Is there a way to make it so that when button is pressed it makes a color to illustrate that its being press down.
I find that this could be usefull for some switches were i have Harmony activity switches and whant to show that ive acualy pressed the button so i know the activity is about to start before i klick again.
This is just one example of many were i have buttons that has a script on them that makes allot of stuff were it take abitt of time before it turns on and then gets a color.
I could not find a answer to this when i search so hope any of you might have a answer.
Only way to do this at the moment is by adding a delay to the script. This will give the script a momentary âonâ state which will make the button light up.
Otherwise this is something that @RomRider has not found a solution to yet.
recent_movie:
show_entity_picture: true
show_name: false
aspect_ratio: 1/1.3937
var index = variables.index - 1;
var data = entity.attributes.result.movies;
var title = data[index].title;
variables.movieid = data[index].movieid;
return title;
entity_picture: >
var image = data[index].art.poster;
image = image.replace("image://","");
return decodeURIComponent(image);
This creates a card to a list of movies, according to the âvariables.indexâ I return a movie image from a array.
But I would like to store on the template a extra field, movieid, to later use calling a mqtt service I tried in the template:
variables:
movieid: >
var movieid = data[index].movieid;
return movieid;
But this does not seems to work.
How can I store this on a variable and later use it to call the mqtt service on tap action?
I declare a new variable with the name index with the value 1.
With that I can use it to access a sensor that contains a JSON object
recent_movie:
show_name: false
return title;
entity_picture: >
This displays a image.
Works great.
What I what now is to click that image and call the MQTT service with the movie ID. But for that I need to extract it from the JSON sensor with the index. My question was, can I, in the template, with the Javascript declare a variable to use later in the click action. Somting like " variables.movieid = data[index].movieid" (this does not seems to work).
I may have misunderstood but I believe this is what youâre asking for if not sorry Try this if you have card-mod installed, play with the transition as you see fit.
Man your my hero, I just tested it in my enviroment ant it worked flawless. exakly as me and my wife want it. And you know, Happy wife happy life Im getting a good night tonight
not sure, but I canât get it to work. Would it be the already set styles on the button_card_template prevent this transitional style to do its job maybe? (note a button with only this set or styling does work, so its not the styling perse, its about the combination)
I am trying to use a custom card as a custom field, but I am getting a js error in chrome Uncaught (in promise) DOMException: Failed to execute 'whenDefined' on 'CustomElementRegistry': "custom:circle-sensor-card" is not a valid custom element name
The circle sensor card shows up in the button so it works as expected, but the Console is filled with these errors.
Anyone has any idea if there is a problem with custom cards inside custom_field?
