Lovelace: Button card
Is it possible to pop-up confirmation only for specific event (ie double tap)
Hi, i think itā€™s a easy question but i can find the solution.
afbeelding
This button card is for a script i will that the icon always have the color green.
how can i fix that? thanks for helping!
type: ā€˜custom:button-cardā€™
entity: script.blauw
color_type: icon
color: ā€˜rgb(14, 53, 247)ā€™
icon: ā€˜mdi:lightbulb-on-outlineā€™
tap_action:
action: toggle
Is it possible to use attributes with a - in the name in a template
label: >
               if (entity === undefined) return "?"  ;
               if (entity.attributes.days-until !=  undefined) return entity.attributes.days-until  ;
                          else  return "?"
Get the followingin error: ButtonCardJSTemplateError: ReferenceError: until is not defined in ā€˜return entity.attributes.days-until if (entity === undefined) return ā€œ?ā€ ; ā€¦ā€™
Itā€™s because itā€™s interpreting it as a math expression, like x - y.
Try entity.attributes["days-until"].
Many thanks, works perfectly now
Is there a way to style all cards on the page at once?
Right now I have 7 cards on the page organized with use of grid card. And Iā€™m in the progrerss of backporting styles from homekit card (because of lack of some features which are found in custom:button card)
But everytime I need to change some detail, I have to go through all seven cars to update them.
Is there a way?
Also I found using grid not perfect, because for some reason it doesnā€™t apply right padding/margin, so cards are sticked to right frame of mobile phone. In this case homekid card works better not trying to fill size for any cost.
Is there more efficient alternative how to keep 3 columns of cards without need of defining sizes, margins, paddings for every button? Or achive behaviour of HK cards in this regard?
Thanks in advance
with regards
You need to change some settings for swiper card to work properly on mobile, this works for me:
  - type: custom:swipe-card
    parameters:
      simulateTouch: true
      followFinger: true
      preventInteractionOnTransition: true
      shortSwipes: true
      preventClicks: true
      preventClicksPropagation: true
      touchStartPreventDefault: false
      mousewheel: true
Yes, itā€™s possible, each action can have its own confirmation object: button-card/README.md at master Ā· custom-cards/button-card Ā· GitHub
You have to set the color directly on the icon:
styles:
  icon:
    - color: green
Yes, you can use configuration templates for that. Check the documentation
I donā€™t understand, please share your code and show us a screenshot.
Yes, sure, if the entity defined in the button-card config is the one which has the entity picture you want to use.
Hello, I REALLY want to use this card, but for the life of me cannot figure out how to get past the ā€œelement does not existā€ error. I have the resource in lovelace, I think I am missing a step between putting it in resources and doing the dashboard. Am I supposed to copy a file into www? I am new to AH so any help or if someone could point me towards a more detailed tutorial so I can use this card it would be very appreciated, thank you!
The docs are fine. You need to tell us what your config looks like and which steps you performed (as well as how).
Unfortunately it doesnā€™t works for me. Are you on iOS?
Anyway, thanks for the hint, Iā€™ll make a try with some other parameter.
:tada::tada: Version 3.4.1 :tada::tada:
Bug fixes
  • Clicks on embedded cards were triggering the action of button-card (Fix #410) (Sorry :pray:)
Other
  • Remove the ellipsis class from embedded cards (cc: @petro)
Thank you for responding.
Below is a copy paste of the steps taken and the coding for the lovelace card. I had asked on a new topic but no responses. Iā€™m sure the step I missed was configuration file, I havenā€™t edited that.
Thank you in advance, I am super new to HA.
I have been all over the forums and google looking for a how to.
I am having trouble adding custom cards.
Specifically Paper Buttons found here: https://github.com/jcwillox/lovelace-paper-buttons-row
Installation instructions when you find a custom resource are always like this from what I have found with trying to do this, so I KNOW I am missing something.
resources:
  • url: /hacsfiles/lovelace-paper-buttons-row/paper-buttons-row.js
    type: module
I have Advanced active.
I have added the resource into the resources tab in Lovelace, but I think I am missing a step. I am lost from there. I was expecting it to pop up as a button like the other ones, but that didnā€™t happen. So I went down a rabbit hole and figured out how to type what I am wanting out, but then I get the error: Custom element does not exist.
I am missing a step or twoā€¦ anyone know what it is? I feel like I was supposed to place a file somewhere or am supposed to be putting the code somewhere else, like config. I created the www folder in config but have no clue what to put inside it or how to get the file to put there.
type: entities
entities:
  - type: "custom:paper-buttons-row"
    buttons:
      - light.backdoor
      - entity: light.01110061bcddc23b644c
        icon: "hass:lightbulb"
Thank you!
paper-button-row is unrelated to button-card. However, Iā€™d suggest that you use HACS to install your custom cards. This will make things easier.
Oh snap, I think I mixed up what I was working on, that may be where I went wrong. Thank you for the link! That makes life so much easier!
I have two different lovelace dashboards (admin and user) that use two common views (main and tree).
With a custom button-card in the main view I want to navigate in the tree view but itā€™s not possible since the path to the view is relative to each dashboard: in admin dashboard the path is /lovelace-admin/tree and in the user dashboard the path is /lovelace-user/tree.
How can I have an ā€œabsoluteā€ navigation_path in the main view just to link the tree view indipendently from the lovelace dashboard?
SOLVED: Just for someone interested. The navigation_path can point to the path variable of the view
configuration without the dashboard root, for example in my case
navigation_path: tree
Hi guys iā€™ve created a simple button within a vertical stack which turns the icon yellow when turned on.
type: vertical-stack
cards:
  - type: 'custom:button-card'
    entity: light.fish_tank_light
    icon: 'mdi:lightbulb'
    color: auto
    color_type: icon
    default_color: 'rgb(255, 140, 0)'
    tap_action:
      action: toggle
    hold_action:
      action: more-info
But i want to resize it and add other styles etc, so when i add some style code to it it resizes it but the icon stops turning yellow
cards:
    color: auto
    color_type: icon
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    styles:
      card:
        - font-size: 13px
        - filter: opacity(50%)
        - filter: grayscale(100%)
        - border-radius: 15%
        - text-shadow: 0px 0px 5px black
        - height: 210px
        - width: 210px
I tried putting the colour options within the style but i canā€™t figure it out.
Thanks for any advise
grayscale on the card will render the whole card in grayscale, including the icon (since the icon is a child of the card)
Thanks that worked great.
I thought Iā€™d try that one but I mustnā€™t have done.
Thanks again
You truly are my hero, this got me on the right path. Thank you so much!
Hi back again thanks for the help yesterday @RomRider
Iā€™m hoping you might know where iā€™m going wrong with this, Iā€™m wanting to create a small presence button with custom home and away avatars.
I have the code below working fine in a picture entity but iā€™m wanting it within a custom button so i can resize it etc.
type: picture-entity
entity: person.steve_2
state_image:
  not_home: /local/images/steve_away.png
  home: /local/images/steve.png
So iā€™ve been trying various cards to add it with but not sure where iā€™m going wrong as the images donā€™t show up but the size is what iā€™m wanting ,i have this in a horizontal stack at the moment.
type: horizontal-stack
cards:
    show_state: false
    state_image:
    tap_action:
      action: toggle
    styles:
      card:
        - font-size: 15px
        - text-shadow: 0px 0px 15px black
        - height: 200px
        - width: 200px
