Can you please give me an example with 3 buttons that are separated ?
I do not understand how to use card-mod based on the examples that I can find.
Thanks !
So hereās a little hack for those who want to have feedback on tap (works for hold and double_tap) (cc: @petro). However, it doesnāt work well if the entity of the card is updated before the animation is finished
tap_action:
action: call-service
always_execute: | # The key can be anything, but not a official documentation value
this.shadowRoot.getElementById('card').style.background = "COLOR_ON_CLICK";
window.setTimeout(() => {
this.shadowRoot.getElementById('card').style.background = "COLOR_YOU_WANT_UNCLICKED"; // if your color is different based on the state, well, you'll have to handle it here or use css variables :)
}, 500)
You can use that hack for anything else also that you want to execute on tap/double_tap/hold
Iām using it to do this for example:
- type: custom:button-card
show_icon: true
icon: mdi:skip-next
color: rgba(255, 255, 255, 0.8)
styles:
card:
- background: none
- box-shadow: none
icon:
- transition: all 1s ease-in-out
- opacity: 0
tap_action:
service: media_player.media_next_track
service_data:
entity_id: media_player.sonos_connect
always_execute: |
this.shadowRoot.getElementById('icon').style.opacity = 1;
this.shadowRoot.getElementById('icon').style.opacity = 0;
}, 1000)
Hey cool. I got a new phone so I have haptic feedback now. This requirement is a thing of the past! I was using an iphone 5 for the longest timeā¦
Anyways, I can see a use for it in other areas, thanks!
What did you do to get the background to display the graph for a sensor card? Are you leveraging the html objects?
EDIT: You have to be, Iām guessing you have that positioned in the center in the with a low z order?
EDIT: The only thing I can see you doing is using hui-graph-base but you feed it coordinates that you calculate.
LAST EDIT: FFS, I didnāt notice you built in the ability to embed cardsā¦ been on a damn wild goose chase looking through the code. Should have checked the docs sooner
Actually, Iām using a picture-elements
with a button-card
and a mini-graph-card
inside (it is a decluttering-card template)
square_numeric_sensor_with_graph:
defaults:
- entity:
- name:
card:
type: picture-elements
image: /local/Transparent_Square.png
elements:
- type: custom:mini-graph-card
style:
top: 40%
left: 50%
width: 100%
height: 80%
translate: translate(-50%, -50%)
entities:
- '[[entity]]'
group: true
points_per_hour: 1
line_color: rgba(255, 255, 255, 0.8)
hour24: true
line_width: 10
hours_to_show: 24
update_interval: 600
show:
icon: false
state: false
points: false
legend: false
average: false
extrema: false
labels: false
fill: false
labels_secondary: false
name_adaptive_color: false
icon_adaptive_color: false
style:
top: 50%
left: 50%
width: 100%
template: square_base_numeric_sensor
entity: '[[entity]]'
(Edit: Would have used the card inside button-card but it would refresh the whole graph everytime. I need to improve that on the button-card)
Iām almost there with the button card. Much larger config that yoursā¦ but itās almost done.
what do you mean refresh the whole graph? If you use a embedded sensor card it refreshes the whole graph?
I have this so far
aspect_ratio: 1/1
entity: sensor.cpu_temperature
show_name: true
show_label: true
show_last_changed: true
styles:
grid:
- grid-template-areas: '"info" "graph" "n" "l" "i" "s"'
- grid-template-rows: 1fr min-content min-content min-content min-content min-content
card:
- border-radius: 15px
- padding: 10px 0px
name:
- justify-self: start
- align-self: end
- font-weight: bold
- font-family: Helvetica
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, var(--paper-item-icon-color) 0%, var(--paper-item-icon-color) 80%, rgba(0,0,0,0))
- -webkit-background-clip: text
- -webkit-text-fill-color: transparent
- position: relative
- display: inline-block
- width: calc(100% - 20px)
- align-content: start
- text-align: start
- text-overflow: unset
- padding: 0px 10px
label:
- align-self: end
- font-size: 11px
- text-align: start
- text-align: start
- padding: 0px 10px
custom_fields:
info:
- align-self: start
custom_fields:
info: >
return `
<svg viewBox="0 0 50 50"
<circle cx="25" cy="25" r="20.5" fill="var(--paper-item-icon-color)" stroke="none" />
</svg>
graph:
card:
style: |
.graph { padding: 0px; }
.flex { padding: 0px; }
entities:
- sensor.cpu_temperature
show:
fill: false
icon: false
state: false
Looks like:
Yes everytime on of the entity of the button-card is updated, it would recreate the whole mini-graph-card instead of reusing the current one thus introducing some glitches.
ah ok, maybe Iāll switch then.
Wait so how does that work with aspect ratio and a series of buttons next to each other? Ah never mind, I see the work around with the transparent square image.
Breaking Change
triggers_update
is a new field that enables you to define which entities should trigger an update of the card itself (this rule doesnāt apply for nested cards incustom_fields
as they are always updated with the latest state. This is expected and fast!). Before 3.3.0, if you were using javascript[[[ ]]]
templates, the card would update itself everytime ANY entity was updated in HA introducing a lot of load on the browser.
If you donāt have javascript[[[ ]]]
templates in your config, you donāt need to do anything, else read further.
If unset, the card will parse your code and look for entities that it can match (it only matchesstates['ENTITY_ID']
) so:
In this second case, you have 2 options:return states['switch.myswitch'].state // will match switch.myswitch // but const test = switch.myswitch return states[test].state // will not match anything
- Set the value of
triggers_update
toall
(This was the behavior of button-card < 3.3.0)triggers_update: all
- Set the value of
triggers_update
to a list of entities. When any of the entities in this list is updated, the card will be updated. The logic is the same as the internal home-assistant* templates
integration (see here for example):type: custom:button-card entity: sensor.mysensor # No need to repeat this one in the triggers_update, it is added by default triggers_update: - switch.myswitch - light.mylight
- Set the value of
New Features
- Supports defining multiple button
template
The button templates will be applied in the order they are defined:type: custom:button-card template: - template1 - template2
template2
will be merged withtemplate1
and then the local config will be merged with the result. You can still chain templates together (ie. definetemplate
in a button-card template. It will follow the path recursively). - The card will display an error on screen instead of just disappearing from your layout when an error occurs. If it is an error in your javascript templates, it will display an error card with
ButtonCardJSTemplateError
and display the beginning of your template so that you can identify it:
BugFixes
- The button might not have been clickable in some cases when the
action
of a*_action
was a template. - Nested cards should be updated properly now when there is a state change.
- Fixes when a timer entity was defined and the button was in a vertical-stack/horizontal-stack
- Fix for button-card using templates not working in Lovelave panels when casting
Other stuff
- A lot of refactor in the code, I hope I didnāt break too much things
Hi guys,
Iām trying to figure it out how to toggle my sonoff we the yeelight is unavailable.
is it possible to use templates on tap_action in order to change the identity_id to toggle based on a states attribute?
Something like this:
- type: "custom:button-card"
entity: light.yeelight_lampadario
template: light_button
icon: "mdi:globe-light"
tap_action:
service: homeassistant.toggle
service_data:
entity_id: >
if (states['light.yeelight_lamp'].state == "unavailable")
return switch.sonoff_lamp;
return light.yeelight_lamp;
(this in not working)
the overall idea is to toggle the sonoff_switch when the yeelight lamp is unavailable.
Thanks Mark
You are missing the quotes:
tap_action:
service_data:
entity_id: >
return "switch.sonoff_lamp";
return "light.yeelight_lamp";
damn quotesā¦ now is working perfectlyā¦
Sorryā¦
Your āCoversā header has 3 icons, how did you do that?
Thanks,
Jon
Itās 4 buttons embedded in a stack-in-card
- type: custom:stack-in-card
mode: horizontal
cards:
template: header_with_other_stuff
template: header_icon_middle
icon: mdi:arrow-up-thick
tap_action:
service: cover.open_cover
service_data:
entity_id: cover.all_covers
icon: mdi:stop
tap_action:
service: cover.stop_cover
service_data:
template: header_icon_end
icon: mdi:arrow-down-thick
tap_action:
service: cover.close_cover
service_data:
Awesome thank you.
can you share āheader_icon_endā or āheader_icon_middleā template? Curious how you are doing the alignments? Thank you!!
Trying to make a card that has a background that matches the theme (working), an icon that has a custom state color (green for locked) but then when unlocked, the icon changes to white and the card to red and flashes. Iām close but canāt quite get it. The icon stays green on āunlockedā. Anyone got any tips?
color: var(--paper-item-icon-inactive-color)
color_type: card
entity: lock.frontdoor_deadbolt
icon: 'mdi:lock'
state:
- color: red
icon: 'mdi:lock-open'
styles:
card:
- animation: blink 5s ease infinite
value: unlocked
- operator: default
styles:
card:
- height: 140px
- border: 'solid 2px rgba(255,255,255,.4)'
icon:
- color: green
- value: locked
type: 'custom:button-card'
That would do it:
color_type: card
icon: 'mdi:lock'
state:
- color: red
styles:
card:
icon:
- color: white
value: unlocked
styles:
card:
- height: 140px
icon:
- color: green
