Hey, is there a way to customize the background and the icon? For example, could I make the background white and the icon red? I can only seem to manage one or the other.
Hey I am looking to build something similar for my blinds, can you please share that config? I am not sure how you included those buttons and how they trigger the blinds.
I think
styles:
card:
- background-color: white
icon:
- color: red
should work
We already discussed this here I think with a proposed solution.
I donāt think I can implement this in the card itself, it would work for white, but then, what if the user has a blue background and the light is blue?
I need some help here.
I made a button to have a popup.
If i leave the entity out of the code, the popup (mod-browser) comes up and works
However i want to change the icon used, based on the state of the entity.
Thathwhy i added the entity, but when i do that, the popup doesnt work anymore.
type: custom:button-card
entity: alarm_control_panel.risco
state:
- value: "disarmed"
icon: mdi:shield-off
- value: "armed_away"
icon: mdi:shield-check
styles:
icon:
- color: var(--primary-color)
- value: "armed_home"
icon: mdi:shield-half-full
styles:
icon:
style: |
ha-card {
height: 128px;
text-align: center;
tap_action: !include popup/alarm.yaml
I donāt think it is related.
What does your popup code look like?
Also, does this code it work on another cardās tap action?
This one for example works with the popup
- name: Verlichting
icon: mdi:lightbulb-outline
tap_action: !include popup/verlichting.yaml
style: |
ha-card {
height: 128px;
But as soon as i put in an entity there, the popup doesnt work
Heres the popup
action: call-service
service: browser_mod.popup
service_data:
title: Alarm
hide_header: true
deviceID: this
style:
:host .content {
width: calc(400px);
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
background: none !important;
card:
type: alarm-panel
states:
- arm_home
- arm_away
ok i found it
if i change code like this , it the popup works
state:
- value: "disarmed"
styles:
icon:
styles:
icon:
style: |
ha-card {
height: 128px;
text-align: center;
It seems the order where i put the tap_action is important
Thank you, RomRider. This is what I thought. Iāll try Petroās suggestion. I couldnāt find that particular post you linked to.
I understand that there will always be some ambiguity (and summarising for myself and others): For a blue light on a blue background, youāll either have the true colour which wonāt be visible, or another colour that doesnāt reflect the true light colour just to make it visible on the card. I suppose even the built-in behaviour has the latter problem (choosing hues of yellow for both yellow and white hues).
The exact code to add to your card to have the result you expect is the one in this post: (it was the one linked in my previous post)
Thanks again - and now I see the ambiguity in what I said (ironically): The link worked fine! I meant that I posted the question since I couldnāt find anything on the topic. I appreciate all the feedback.
I want to use the button card for selecting games to start on my PS4. I tried it with lovelace picture cards but they donāt scale and fit like the button card does. Now iām wondering is there a way to move or scale the image which is used as background-image? so i can fit the image on the button card.
Here is my code and a picture of the card.
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: 'custom:button-card'
aspect_ratio: 1/1
styles:
card:
- background-size: cover
- background-image: url("/local/images/Far_Cry_5.jpg")
aspect_ratio: 1/1
styles:
card:
- background-image: url("/local/images/Fortnite.jpg")
aspect_ratio: 1/1
styles:
card:
- background-image: url("/local/images/FS19.jpg")
Try to add too:
background-repeat: no-repeat;
background-position: center;
background-size: auto;
Maybe better set the size:
background-size: Xpx Xpx;
Works like a charm. Thank you!
Hi @PodPerson - would you mind sharing your YAML code for one of the tiles, maybe for Lounge? Thank you!
Iām sorry, I donāt use those anymore tiles as it was pretty slow to load and I havenāt kept a copy of it. Iāve gone through a few designs since then. It was bascally a lot of nested button cards and stack-in-card. Something like this:
- vertical-stack-in-card
- horizontal-stack
- light
- vertical-stack
- lux sensor
- fake button for spacing
-vertical-stack
- horizontal-stack
- motion sensor
- Light mode
- horizontal-stack
- door
- garage door
- horizontal-stack
- window 1
- window 2
Good morning,
Iām using Button Card for some stuff but now Iām stuck in the color_type: card
& color: auto
feature:
in particular i have an rgb light entity with a custom image (entity_picture
) as icon (just a custom black icon) and I like to have it change in color with the text to be readable when card color change by color: auto
, but I canāt figure how to do this.
I know that is not a standard icon so the color: auto
function doesnāt work, but there is a trick to make the entity_picture
change with card color by changing the picture (I can make a black one, a white one and a grey one for example)?
That is not possible (technically it is possible with filters to change black into something else but not be predictive and obtain the light color)
If your image was a SVG, then you could do something.
Well, if I have the possibility to convert it to svg how can I do the color change?
BTW, is no possible to change the image ex. from A.png to B.png based on the RGB Light color (that colorize the card)?
For SVG, you can use the solution from this post.
If you want to change the picture based on the color, you can use javascript templates to return the appropriate image path.
