after updating to 0.114 my tap_action doesnt work anymore, i have a call-server as action that needs to run a script when i hit on the button but nothing happens. When i go back to 0.112.3 it works fine, any idea why?
Good evening I need a lot of help, I saw the realization of LbDAB that I am attaching I tried to understand how to load the files on my home assistant but without success is there anyone who can help me? I would like to accomplish such a thing on one page. On the LbDab wiki page there are files and what you need but not a technical explanation of how they should be loaded and what makes me even more doubtful is the location of these files in the home assistant.
I am trying to get the same function as lovelace-multiple-entity-row but I only want to use button-card.
I have the overall design almost done now and now I am stuck.
I want the area in the th /th to be a link to the entity is that possible? So if i press Min i want this area up:
Mariusthvdb Iām not the one who designed this beautiful card but as rste_narquois said it was the LbDab user from whom I would have liked to have some more details on the location of the files tracked in GitHub see the link that put you rste_narquois
Yes that is trueā¦ Maybe that is the way i need to go if I cant fix it with some custom are over the other or embed a link in the th section.
that should make it more customizable for the future also
Iāve been trying to use the navigation path action to change the url hash value along with the state-switch card in order to make a user independent tab menu, It works but iād like to have the button colour change depending on the url hash value. Iāve tried using a javascript template with if (window.location.hash === āvalueā) which works but only updates the colour after the page is manually reloaded.
So my question, is it possible to recheck a template value when a button is pressed?
