Lovelace: Button card
Can someone pls help me with the config of a button card:
color: auto
color_type: card
entity: switch.tumble_dryer
hold_action:
  action: more-info
icon: 'mdi:tumble-dryer'
label: Dryer
show_label: true
state:
  - color: white
    styles:
      card:
        - animation: blink 2s ease infinite
        - color: 'rgb(255, 0, 0)'
    value: 'on'
  - color: 'rgb(255, 255, 255)'
    value: 'off'
type: 'custom:button-card'
The above works fine based on the on/off state of my wifi switch (flashes red when it is on) but I need to create the exact same but to work off of a sensor.tumble_dryer value which is the wattage value of the wifi switch.
Not sure how to change this part so I can say if value is > 10watts then flash red (means the dryer is on)
state:
  - color: white
    styles:
      card:
    value: 'on'
    value: 'off'
Any ideas?
That should do it instead of value: 'on'
value: 10
operator: '>'
That did it :slight_smile:
Much obliged.
Is there a way to align the card so that the entity_picture is on the left and all the data is on the right side?
Currently all the data is at the bottom of my entity_pitcture.
  - type: horizontal-stack
    cards:
      - type: 'custom:button-card'
        entity: device_tracker.google_maps
        entity_picture: /local/lovelace/Presence/Home.png
        aspect_ratio: 1/1
        show_entity_picture: true
        state:
          - value: "home"
            styles:
              entity_picture:
                - filter: opacity(0%)
                - filter: grayscale(0%)
        styles:
          card:
            - border-radius: 0%
            - padding: 5%
            - color: ivory
            - font-size: 12px
            - text-shadow: 0px 0px 0px black
            - text-transform: capitalize
            - justify-self: end
            - align-self: middle
            - font-family: avenir
          grid:
            - grid-template-areas: '"i status" "n n" "address address" "battery battery" "charging charging"'
            - grid-template-columns: 1fr 1fr
            - grid-template-rows: 1fr min-content min-content min-content min-content min-content
          name:
            - font-size: 16px
            - justify-self: start
            - padding-bottom: 0px
          icon:
            - width: 70%
          entity_picture:
            - filter: opacity(50%)
            - filter: grayscale(100%)
          custom_fields:
            status:
              - align-self: start
              - justify-self: end
              - color: gray
            address:
              - color: gray
            battery:
              - color: gray
              - '--text-color-sensor': '[[[ if (states["sensor.mobile_battery"].state < 50) return "#EF4F1A"; ]]]'
            charging:
              - color: gray
        custom_fields:
          status: |
              return `<ha-icon
                style="width: 12px; height: 12px; color: black;">
                </ha-icon><span>${entity.state}</span>`
          address: |
              return `<ha-icon
                icon="mdi:map-marker-distance"
                style="width: 12px; height: 12px; color: deepskyblue;">
                </ha-icon>  <span>\<span style="color: var(--text-color-sensor);">${states['sensor.phone_geocoded_location'].state}</span></span>`
          battery: |
              return `<ha-icon
                icon="mdi:cellphone-iphone"
                </ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.mobile_battery'].state}% battery</span></span>`
          charging: |
              return `<ha-icon
                icon="mdi:flash"
                </ha-icon>  <span>\<span style="color: var(--text-color-sensor);">Charging: ${states['device_tracker.google_maps}</span></span>`
@RomRider Thanks - Iā€™ve been working at it a while and am pretty happy with where itā€™s come. The pop-up card is what really makes it long, though, not button card specifically. Will clickable hot zones ever be a part of the card? That would really be an amazing upgrade from my point of view.
@anilet Glad to see itā€™s not a complete unintelligible mess to everyone but me!
@ThaNerd In grid-template-areas you have 5 value sets but in grid-template-rows you have 6 rows defined. There needs to be the same number of those two things or the grid breaks. Speaking of the grid, to separate the entity picture on the left and the data on the right, thatā€™s how you do it. Make a column that has only the entity picture on the left side and then another column with your data points on the right.
Something like ā€˜ā€œi statusā€ ā€œi nā€ ā€œi addressā€ ā€œi batteryā€ ā€œi chargingā€ā€™ would make the ā€˜iā€™ fill up the entire left column, while the grid areas are spread out across the right column.
Or if you wanted the name and status to be full length across the top, the identity picture in the bottom left corner, and the other info in the bottom right, you could do something like ā€˜ā€œstatus statusā€ ā€œn nā€ ā€œi addressā€ ā€œi batteryā€ ā€œi chargingā€ā€™
(I made a post a while back doing my best to explain the grid for someone who was confused by it, in case itā€™s helpful) Lovelace: Button card - #3154 by tismondo
After installing latest HA release some of my buttons disappeared also if i did not changed anything in the configsā€¦
For example these buttons are not anymore visible in the frontend:
                      - type: custom:button-card
                        entity: 'binary_sensor.updater'
                        icon: 'mdi:home-assistant'
                        name: Home Assistant
                        styles:
                          card:
                            - padding-left: 5px
                            - font-size: 12px
                            - font-weight: normal
                            - font-family: 'Georgia'
                            - box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 0.2), 0 6px 20px 0 rgba(0, 0, 0, 0.19)
                          grid:
                            - grid-template-areas: '"i i" "n n" "current current" "local local" '
                          name:
                            - font-size: 13px
                            - padding-bottom: 4px
                          img_cell:
                            - justify-content: start
                            - align-items: start
                          icon:
                            - color: >
                                  if (entity.state == 'on') return 'red';
                                  return 'green';
                            - animation: >
                                    if (entity.state == 'on') return 'blink 2s ease infinite';
                          custom_fields:
                            current:
                              - align-self: start
                              - --text-color-sensor: >
                                  [[[ if (entity.state == 'on') return 'red'; return 'green'; ]]]
                            local:
                              - align-self: start
                        custom_fields:
                          current: >
                            return `<ha-icon
                              icon='mdi:home-assistant'
                              style='width: 12px; height: 12px; color: deepskyblue;'>
                            </ha-icon><span>Current: <span style='color: var(--text-color-sensor);animation: var(--animation)'>${states['sensor.latest_version'].state}</span></span>`
                          local: >
                              return `<ha-icon
                              </ha-icon><span>Local: <span style='color: green;'>${states['sensor.current_version'].state}</span></span>`
                        entity: sensor.rpi_power_status
                        show_state: true
                        name: RPi <br> Power Status
                        styles:
                          card:
                            - font-size: 10px
                            - height: 100%
                          icon:
                            - color: >
                                  if (entity.state == 0) return 'red';
                                  return 'green';
                        entity: sensor.hacs
                        show_state: true
                        styles:
                          card:
                            - font-size: 12px
                            - height: 100%
                          icon:
                            - color: >
                                  if (entity.state >= 1) return 'red';
                                  return 'green';
                            - animation: >
                                  if (entity.state >= 1) return 'blink 2s ease infinite';
While others like this:
                      entity: sensor.home_assistant_log
                      show_state: true
Are visible like beforeā€¦
What has changed?
Is there a way to remove the card outline?
Iā€™ve tried the different 'color_typeā€™s
Iā€™m having the same issue, but for me none of the cards are working
I found the issue is about custom stack-in-card i was using with those button cardsā€¦
Changing it to vertical-stack all was working againā€¦ Hoping in a fast fix!
Probably this:
styles:
  card:
    - background: none
stack-in-card has an issue, I need to look into it but didnā€™t have time for now
it should now be fixed with stack-in-card v0.1.1: Stack-In-Card: Drop-in replacement for vertical-stack-in-card
So I changed it to ā€˜ā€œstatus statusā€ ā€œn nā€ ā€œi addressā€ ā€œi batteryā€ ā€œi chargingā€ā€™ and I got this:
so in that code I see all the fields but which one assigns where the entity_picture: goes? Seems like the code you provided made 4 columnsā€¦
There arenā€™t 4 columns, but your justify-self settings make it look like there are. Without knowing what you want the card to finally look like, I canā€™t provide very specific help. Iā€™ll assume you want a heading across the entire top of the card since thatā€™s the version of my 2 suggestions you used.
  1. To answer your question, entity_picture is defined by i (since youā€™ve made show_entity_picture: true the entity_picture replaces your icon. i for icon.)
  2. Start by changing justify-self: settings for both name: and status: to justify-self: center. That should show you that the name and status grid areas are spread across the entire top of both columns (and that you only have two, not four). The image and data points will be in the lower portion of the card, separated by the two columns.
  3. Your entity_picture is cut off because it either needs to be made smaller, or you need to change your rows to some other size other than min-content (You can also use fractions of available space, using the nomenclature 1fr 2fr etc)
  4. Again, if you give me a visual of what you want the card to look like I can be a lot more helpful.
I have an issue with 0.110 which has suddenly stopped displaying some custom field information.
I have attached before and after as well as my code for these fields, which has not changed. Any idea what might have changed to cause this? All my sensors are still present and their names and attributes have not changed
Before:
After:
0.110
Snippet of button code:
      - type: custom:decluttering-card
        template: person_card_new
        variables:
          - entity: person.ben
          - name: Ben
          - battery: device_tracker.life360_ben
          - work_sensor: sensor.ben_to_work_waze
          - home_sensor: sensor.ben_to_home_waze
          - work_icon: mdi:car
          - entity_picture: /local/ben6.png
          - show_entity_picture: true
          - tap_action:
              action: more-info
              haptic: light
styles:
  card:
    - border-radius: 12px
    - --paper-card-background-color: '[[background_color]]'
  icon:
    - grid-column: 1
    - grid-row: 1 / 4
  label:
    - color: gray
    - font-size: 11px
    - padding: 0px 10px
  state:
    - font-size: 12px
    - padding: 0px 10px
    - font-weight: bold
    - padding-left: 10px
    - color: var(--primary-text-color)
  grid:
    - grid-template-areas: '"i s" "i battery" "i home" "i work"'
    - grid-template-columns: 50% 50%
    - grid-template-rows: 25% 25% 25% 25%
  img_cell:
    - align-self: start
    - text-align: start
  name:
    - font-weight: bold
    - font-size: 13px
  entity_picture:
    - height: 60px
    - width: 60px
    - border-radius: 100%
  custom_fields:
    battery:
      - align-self: start
      - font-size: 12px
      - color: var(--secondary-text-color)
    home:
      - align-self: start
      - font-size: 12px
    work:
      - align-self: start
      - font-size: 12px
custom_fields:
      battery: >
            if (states['[[battery]]'].attributes.battery_charging === false)
              return `<ha-icon
                icon="mdi:battery"
                style="; height: 14px; color: var(--primary-line-color);">
                </ha-icon><span>${states['[[battery]]'].attributes.battery}%</span>`
            else return `<ha-icon
              icon="mdi:battery-charging"
      home: >
            return `<ha-icon
              icon="mdi:home-import-outline"
              </ha-icon><span>${states['[[home_sensor]]'].state}mins</span>`
      work: >
            return `<ha-icon
              icon="[[work_icon]]"
              </ha-icon><span>${states['[[work_sensor]]'].state}mins</span>`
Did you update decluttering-card to the latest version? Did you try without it?
Thanks for the tip, I havenā€™t which could explain possibly the issue :slight_smile: I just noticed the new file is .ts instead of .js in github, do I need to replace my current .js file with the new .ts file?
Ignore, sorry I have just realised I installed through HACS. Yes it seems to be up to date, I will try without it and report back to see if that works!
No dice Iā€™m afraid, have rebuilt directly using the button card and the same issue occurs for the custom field states onlyā€¦ so doesnā€™t seem like an issue with decluttering.
here is the code:
        entity: person.ben
        lock: false
        color: auto
        background_color: var(--homekit)
        variable: spin
        spin: false
        show_name: false
        show_state: true
        show_label: false
        show_icon: true
        show_last_changed: false
        tap_action:
          action: toggle
          haptic: light
        hold_action:
          action: more-info
          haptic: success
        aspect_ratio: 2/1
        margin-right: 20px
        label: '&nbsp;'
        off_icon_color: gray
        off_name_color: gray
        off_state_color: gray
        styles:
          card:
            - --paper-card-background-color: var(--homekit)
          icon:
            - grid-column: 1
            - grid-row: 1 / 4
          label:
            - color: gray
            - font-size: 11px
            - padding: 0px 10px
          state:
            - font-size: 12px
            - padding: 0px 10px
            - font-weight: bold
          grid:
          img_cell:
            - align-self: start
            - text-align: start
          name:
            - font-weight: bold
            - font-size: 13px
          entity_picture:
            - height: 60px
            - width: 60px
          custom_fields:
            battery:
              - align-self: start
              - font-size: 12px
            home:
              - align-self: start
              - font-size: 12px
            work:
              - align-self: start
              - font-size: 12px
        custom_fields:
              battery: >
                    if (states['device_tracker.life360_ben'].attributes.battery_charging === false)
                      return `<ha-icon
                        icon="mdi:battery"
                        </ha-icon><span>${states['device_tracker.life360_ben'].attributes.battery}%</span>`
              home: >
                    return `<ha-icon
                      </ha-icon><span>${states['sensor.ben_to_home_waze'].state}mins</span>`
              work: >
                    return `<ha-icon
                      icon="mdi:car"
                      </ha-icon><span>${states['sensor.ben_to_work_waze'].state}mins</span>`
        state:
          - value: "not_home"
            styles:
              card:
                - opacity: 0.6
              entity_picture:
                - border: 1px solid var(--secondary-text-color)
          - value: "home"
            styles:
              entity_picture:
                - border: 1px solid var(--primary-line-color)
          - value: "Ben Work"
            styles:
              entity_picture:
                - border: 1px solid var(--secondary-line-color)
          - value: "Jess Work"
            styles:
              entity_picture:
          - value: "Poppy and Lola Home"
            styles:
              entity_picture:
                - border: 1px solid var(--tertiary-line-color)
          - value: "GPa and GMa Home"
            styles:
              entity_picture:
Are you also running the latest button-card 3.3.5? What does your javascript console tell you?
Your config seems a bit wrong for the latest button-card.
  • lock: false doesnā€™t exist this way anymore
  • variable: spin, background_color: var(--homekit) are not configuration options
  • tap_action: you canā€™t toggle a person entity
Sorry was a rush job to update it :slight_smile: can confirm I am running the latest 3.3.5 and have updated those details but still the same issue Iā€™m afraid. Updated code below.
        entity: person.ben
        color: auto
        spin: false
        show_name: false
        show_state: true
        show_label: false
        show_icon: true
        tap_action:
          action: more-info
          haptic: light
        aspect_ratio: 2/1
        margin-right: 20px
        label: '&nbsp;'
        styles:
          card:
          icon:
            - grid-column: 1
            - grid-row: 1 / 4
          label:
            - color: gray
            - font-size: 11px
            - padding: 0px 10px
          state:
            - font-size: 12px
            - padding: 0px 10px
            - font-weight: bold
          grid:
          img_cell:
            - align-self: start
            - text-align: start
          name:
            - font-weight: bold
            - font-size: 13px
          entity_picture:
            - height: 60px
            - width: 60px
          custom_fields:
            battery:
              - align-self: start
              - font-size: 12px
            home:
              - align-self: start
              - font-size: 12px
            work:
              - align-self: start
              - font-size: 12px
        custom_fields:
              battery: >
                      return `<ha-icon
                        icon="mdi:battery"
              home: >
                    return `<ha-icon
              work: >
                    return `<ha-icon
                      icon="mdi:car"
        state:
          - value: "not_home"
            styles:
              card:
                - opacity: 0.6
              entity_picture:
          - value: "home"
            styles:
              entity_picture:
          - value: "Ben Work"
            styles:
              entity_picture:
            styles:
              entity_picture:
            styles:
              entity_picture:
            styles:
              entity_picture:
Unsure how I use Javascript console sorry
