remove the margin on the grid
Do you happen to know what the code is? I inspected the element but canāt seem to find the correct one that sticks with card-mod.
It should just be:
grid:
- margin: 0
and itās not card mod, this card has built in styling.
That goes under the button-card variable styles
right? Where card, label, name etc (and grid already is if using grid option) right?
So in my case:
styles:
custom_fields:
control:
- width: 100%
- height: 100%
- position: absolute
entity_picture:
- border-radius: 20px
- height: 100%
grid:
- margin: 0
name:
- font-weight: bold
I tried that, but doesnāt do anything.
Ok, are you trying to have an image as the background of the button? Hereās what I use for thatā¦ Keep in mind, this is a work around. There may be better ways to do this, I havenāt tried to fix/optimize it in 2 years.
entity_picture: /local/images/petro_large.png
styles:
card:
- background-image: /local/images/petro_large.png
- background-repeat: no-repeat
- background-size: 100% 100%
- border-radius: 15px
- padding: 0px
entity_picture:
- width: 100%
- padding-bottom: 0%
- opacity: 0.0
I make the entity_picture opaque so that the size of the card is set to the size of the entity_picture. Then I set the background image to whatever image I want. This places the image behind all the text, outside the grid.
Basically I want the entity_picture to be the background, full sized. I use a media_player as the entity, so it automatically shows the artwork when using entity_picture. But I canāt seem to get the picture_entity to show fullscreen (so without the grid margings of the card itself).
edit:
I got it to work using this:
styles:
card:
- padding: 0px
entity_picture:
- height: 100%
- width: 100%
when you use width and height 100%, youāll get goofy aspect ratios if your image doesnāt match your button ratio.
I use it for Spotify/Chromecast music, which always shows it in a 1:1 ratio artwork. But thanks for the heads up, if stuff do look weird I know what the issue is.
just keep the button aspect ratio to 1/1 and youāll be fine. You technically shouldnāt need to specify both, only 1. I typically use width and omit height.
Problem with the github example ā¦
Iām learning the grid system, and was frustrated while trying to left justify the icon until I tested this github example on my system. The example shows the icon left justified, but on my system, the icon is still centered.
Whatās the best practice for left-justifying the icon?
- type: custom:button-card
entity: switch.skylight
icon: mdi:fire
show_state: true
styles:
card:
- width: 100px
- height: 100px
grid:
- grid-template-areas: '"i" "n" "s"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
img_cell:
- align-self: start
- text-align: start
name:
- justify-self: start
- padding-left: 10px
- font-weight: bold
- text-transform: lowercase
state:
state:
- value: 'off'
styles:
card:
- filter: opacity(50%)
icon:
- filter: grayscale(100%)
please help me find the error in my button. I need to capitalize these:
which is coded like this:
button_meterget:
template: button_force_body
function capitalizeFirstLetter(string) {
return string.charAt(0).toUpperCase() + string.slice(1).toLowerCase();
var id = entity.entity_id.split('_').slice(-1);
return id;
icon: >
var id = entity.entity_id.split('_meterget')[0].split('.')[1];
return states['switch.' + id].attributes.icon;
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: entity
haptic: light
styles:
card:
- color: var(--text-color-on)
- background-color: var(--background-color-on)
icon:
the function capitalizeFirstLetter() isnt yet used. However, if I do use it, as I do in numerous other spots, the full button disappearsā¦
return capitalizeFirstLetter(id);
whatās wrong here? thanks for having a look!
verify your entity_id is being supplied to the function. Nothings wrong with the function. The only thing that could be wrong is that you arenāt supplying an entity
yeah, but it must be? otherwise the current name wouldnāt exist would it.this is the card config:
- type: horizontal-stack
cards:
template: button_meterget
entity: script.netwerk_auditorium_meterget_power
entity: script.netwerk_auditorium_meterget_usage
entity: script.netwerk_auditorium_meterget_state
and a script is like:
netwerk_auditorium_meterget_state:
alias: Netwerk Auditorium State
sequence:
service: shell_command.netwerk_auditorium_meterget_state
netwerk_auditorium_meterget_usage:
alias: Netwerk Auditorium Usage
sequence:
service: shell_command.netwerk_auditorium_meterget_usage
netwerk_auditorium_meterget_power:
alias: Netwerk Auditorium Power
sequence:
service: shell_command.netwerk_auditorium_meterget_power
yeah, it must beā¦ when I run your function I get output if I change the ID to a string, so the error is beyond that point
var id = "foo";
console.log(capitalizeFirstLetter(id));
You can even modify your code to log the entity and look at the errrors:
console.log(id);
yeah, how odd, even without the capitalize function, I see this:
ButtonCardJSTemplateError: TypeError: Cannot read property 'entity_id' of undefined in 'var id = entity.entity_id.split('_').slice(-1);
console.log(id);
return id;'
though the buttons show fine, and work Only I cant see working is the capitalize function.
also the console shows:
Okay, thereās your problem. Itās an array not a string.
var id = entity.entity_id.split('_').slice(-1)[0];
console.log(id);
so, thatās remarkable isnt it? How can that be an array, and not a string? also how come it says the entity is undefined, while it most certainly is:
update
2 things solved:
- the entity undefined: well that was a simple typo. so correct error
- Capitalize is solved by using
var id = entity.entity_id.split('_').pop(-1);
console.log(id);
pop() instead of slice()
slice returns an array.
yeah, see my post above. thanks for your analysis.
have another quest now that all is solved: trying to write a decluttering template:
card:
type: horizontal-stack #<-- no dash in front of the type: here!!
cards:
triggers_update: switch.[[id]]
entity: script.[[id]]_meterget_power
entity: script.[[id]]_meterget_usage
entity: script.[[id]]_meterget_state
so I can use a simple:
- type: custom:decluttering-card
template: meterget
variables:
- id: kast_library
for all of my 25 switches, instead of having to copy all of this:
cards:
triggers_update: switch.kast_library
entity: script.kast_library_meterget_power
entity: script.kast_library_meterget_usage
entity: script.kast_library_meterget_state
somehow Iāve mixed things up, but I cant bend my head around itā¦ it errors out with
have a suggestion on this? Checking the red cards reveals the exact same code as the yaml sectionā¦?
Sorted! had a ā-ā in front of the card type from a previous edit, marked it in the code aboveā¦
made life just a bit easier for now using below code for decluttering card:
cards:
triggers_update:
- switch.[[id]]
- sensor.[[id]]_actueel
variables:
sensor: sensor.[[id]]_actueel
unit: ' W'
variables:
sensor: sensor.[[id]]_totaal
unit: ' kW'
variables:
sensor: sensor.[[id]]_state
unit: ''
Simply hardcoding the name here is waay less error prone than the js function;-)
only using small configs like these for all my switches now in the card config:
template: force_switches
variables:
- id: netwerk_dorm
- on-icon: wifi
- off-icon: wifi-off
thanks for the amazing button-card and decluttering-card, using templates and variables!
