Cool. Can you share your code?
I plan on publishing my config to github once I get a little more added to it.
The person buttons at the top do not refer to presence, but used to notify the specific user when the washer/dryer has finished. I work irregular hours and would prefer to not cast/notify all devices if someone else is doing laundry.
as for the time, its a run time, showing how long the washer/dryer has run on the last cycle.
I will adjust the wording??
Thanks for your input!
Card:
type: custom:hui-entities-card
title: Laundry
entities:
- type: custom:hui-horizontal-stack-card
cards:
- type: 'custom:decluttering-card'
template: button_laundry_notify
variables:
- name: 'Nathan'
variables:
- name: 'Sarah'
variables:
- name: 'Mom/Dad'
variables:
- name: 'Hayley'
cards:
- type: 'custom:button-card'
entity: sensor.washing_machine_status
icon: mdi:tumble-dryer
- type: custom:mini-graph-card
icon: mdi:washing-machine
hours_to_show: 48
font_size: 70
points_per_hour: 20
line_width: 2
show:
points: false
extrema: true
entities:
- sensor.washing_machine_power
- sensor.dryer_power
template:
button_laundry:
template: default_button_settings
aspect_ratio: 2/1
tap_action:
action: none
styles:
grid:
- grid-template-areas: '"i i" "n n" "s door" "l timer"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 1fr min-content min-content min-content
custom_fields:
door:
- align-self: end
- font-size: 11px
- font-family: Helvetica
- justify-self: end
- font-weight: bold
timer:
- align-self: end
- font-size: 11px
- justify-self: end
custom_fields:
door: >
var id = entity.entity_id.split('.')[1];
var door = (states['binary_sensor.door_' + id].state);
var door_state = door == 'on' ? 'Open' : 'Closed';
return `<span>Door: ${door_state}</span>`
timer: >
var timer = (states['sensor.timer_' + id].state);
return `<span>Time: ${timer}</span>`
state:
- value: 'Running'
styles:
card:
- color: orange
- value: 'Finishing'
styles:
card:
- color: yellow
- value: 'Clean'
styles:
card:
- color: green
@RomRider I was playing around with my remote activity buttons a little more today. What I think is happening now, is that after performing the tap_action, the javascript objects are not being refreshed. Was that the bug you were mentioning before? Iāve been debugging via logging to the console and after switching activity, the hass, states, and entity objects donāt change based on the state changing.
So what I thought was the javascript templates in the config template being evaluated and put in as static values, I think was incorrect. It was just really that itās not picking up the state changes.
Here is a zip file with a simple test case, basically just a small portion of my remote. You should be able to just change the harmony hub name and the activities to test it out.
Anyone using this in a horizontal-stack with swiper card? I have tried it in the past but I have issues with touch being too sensitive.
The cards work fine (have them setup in a horiontal-stack), but when swiping to the next set of button cards in a horizontal-stack, I have to start the swipe motion by dragging a button card. It then either registers it as a tap_action or hold_action (depends on how slow I drag). Is there a way I can fix this by either doing something to button card or swiper card? I asked in the swiper card topic but unfortunately no succes, so figured try it here too.
This behaviour is om iOS and Android btw. On desktop with a mouse it seems to work fine.
@RomRider, could you tell me how the card knows when to refresh itself?
Iām asking because I wanted to create a card that shows states of 2 sensors and I couldnāt find in the docs anything that answers my question so I wasnāt sure it will update itself when state of each sensors changes.
I ended up creating a card with no entity and a name that is a template like this (this one uses only one sensor but the idea is the same across the board)
let primary_obj = states[variables.primary_entity];
let unknown = '?'
if (primary_obj == null || primary_obj.state === null || variables.invalid_states.includes(primary_obj.state)) return unknown;
return primary_obj.state + ' ' + primary_obj.attributes.unit_of_measurement;
and it seems to be updated well.
So my question is - what rules do we need to follow (if any) to make sure out cards are updated when data its field are based upon is changed?
Cheers
If there is a template defined ([[[...]]]), it will update anytime any entity is updated even without the entity field defined.
If there is only an entity defined, it will update only if this entity is updated.
Thanks for confirming.
Is HA or your card evaluates templates?
If itās HA, things like
{% set entity = 'sensor.test' %}
{{ return states(entity) }}
wonāt trigger update if the template as HA fails to detect entity to listen to.
(I know this card uses JS templates but I just used Jinja to show you what I mean.)
If itās your card that is in charge of evaluating templates, I take it there is no requirements to follow to get them updated.
The card computes everything in frontend, not HA. For every card in lovelace, an update is requested when the hass object is assigned (it contains all the states, so as soon as any state is updated, it should be reassigned to each card). When that variable is assigned, I check if the button needs an update or not based on the rule above (Lovelace: Button card)
But if HA does not assign the hass object, the card will not be updated and this is out of my control.
Thanks for the great explanation!
Actually, after reading the rule for the second time I realised that in case when there is no entity specified, the card will be updated every time any HA entity changes its state (or an attribute).
It sounds a bit overkill so maybe you could add a config variable like entities that will hold all entities that can trigger update of the card so we would dramatically reduce the number of required updates?
If it sounds ok, Iāll create a FR and add more details to it there.
I thought about this a while ago but youād need to list all the entities in your templates and cards in custom fields (and I know some people have a lot
). Also I didnāt want to handle questions like āwhy is my card not updating?ā as this would be an advanced feature and I donāt plan to do auto discovery at all
However, technically itās quite easy to add.
Cool! Iāll try create a very good PR proposing an approach that addresses/takes into account all of your concerns
Donāt bother with the PR, Iāll handle it later today or tomorrow
(Iāve got a bunch of bugfix already on their way and a lot of modifications in the way I build the card also on its way so not a great time to do a PR)
I meant FR ⦠
That would be great
Hmm, interesting. If I have a button-card that has no entity defined, and it has a custom field that is a vertical-stack that contains several horizontal-stacks each of which has several button-cards, would each of those button-cards follow the same principles on getting updated? In other words are they completely independent from any enclosing button-card that might house them?
And does HA see those āsub-cardsā as independent cards meaning that it also attempts to reassign the hass object to them upon a state change?
I canāt imagine why and how to make them dependent tbh. They shouldnāt be.
well, imho HA has nothing to do with the cards in general, all that happens is hass object changes when anything in HA changes and all cards get an updated hass.
thatās how it works. and then
The reason I was asking is because I was commenting in an earlier post that Iām seeing a case where it doesnāt appear the hass object is being updated, even upon a state change if I have an entity defined, or even if I have no entity defined. The card in question is buried in
button-card->custom_field->vertical-stack->horizontal-stack->button-card
well, you need to tell that. and even if your observation is right,
have you tried ādiggingā your card out to see if it makes any difference?
I mean, you can leave the weird one where it is and create an identical one at say, top level and compare their behaviour if you suspect it has something to do with nesting.
Each cards assign hass to each direct child element. So in button-card->custom_field->vertical-stack->horizontal-stack-> button-card:
button-card1assigns hass tovertical-stack -
vertical-stackis responsible for assigning hass tohorizontal-stack -
horizontal-stackis responsible for assigning hass tobutton-card2
