Lovelace: Button card
What’s the progress bar called in css? The % around your brightness.
Edit: can you also post how you got the shadow on the icon itself?
That a piece of svg I’ve copied over from @Mattias_Persson.
Here’s the code:
  custom_fields:
    info: >
        if (entity.state === 'on' && entity.attributes.brightness) {
          const radius = 20.5;
          const brightness = Math.round(entity.attributes.brightness / 2.54);
          const circumference = radius * 2 * Math.PI;
          return `
            <svg viewBox="0 0 50 50">
              <circle style="
                  transform: rotate(-90deg);
                  transform-origin: 50% 50%;
                  stroke-dasharray: ${circumference};
                  stroke-dashoffset: ${circumference - brightness / 100 * circumference};
                id="c_brightness" cx="25" cy="25" r="20.5" stroke="var(--sq-info-color)" stroke-width="1.5" fill="none" />
              <text x="50%" y="54%" fill="var(--sq-info-color)" font-size="14" text-anchor="middle" alignment-baseline="middle">${brightness}<tspan font-size="10">%</tspan>
              </text>
            </svg>
Edit: Adding the shadow for the icon is quite simple:
  state:
    - id: id_on
      styles:
        icon:
          - filter: |
                if (entity.attributes.supported_features >> 4 & 1) return "drop-shadow(0px 0px 1px rgba(0,0,0,1))";
I tried every attribute on an icon in the past accept filter. Well now I know, thanks.
Instead of ... when the text is overflowing the card, what I did lately is a nice fade effect:
using this css:
      - background-image: linear-gradient(to right, var(--paper-item-icon-color) 0%, var(--paper-item-icon-color) 80%, rgba(0,0,0,0))
      - -webkit-background-clip: text
      - -webkit-text-fill-color: transparent
      - position: relative
      - display: inline-block
      - width: 100%
      - align-content: start
      - text-align: start
      - text-overflow: unset
Awesome. How did you get that Sonos popup???
It is 4 button cards to select the master, then a state-switch with mini-media-player to display the Sonos grouping list, then 4 mini-media-player for the volume bars
i dont understand how its in a pop up, would you mind sharing the code?
the browser_mod part i suspect…
Yes, it’s with browser_mod:
action: call-service
service: browser_mod.popup
service_data:
  title: Sonos Groups
  deviceID:
    - this
  style:
    border-radius: 10px
    overflow: hidden
    background: var(--lovelace-background, var(--primary-background-color))
  card:
    type: custom:decluttering-card
    template: square_sonos_group_manage #which is a vertical-stack with everything inside
And then the decluttering-template:
square_sonos_group_manage:
  variables:
    - sonos_master:
  card:
    type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
          - type: custom:button-card
            template: square_mini_media_player
            entity: media_player.sonos_universal
            variables:
              default_background: /local/sonos_connect_big.png
              sonos_master: media_player.sonos_connect
            entity: media_player.sonos_office_stereo
            variables:
              default_background: /local/sonos_one_big.png
            entity: media_player.sonos_bedroom_stereo
            variables:
              sonos_master: media_player.sonos_bedroom_stereo
            entity: media_player.sonos_bathroom
            variables:
      - type: entities
        style: |
          ha-card {
            --mini-media-player-base-color: var(--paper-item-icon-color);
        entities:
          - type: custom:mini-media-player
            style:
                :host {
                  --mmp-text-color: var(--paper-item-icon-color);
                  --mini-media-player-accent-color: var(--paper-item-icon-active-color)
              ha-card: |
                  .entity__info__name {
                    font-weight: bold !important;
                    text-transform: lowercase;
                  .entity__info__media {
                    color: var(--paper-item-icon-color) !important;
            entity: '[[sonos_master]]'
            group: true
            hide:
              power: true
              icon: true
              source: true
              volume: true
              progress: true
            speaker_group:
              platform: sonos
              show_group_count: true
              expanded: true
              entities:
                - entity_id: media_player.sonos_connect
                - entity_id: media_player.sonos_office_stereo
                - entity_id: media_player.sonos_bedroom_stereo
                - entity_id: media_player.sonos_bathroom
          - type: divider
            style:
            group: true
            hide:
              controls: true
              progress: true
              info: true
              icon: true
              source: true
            group: true
            hide:
              controls: true
              progress: true
              info: true
              icon: true
              source: true
            group: true
            hide:
              controls: true
              progress: true
              info: true
              icon: true
              source: true
            group: true
            hide:
              controls: true
              progress: true
              info: true
              icon: true
              source: true
for some reason I cannot get the circle to render. svg viewbox is causing the problem. Not sure what. What version of your card are you using? I’m on 3.2.3.
EDIT: Everything seems to be calculating properly. No errors in logs and the html looks correct. Chrome is just not rendering it.
        <circle style="
            stroke-dasharray: 128.8052987971815;
            stroke-dashoffset: 63.114596410618944;
          id="c_brightness" cx="25" cy="25" r="20.5" stroke="var(--paper-item-icon-active-color)" stroke-width="1.5" fill="none" />
        <text x="50%" y="54%" fill="var(--paper-item-icon-active-color)" font-size="14" text-anchor="middle" alignment-baseline="middle">51<tspan font-size="10">%</tspan>
        </text>
      </svg>
it’s probably rendered but either hidden somewhere because of the styles you apply on the field or because its z-index is not correct and it’s under something else.
If you go in the chrome debugger and unfold the button-card, the element should be there, you’ll see on the page where it is and then you can play with the styles on the div around it.
PS: I’m running 3.3.0-3 (beta), but it shouldn’t change anything for this.
Yeah I’m doing that. I see it. I can’t tell the z order, I would expect a custom field to be on top no?
what are you using for the custom_field style?
It depends on the style of everything else :slight_smile:, my field is info (the circle):
  styles:
    grid:
      - grid-template-areas: '"i info" "n n" "s s" "l l"'
      - grid-template-columns: 1fr 35%
      - grid-template-rows: 1fr min-content min-content min-content
    custom_fields:
      info:
        - align-self: start
        - opacity: 0.5
I’ll try placing it in the grid… I"m using:
    - position: absolute
    - top: 50%
    - right: 50%
Interesting, placing it in the grid works. Might be an issue there? Or how Can i change the Z order with position absolute?
It should also be interesting to note that it doesn’t display if you place it in label field.
svg will scale with its parent container. if you set its position to absolute, you also have to set width and height on the parent container.
ah ok always something to learn. When you refer to the container, you mean that I’ll be placing this in the custom field style, correct?
Yes :slight_smile:
yep, now it works. TIL. It’s odd that it was properly sized but not visible.
container was zero size but objects not? In a normal UI they’d show up in the upper left corner.
That’s as far as I can help you with CSS. It always f***s my brain.
