how to add custom button card in a conditional card?
The custom button card should be reflected in the listed entities based on the selection.
title: Room Selection/Schedule
type: vertical-stack
cards:
  - entities:
      - entity: input_select.rooms
      - entity: sun.sun
    show_header_toggle: false
    type: entities
  - card:
      entities:
        - switch.bedroom1
        - switch.bedroom2
        - switch.bedroom3
        - switch.bedroom6
        - switch.bedroom7
        - input_select.bedroom
      type: entities
    conditions:
        state: Bedroom
    type: conditional
This should work:
cards:
  - entities:
      - entity: sun.sun
    type: entities
  - card:
      entities:
        - type: custom:hui-vertical-stack-card
          cards:
            - type: custom:button-card
              entity: switch.bedroom1
              entity: switch.bedroom2
              entity: switch.bedroom3
      type: entities
    conditions:
        state: Bedroom
    type: conditional
Thanks sti0
Much appreciated. Does work like a charm.
Thanks for the assistance
I have one more question:
If I want to have the horizontal stack duplicated.
I can add additional horizontal stacks but it adds is into the same frame of the first stack Meaning it just adds more buttons below the first row.
I want a second custom card so I can kind of separate the two custom cards by their frame.
  - card:
      entities:
        - type: 'custom:hui-horizontal-stack-card'
          cards:
            - type: 'custom:button-card'
      type: entities
cards:
  - entities:
      - entity: sun.sun
    type: entities
  - card:
      entities:
          cards:
      type: entities
    conditions:
        state: Bedroom
    type: conditional
example
Sorry I’m not sure what you like to achieve. You can add a vertical stack and wrap the horizontal stacks within. If this is not what you want to do please describe more precise.
cards:
  - entities:
      - entity: sun.sun
    type: entities
  - card:
      entities:
          cards:
            - type: horizontal-stack
              cards:
              cards:
      type: entities
    conditions:
        state: Bedroom
    type: conditional
i can do this:
example1
but trying to achieve this:
example
Ok. Just do this:
cards:
  - entities:
      - entity: sun.sun
    type: entities
  - card:
      entities:
          cards:
      type: entities
    conditions:
        state: Bedroom
    type: conditional
  - card:
      entities:
          cards:
      type: entities
    conditions:
        state: Bedroom
    type: conditional
Tried that but the gives the same result without the gap/ new frame
Please try the updated version. I changed it after I posted the solution you mentioned lately.
What you did is different from what @sti0 showed you. He proposed 2 conditional cards, 1 for each line, you have only one :wink:
Thanks sti0 for the help.
I see where i went wrong. I duplicated everything except for:
    conditions:
        state: Bedroom
    type: conditional
My thinking was that the conditional section would apply to both cards. I see the logic now it is basically another conditional card.
Thanks for your help. You guys rock.
Ah there is no embedded card, just me displaying a state in a custom field. I think I may have a solution, tap for one, and double tap or hold for the other - will give it a whirl later.
