Lovelace: Button card
Everytime I set the height of a card I get a huge gap at the bottom. I tried setting padding to 0% and margin to 0% but nothing works…If I don’t set the height the card becomes to big.
Is there a way to fix this?
        styles:
          card:
            - font-size: 20px
            - color: green
            - height: 100px
            - padding-bottom: 0%
            - padding-top: 0%
2020-05-27_10-43-34
Upgrade to the latest button-card, this is already fixed.
What is the parent card in this setup?
This is the start of the yaml:
title: Irrigation
icon: mdi:water-pump
cards:
  - type: vertical-stack
    cards:
      - type: 'custom:button-card'
        entity: timer.irrigation_timer
        show_state: true
        show_label: false
        show_icon: false
        show_name: false
        aspect_ratio: 2/1
        state_display: '[[[ if (entity.state === "idle") return "Irrigation is OFF"; else return null ]]]'
        styles:
          card:
            - font-size: 20px
            - color: green
            - margin: 0%
        entity: script.irrigate
        aspect_ratio: 4/1
        show_icon: false
        tap_action:
          action: call-service
          service: script.turn_on
          service_data:
            entity_id: script.irrigate
          confirmation:
            text: Are you sure you want to start all sprinklers?
        styles:
          card:
            - font-size: 20px
            - height: 100px
            - padding-top: 0%
      - type: horizontal-stack
        cards:
            entity: switch.irrig_front
            icon: mdi:arrow-decision-outline
            aspect_ratio: 1/1
            tap_action:
              service: switch.turn_on
              service_data:
                entity_id: switch.irrig_front
              confirmation:
                text: Are you sure you want to start Front Yard?
            double_tap_action:
              service: switch.turn_off
              service_data:
              confirmation:
                text: Are you sure you want to stop Front Yard?
            styles:
              card:
               - font-size: 12px
Don’t forget to clear your cache. Also if you use HACS, refresh the page twice, at least.
OK fixed it.
I guess it was aspect_ratio vs height? You can’t specify both at the same time :slight_smile:
Yeah I removed aspect ratio and it started to play nice :slight_smile:
Btw out of curiosity is there a way to use a gif within a card? Or any animated image?
Yes, just use your gif as the entity_picture, or in any CSS property which supports an image (like background for example).
Hey there, just another noob question:
How could i align the icon left?
I tried
aspect_ratio: 1/0.3
color: 'rgb(47, 186, 229)'
icon: 'fas:couch'
label: >
  [[[ return states['sensor.heizung_wohnzimmer_temperature'].state + '°C / ' +
  states['sensor.heizung_wohnzimmer_humidity'].state + '%' ]]]
show_label: true
styles:
  card:
    - color: '#101012'
    - padding-top: 0%
    - align: left
  label:
    - color: '#adadb7'
    - font-size: 13px
    - padding-top: 5px
  name:
    - justify-self: center
    - margin-bottom: 5%
    - font-size: 18px
    - font-weight: bold
    - font-family: 'Roboto,sans-serif'
tap_action:
  action: navigate
  navigation_path: /lovelace/wohnzimmer
But align: lleft does not affect the icon. I’m neither a HA nor a CSS expert.
Could you help me? :wink:
Nic
add icon: under styles: and use justify-self: start
styles:
  icon:
    - justify-self: start
i tried
aspect_ratio: 1/0.3
icon: 'fas:couch'
label: >
show_label: true
styles:
  card:
    - color: '#101012'
  icon:
  name:
    - margin-bottom: 5%
    - font-size: 18px
    - font-weight: bold
tap_action:
  action: navigate
But the “couch” icon is still in the middle
what about using the layout parameter/options to put the icon and state horizontally aligned and the state below?
layout: icon_state
Sorry i meant label below
Perhaps I don’t know what you mean when you say you want it to the left. Could you please screenshot your card and visually explain what you want?
Hey RomRider,
would there be any future left for this thought we once dreamt about…
Don’t think I’ve seen a definitive Njet in this thread further down, so my hopes are still up :innocent:
Wouldn’t layout-card do the trick here?
That should work (this is top left, but remove one line or the the other to have it only left or top) :
  styles:
    img_cell:
      - justify-content: start # horizontal
      - align-items: start # vertical
I’ve been trying to do the same, and I just can’t get it to work no matter what I try.
The red border is around the img_cell and the green border is around the icon:
                  img_cell:
                    - width: 40px
                    - height: 40px
                    - border: 1px dashed red
                  icon:
                    - height: 24px
                    - width: 24px
                    - border: 1px dashed green
I’m trying to get the thermometer to be hard left against the green border. Tried playing around with the grid column size, that moves things around, but the icon is always centered in the green border … I am sure its just me, but thought I’d mention it as well.
Not something possible as the viewPort of the icon svg is a square and the icon is centered inside (using preserveAspectRatio but it’s not a CSS property). That’s how mdi icons are defined. :man_shrugging:
