I was unaware you ccould create css classes. Nice
ok, as said I hadnât yet set styles
so I need this to hover on the icon, since thatâs the only thing showing on my buttons in the shortcut menu. please let me post what I tried:
using the adapted button_template, with the extra_styles @KTibow posted above:
button_shortcut_menu:
variables:
dashboard: >
[[[ return window.location.pathname.split('/')[1] ]]]
view: >
[[[ return window.location.pathname.split('/').slice(-1) ]]]
styles:
icon:
- color: var(--secondary-text-color)
card:
- background: >
[[[ return variables.view == variables.path
? 'var(--secondary-background-color)' : 'var(--card-background-color)';
extra_styles: |
/* Tooltip container */
.tooltip {
position: relative;
display: inline-block;
border-bottom: 1px dotted black; /* If you want dots under the hoverable text */
/* Tooltip text */
.tooltip .tooltiptext {
visibility: hidden;
width: 120px;
background-color: black;
color: #fff;
text-align: center;
padding: 5px 0;
border-radius: 6px;
/* Position the tooltip text - see examples below! */
position: absolute;
z-index: 1;
/* Show the tooltip text when you mouse over the tooltip container */
.tooltip:hover .tooltiptext {
visibility: visible;
and the menu button itself:
- type: custom:button-card
template: button_shortcut_menu
icon: >
return `<div class="tooltip">
<ha-icon>icon='mdi:calendar'></ha-icon>
<span class="tooltiptext">Calendar</span>
</div>`
tap_action:
action: navigate
navigation_path: /lovelace/tijd_agenda
variables:
path: tijd_agenda
styles:
icon:
- color: >
[[[ return states['sensor.trash_color'].state ]]]
is this getting anywhere close to what it should be? Must be wrong somewhere because I cant see an icon anymore, nor a tooltipâŚ
trying the html in the button code for now, if this will work, Ill try to move it to the template and need to find a way to have the icon set in the button config (maybe yet another variable?) and feed it to the template
if anyone would have a minute to help me a bit further here it would be much appreciated. Much of my troubles is caused by not being able to show the icon using the code herein I fear (copied from the docs. Or is that only allowed in custom_fields, and not the main pre-defined ones?:
icon: >
</div>`
if I could start getting that right, next step (the tooltip) would probably be easier. If possible at all of course.
thanks of you would!
Mind making a compiled button-card for testing (manually add the template in to your setup)? Thanks!
I already tried that, but nothing showsâŚ
icon: >
return `<ha-icon icon='mdi:calendar'></ha-icon>`
tap_action:
action: navigate
shows a button, tapping it works, but no iconâŚ
This should work:
icon: >
return `mdi:calendar`
tap_action:
action: navigate
yes it does! and, using your extra_styles in my button template, how should I next add Petroâs template around that icon?
icon: >
return `<div class="tooltip">mdi:calendar
</div>`
? obviously notâŚ
I donât think itâs possible to override the HTML of the icon. Gonna come back to this later. Iâd recommend adding a custom field which is a markdown card, and disabling the icon.
thanks, appreciate your efforts. Maybe Romrider could provide us (me) with some certainty. If not possible yet, might be a fine FR, adding tooltip on a button with an icon only.
will test with name to be sure the tooltip itself is correct.
using:
return `<div class="tooltip">Cal
</div>`
the name shows fine, even with the dots of the extra_styles, but no tooltip on hover:
this seems to be the only reference by the master himself, stating it should be possible, so thatâs hopeful.
no example anywhere thoughâŚ
tried a little hack:
`<div class='tooltip'><ha-icon icon='mdi:calendar'</ha-icon>
<span class='tooltiptext'>Tooltip text</span>
</div`
showing the icon, but still no tooltip. giving up for now.
HI Guys,
can one help me for this:
thank you
What do you need help with? Is there a bug? Do you want to add something?
i want to integrate that and would like to have the code.
The Code from Pedro works only for lovelace gen ?
# lovelace_gen
{% set color = color|default('var(--paper-item-icon-active-color)') %}
aspect_ratio: 1/1
entity: {{ entity }}
name: {{ name }}
show_state: true
show_name: true
show_label: false
styles:
icon:
- height: auto
img_cell:
- justify-content: start
- align-items: start
grid:
- grid-template-areas: '"i info" "n n" "s s" "l l"'
- grid-template-columns: 1fr 35%
- grid-template-rows: 1fr 0.min-content min-content min-content
- position: relative
card:
- border-radius: 15px
- padding: 10px
name:
- justify-self: start
- align-self: end
- font-weight: bold
- font-family: Helvetica
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, white 0%, white 80%, rgba(0,0,0,0))
- -webkit-background-clip: text
- -webkit-text-fill-color: transparent
- display: inline-block
- width: 100%
- align-content: start
- text-align: start
- text-overflow: unset
state:
- align-self: end
- font-weight: bold
- font-size: 12px
- text-align: start
custom_fields:
info:
- align-self: start
custom_fields:
info: >
function capitalizeFirstLetter(string) {
return string.charAt(0).toUpperCase() + string.slice(1).toLowerCase();
const length = 41;
const width = 3;
if (entity.state === 'on' && entity.attributes.brightness) {
const radius = length / 2;
const brightness = Math.round(entity.attributes.brightness / 2.54);
const circumference = radius * 2 * Math.PI;
return `
<svg viewBox="0 0 50 50">
<circle cx="25" cy="25" r="${radius}" fill="none" stroke="var(--paper-item-icon-color)" opacity="0.5" stroke-width="${width}" />
<circle style="
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - brightness / 100 * circumference};
id="c_brightness" cx="25" cy="25" r="${radius}" stroke="var(--paper-item-icon-active-color)" stroke-width="${width}" fill="none" stroke-linecap="round" />
<text x="50%" y="54%" fill="var(--primary-text-color)" font-size="14" text-anchor="middle" alignment-baseline="middle">${brightness}<tspan font-size="10">%</tspan>
</text>
</svg>
else if (entity.state === 'on' && entity.attributes.speed && entity.attributes.speed_list) {
const text = capitalizeFirstLetter(entity.attributes.speed);
const gap = 5;
const edge = (50 - length) / 2;
const y = 50 - edge;
var items = entity.attributes.speed_list;
if (items.indexOf('off') !== -1){
items.splice(items.indexOf('off'), 1);
const current = items.indexOf(entity.attributes.speed)
var i;
var x1 = edge;
var ret = `<svg viewBox="0 0 50 50">`;
var l = (length - gap * (items.length - 1)) / items.length;
for (i = 0; i < items.length; i++) {
var x2 = x1 + l;
var color = (i <= current) ? "var(--paper-item-icon-active-color)" : "var(--paper-item-icon-color)";
var opacity = (i <= current) ? "1.0" : "0.5";
ret += `<line x1="${x1}" y1="${y}" x2="${x2}" y2="${y}" stroke="${color}" stroke-width="${width}" opacity="${opacity}" stroke-linecap="round" />`;
x1 = x2 + gap;
ret += `<text x="50%" y="54%" fill="var(--primary-text-color)" font-size="14" text-anchor="middle" alignment-baseline="middle">${text}</text></svg>`
return ret;
state:
- value: 'on'
styles:
card:
- opacity: 1.0
icon:
- color: |
var [domain, object_id] = entity.entity_id.split('.');
if (domain === "light")
return 'var(--button-card-light-color)';
return '{{ color }}';
name:
- color: white
state:
- color: gray
lock:
- color: white
label:
- color: gray
- value: 'off'
styles:
card:
- opacity: 0.5
icon:
- color: var(--paper-item-icon-color)
name:
- color: var(--primary-text-color)
state:
label:
lock:
- value: "unavailable"
styles:
card:
- opacity: 0.2
icon:
- color: var(--paper-item-icon-color)')
name:
state:
- color: hsl(0, 100%, 50%)
label:
lock:
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: heavy
# lovelace_gen
aspect_ratio: 1/1
name: {{ name }}
show_state: true
show_name: true
show_label: false
styles:
icon:
- height: auto
img_cell:
grid:
card:
- padding: 10px
name:
- align-self: end
- font-weight: bold
- font-size: 12px
- text-align: start
- width: 100%
- text-align: start
state:
- align-self: end
- font-weight: bold
- font-size: 12px
- text-align: start
custom_fields:
info:
- align-self: start
custom_fields:
info: >
const length = 41;
const width = 3;
return `
<circle style="
</text>
</svg>
const gap = 5;
var i;
var x1 = edge;
var x2 = x1 + l;
x1 = x2 + gap;
return ret;
state:
- value: 'on'
styles:
card:
- opacity: 1.0
icon:
- color: |
name:
- color: white
state:
- color: gray
lock:
- color: white
label:
- color: gray
- value: 'off'
styles:
card:
- opacity: 0.5
icon:
name:
state:
label:
lock:
styles:
card:
- opacity: 0.2
icon:
name:
state:
label:
lock:
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: heavy
hi, see if someone can help me, so far I have this working:
hold_action:
action: url
url_path: >
[[[ return states['[[entity]]'].attributes.map_link ]]]
now I am trying to achieve the same with the sensor of the ha application, in the template editor it works correctly:
{% set geo = state_attr('sensor.redmi_note_7_geocoded_location', 'Location').split('[')[1].split(']')[0] %}
https://www.google.com/maps/search/?api=1&basemap=roadmap&layer=traffic&query={{geo}}
the problem is that I am not able to add it correctly to the configuration, I have tried:
hold_action:
action: url
url_path: >
return https://www.google.com/maps/search/?api=1&basemap=roadmap&layer=traffic&query={{geo}}
and
hold_action:
action: url
url_path: >
return "https://www.google.com/maps/search/?api=1&basemap=roadmap&layer=traffic&query={{geo}}"
I would appreciate your help, greetings
JS doesnât support Jinja2, donât try to mix them. Try out
hold_action:
action: url
url_path: >
return 'https://www.google.com/maps/search/?api=1&basemap=roadmap&layer=traffic&query=' + states['sensor.redmi_note_7_geocoded_location'].attributes.location.split('[')[1].split(']')[0]
Thanks a lot, its working
I have this :
color: auto
color_type: icon
entity: input_select.chauffage_salon
icon: 'mdi:clock-outline'
show_icon: true
show_label: false
show_last_changed: false
show_name: true
show_state: false
styles:
card:
- height: 100px
- width: 355px
- margin: 0px 0px 0px 3px
- box-shadow: none
- background: 'rgba(0,0,0,0)'
- border: 2px solid var(--primary-color)
custom_fields:
start_time:
- z-index: 100
- background-color: 'rgba(0, 0, 0, 0)'
- position: absolute
- left: 115px
- font-size: 15px
- line-height: 20px
- transform: scale(0.9)
end_time:
- z-index: 100
- left: 225px
- font-size: 15px
- line-height: 20px
grid:
icon:
- color: var(--primary-color)
- transform: scale(0.4) rotate(0.8turn)
- left: '-50px'
name:
- bottom: 23px
- left: 45px
- font-size: 18px
- color: black
tap_action:
action: none
custom_fields:
start_time:
card:
entity: input_datetime.heating_time_confort_morning_start
hide:
hour_step: 1
layout:
align_controls: center
link_values: true
minute_step: 5
style:
ha-card {
width: 30%;
background-color: rgba(0,0,0,0);
box-shadow: none;
.time-picker-row:
.time-picker-content:
.time-separator {
display: none;
time-unit:
.time-unit {
padding: 2px !important;
.time-input {
border: 2px solid var(--primary-color) !important;
background-color: rgba(0,0,0,0) !important;
color: black !important;
border-radius: 5px;
.time-picker-icon {
color: var(--primary-color) !important;
type: 'custom:time-picker-card'
end_time:
card:
entity: input_datetime.heating_time_confort_morning_end
hide:
hour_step: 1
layout:
link_values: true
minute_step: 5
style:
ha-card {
width: 30%;
box-shadow: none;
.time-picker-row:
.time-separator {
display: none;
time-unit:
.time-unit {
.time-input {
border-radius: 5px;
.time-picker-icon {
type: 'custom:button-card'
and i got :
I have a problem.
None of the embedded cards have focus.
I have tried playing with the z-index css but it doesnât work.
Any ideas ?
I had already asked a question of this type and the correction was the css z-index.
But for this case, it does not work.
Thanks in advance.
I answer to myself if one day someone has the problem :
The focus problem is because I had set action to none.
So I put the action on script, without parameters (so no call):
I also reviewed the positions of the z-index css :
color: auto
color_type: icon
show_icon: true
show_label: false
show_name: true
show_state: false
styles:
card:
- height: 100px
- width: 355px
- box-shadow: none
custom_fields:
start_time:
- z-index: 100
- left: 115px
- font-size: 15px
- line-height: 20px
end_time:
- z-index: 100
- left: 225px
- font-size: 15px
- line-height: 20px
grid:
icon:
- left: '-50px'
- z-index: 10
name:
- bottom: 23px
- left: 45px
- font-size: 18px
- color: black
tap_action:
action: call-service
custom_fields:
start_time:
card:
hide:
hour_step: 1
layout:
link_values: true
minute_step: 5
style:
ha-card {
width: 30%;
box-shadow: none;
.time-picker-row:
.time-separator {
display: none;
time-unit:
.time-unit {
.time-input {
border-radius: 5px;
.time-picker-icon {
end_time:
card:
hide:
hour_step: 1
layout:
link_values: true
minute_step: 5
style:
ha-card {
width: 30%;
box-shadow: none;
.time-picker-row:
.time-separator {
display: none;
time-unit:
.time-unit {
.time-input {
border-radius: 5px;
.time-picker-icon {
I love this card !
Itâs work on pc (chrome) but not in app or mobile
Screenshot post? What do you mean by itâs not working? If itâs the time picker or card-mod, raise an issue over there.
