Lovelace: Button card
I don’t have time to strip it out of my config and post it, but you’re welcome to dig into it yourself.
search my github ui-lovelace.yaml file for BASEMENT LIGHTS and take a look at the code. It uses anchors so you’ll have to walk backwards and find each anchors definition. Anchors start with a <<: *anchor_name. Just search upwards the anchor_name
Thanks @petro for the link to your .yaml file.
any tip why glow effect disappears when i go between pages?
I need help to get “show last changed” in “off” state. Only in On state right now.
Thanks,
  button_slider: &button_slider
    type: custom:button-card
    label: >
        var bri = Math.round(entity.attributes.brightness / 2.55);
        return (bri ? bri : '0') + '%';
    color: auto-no-temperature
    aspect_ratio: 1/1
    show_last_changed: true
  #  show_state: true
  #  show_label: true
    tap_action:
      action: toggle
      haptic: light
    hold_action:
      action: more-info
      haptic: success
    styles:
      state_label:
        - font-size: 11px
        - font-family: Helvetica
        - justify-self: start
        - text-transform: capitalize
        - font-weight: bold
      card:
        - border-radius: 15px
        - background-color: 'var(--paper-card-background-color)'
        - padding-left: 5px
      name:
        - font-weight: bold
        - font-size: 13px
        - text-overflow: unset
        - white-space: unset
        - word-break: break-word
        - text-align: start
      label:
        - font-size: 11px
        - text-align: start
        - padding-right: 45px # push to the state column
      state:
        - font-size: 11px
        - font-weight: bold
      grid:
        - grid-template-areas: '"i" "n" "stateDisplay" "l"' #'"i" "slider" "n" "stateDisplay" "l"' #'"i" "n" "stateDisplay"' # '"i" "slider" "n" "stateDisplay"' #'"i" "n" "s" "l"'
        # - grid-template-areas: '"i" "n" "stateDisplay" "l"' #'"i" "slider" "n" "stateDisplay" "l"' #'"i" "n" "stateDisplay"' # '"i" "slider" "n" "stateDisplay"' #'"i" "n" "s" "l"'
        - grid-template-columns: 1fr
        - grid-template-rows: 1fr min-content min-content
        # - grid-row-gap: 5px
      img_cell:
        - justify-content: start
        - align-items: start
      custom_fields:
        slider:
          - filter: opacity(80%)
          - color: rgb(240, 194, 9)
          - padding-left: 0px
    state:
      - value: 'on'
        custom_fields:
          stateDisplay: >
            [[[  var fakestate = `<span style="color: #F0C209;"> ${entity.state}:</span>`;
                var fakelabel = `<span style="color: #F0C209;"> ${Math.round(entity.attributes.brightness / 2.55)} %</span>`;
                return fakestate +' ' + fakelabel;]]]
        styles:
          card:
            # - color: white #'#F0C209'
            # - --paper-card-background-color: rgba(40, 40, 40)
            - box-shadow: 0px 0px 10px 3px var(--button-card-light-color)
          custom_fields:
            stateDisplay:
              - font-size: 11px
              - font-weight: bold
      - value: 'off'
        custom_fields:
          stateDisplay: >
            [[[ return entity.state ]]]
        styles:
          label:
            - color: rgba(0, 0, 0, 0.0)
          icon:
            - color: grey
          name:
            - color: grey
          state:
            - color: grey
          custom_fields:
            stateDisplay:
              - font-size: 11px
              - font-weight: bold
              - color: grey
      - value: 'unavailable'
        custom_fields:
          stateDisplay: >
        styles:
          card:
            - opacity: 0.8
            - color: '#D3D3D3'
          icon:
            - color: '#D3D3D3'
          label:
          custom_fields:
            stateDisplay:
              - font-size: 11px
              - font-weight: bold
              - color: '#D3D3D3'
light
Mind sharing your code for the buttons at the top please?
You smoking something? It’s in his post…
@cyberumb15
Change your style for value: ‘off’'s label from:
          label:
to
          label:
            - color: grey
show_last_changed appears in your label field. When you give it an RGBA of 0.0 (r), 0.0 (g), 0.0 (b), 0.0 (a) you’re telling it to make it transparent. R = red, G = green, B = blue, A = alpha. 100% alpha = you can see it. 0.0% alpha = you can’t see it.
Got it, really appreciate your explanation.
the code should be in anchors, then in your card
  - title: Light
    icon: mdi:lightbulb-outline
    panel: false
    path: light
    cards:
      - type: vertical-stack
        cards:
          - type: horizontal-stack
            cards:
              - <<: *button_slider
                entity: light.kitchen
                entity: light.dining_room
                entity: light.bathroom_2
                entity: light.basement
found the fix which needs adding items to value: ‘closed’, ‘closing’ and ‘open’, ‘opening’ beside ‘on’ and ‘off’
do you know why light switch and cover did not work?
Thanks,
Capture
    state:
      - value: 'on'
        icon: >
            if (entity.attributes.device_class == 'light')
              return 'mdi:lightbulb';
            if (entity.attributes.device_class == 'switch')
            if (entity.attributes.device_class == 'motion')
              return 'mdi:run';
            if (entity.attributes.device_class == 'door')
              return 'mdi:door-open';
            if (entity.attributes.device_class == 'window')
              return 'mdi:window-open';
            if (entity.attributes.device_class == 'cover')
              return 'mdi:garage-open-variant';
      - value: 'off'
        icon: >
              return 'mdi:lightbulb-outline';
              return 'mdi:walk';
              return 'mdi:door-closed';
              return 'mdi:window-closed';
              return 'mdi:garage-variant';
Can’t anyone help me with my config please?
This config results in nothing displayed correctly…
Note ‘bedside lamp’ at the bottom, there should be 2 cards…
        cards:
          - type: light
            entity: light.lounge_light
          - type: light
            entity: light.lounge_lamp
          - type: light
            entity: light.bridge
          - type: light
            entity: light.kitchen_cupboard_lights
        cards:
          - type: light
            entity: light.landing_light
            name: Top Landing Light
          - type: light
            entity: light.bottom_landing_light
            name: Bottom Landing Light
        cards:
          - type: custom:button-card
            color: auto
            icon: mdi:lamp
            label: >
                return states['light.landing_light''].state;
            show_label: true
            hold_action:
              action: more-info
            styles:
              card:
                - height: auto
            entity: switch.bedside_lamp_relay
            color: auto
            icon: mdi:lamp
            label: >
                return states['switch.bedside_lamp_relay'].state;
            show_label: false
            hold_action:
              action: more-info
            styles:
              card:
                - height: auto
What’s not working about it?
Only difference I see between the hidden one and the visible one is that the hidden one has ‘show_label’: false.
No, that hasn’t help :man_shrugging:
you sure that light.landing_light is correct?
Yep. You’ll have to excuse my naming logic…
garage
I got it working, the garage icon did not display garage door icon because value should have ‘closed’, ‘closing’ and ‘open’, ‘opening’ so I add those conditions to value.
You must have a fancy garage door. I have a binary_sensor and it would have worked in your card if you added device_class: garage
Just as a test I pasted the stack into a separate view and still see the problem
Paste the single card that’s not visible outside the vertical stack. See if that works. Most likely it doesn’t It’s probably your label template.
Actually, i see the problem now.
            label: >
                                               Extra Quote, remove
Good spot. Knew it would be something daft!
Now the buttons are very small though…no icon being shown?
It’s just wifi liftmaster garage door opener.
I did change device_class: garage, thanks.
