johntdyer
(John Dyer)
March 4, 2021, 1:35pm
5255
@Mariusthvdb
the error is
Button-card template 'button_default_title' is missing!
type: 'custom:button-card'
name: Home Assistant version info
template: button_default_title
and
Button-card template 'button_updater' is missing!
template: button_updater
entity: binary_sensor.ha_update_available
name: Update available
so I think I’m just missing the template for button_updater
and button_default_title
Thanks for your help
button_default_title:
aspect_ratio: 12/1
styles:
card:
- background-color: var(--background-color-off)
- color: var(--text-color-off)
- font-size: 20px
- font-weight: bold
and
button_updater:
template: button_body
state:
- value: 'on'
styles:
icon:
- color: green
- animation: blink 2s ease infinite
state:
- color: green
- operator: default
styles:
icon:
- color: grey
state:
- color: grey
clemalex
(Clemalex)
March 4, 2021, 3:29pm
5257
Display of a timer directly on the card (another way ? tell me how ):
(we can imagine a change in speaker color, name, etc. depending on the state of the timer)
Code
var finishes_at = new Date(states['timer.hacf_timer'].attributes.finishes_at);
var remaining = states['timer.hacf_timer'].attributes.remaining;
if (finishes_at == 'Invalid Date') {
if (remaining) {
var remaining_first_element = remaining.split(':');
if (remaining_first_element[0].length < 2 ) {
if (remaining_first_element[0] == '0' ) {
remaining_first_element = remaining_first_element.splice(1);
} else {
remaining_first_element[0] = '0' + remaining_first_element[0];
result = remaining_first_element.toString().replaceAll(',',':');
} else {
result = 'Sonorisation';
} else {
var timestamp = finishes_at.getTime();
var timestamp_now = Date.now();
var difference_between = timestamp - timestamp_now
var time_remaining = new Date(difference_between).toUTCString();
var hours = time_remaining.split(' ');
var hours_split = hours[4].split(':');
if (parseInt(hours_split[0]) == 0 ) {
hours_split = hours_split.splice(1);
var result = hours_split.toString().replaceAll(',',':');;
return result;
triggers_update:
- sensor.aleatoire
show_name: true
icon: 'mdi:speaker'
styles:
custom_fields:
wave:
- background-color: 'rgba(0, 0, 0, 0)'
- position: absolute
- right: 5%
- top: 5%
- font-size: 13px
- line-height: 20px
- display: |
if (states["input_boolean.test2"].state == 'on') return '';
else return 'none';
- '--icon-color': |
if (states["input_boolean.test2"].state == 'on') return 'var(--mail-color)';
else return 'var(--primary-color)';
card:
- border: 2px solid var(--primary-color)
- border-radius: 10px
icon:
- color: var(--primary-color)
name:
- font-variant: small-caps
custom_fields:
wave: |
return `
<div class="loader-container">
<div class="loader-3">
<div class="item-1"></div>
<div class="item-2"></div>
<div class="item-3"></div>
<div class="item-4"></div>
<div class="item-5"></div>
</div>
</div>`
style: |
.loader-3{
width: 40px;
height: 40px;
.loader-3 div {
height: 100%;
width: 3px;
display: inline-block;
.loader-3 div .item-1{
height: 50%;
.loader-3 .item-1 {
animation: loader-3-first-last-div 1.2s infinite linear;
background-color: red;
.loader-3 .item-2 {
animation: loader-3-middle-div 1.2s infinite linear;
animation-delay: -1.1s;
background-color: darkorange;
.loader-3 .item-3 {
animation-delay: -1.0s;
background-color: gold;
.loader-3 .item-4 {
animation-delay: -0.9s;
background-color: green;
.loader-3 .item-5 {
animation-delay: -0.8s;
background-color: DarkOrchid;
@keyframes loader-3-first-last-div {
25%,75% {
transform: scaleY(0.2);
0%,50%,100%{
transform: scaleY(0.6);
@keyframes loader-3-middle-div {
25%,75% {
transform: scaleY(0.4);
0%,50%,100%{
transform: scaleY(1);
A timer entity must be used:
- platform: random
maximum: 999
We must add a random entity (which serves as a trigger to update the button-card):
- platform: random
maximum: 999
You need an automation that runs every second to update this entity:
Automation to update entity
alias: mise a jour de sensor.aleatoire
description: Mise à jour pour affichage des timers sur les cartes
- platform: time_pattern
seconds: '*'
condition: []
- service: homeassistant.update_entity
entity_id: sensor.aleatoire
mode: restart
En français dans le texte
Edit: without random entity and automation but update directly in button-card with javascript (thanks @RomRider ) :
type: custom:button-card
variables:
update: |
if (condition to trigger update each x) {
if (this._myTimer === undefined) {
this._myTimer = window.setInterval(() => { this.update() }, 1000 * 10) // 1000 * 10 = Time between update in milliseconds
} else {
if (this._myTimer !== undefined) {
window.clearInterval(this._myTimer);
delete this._myTimer;
xxx: rest of code...
RichardU
(Richard)
March 5, 2021, 4:33am
5258
@sd_dracula Can you post the code you came up with? This is exactly what I’m trying to do.
Cheers, Richard
Here you go
color: auto
color_type: card
entity: vacuum.robovac
hold_action:
action: more-info
icon: 'mdi:robot-vacuum'
show_label: true
state:
- color: white
styles:
card:
- color: 'rgb(255, 0, 0)'
value: 'on'
- color: 'rgb(255, 255, 255)'
value: 'off'
styles:
grid:
- grid-template-areas: '"t" "i" "n"'
- grid-template-rows: min-content 1fr min-content
- grid-template-columns: 1fr
card:
- height: 95px
- width: 95px
label:
- font-size: 14px
name:
- font-size: 14px
custom_fields:
t:
card:
entity: timer.robovac_timer
margin: none
show_name: false
show_icon: false
show_state: true
styles:
card:
- box-shadow: none
- font-size: 12px
state:
- color: |
if (states['timer.robovac_timer'].state == 'idle')
return "white";
else
return "red";
gabrymed
(Gabriele)
March 5, 2021, 10:29am
5260
Hi all,
i made a card with custom:button-card with my temperature sensors like this:
Is it possible to make a custom:button-card that change background color like mini-graph card with color thresholds concept? Like this:
but working with background button card color?
Thanks in advance
Yes, everything is possible if you develop some code to do it but color threshold is not a simple javascript code.
This is how I build the color of the header in apexcharts-card based on a color_threshold list: https://github.com/RomRider/apexcharts-card/blob/68b1097cbd601b9c20cc6fc28146fe28a29b3d2e/src/apexcharts-card.ts#L986-L1008
gabrymed
(Gabriele)
March 5, 2021, 10:46am
5262
Thanks, i’ll take a look at this Jcode.
RichardU
(Richard)
March 5, 2021, 3:04pm
5263
The only way I’ve been able to make this work is with triggers_update: all
Is there any benefit to frontend workload to try to specify triggers_update for my variable?
button_card_templates:
timer:
variables:
timer_var: "placeholder"
custom_fields:
desc:
card:
entity: '[[[ return variables.timer_var ]]]'
styles:
state:
- color: >
if (states[ variables.timer_var ].state == 'idle')
return "white";
else
return "red";
RichardU
(Richard)
March 5, 2021, 4:21pm
5264
TYPOs or NOT?
I found a very small typo on the github page, so I was thinking of posting a PR (just to prove my English professors wrong). Then I found a couple of other things I could improve in my estimation, but maybe not yours
First, the word “overload” is used four times in a context that I would normally consider to mean “override”, as in to replace an existing setting with a new one.
Should I suggest changing overload to override?
Second, the variables section includes this example:
variable_test:
variables:
var_name: "var_value"
var_name2: "var_value2"
name: '[[[ return variables.var_name ]]]'
That threw me for a minute since the example values look like some kind of entity.
Should I suggest changing the example to this:
variable_test:
variables:
var_name: "Example"
var_name2: "Example 2"
etc. changing the rest of the example as appropriate
Cheers, Richard
clemalex
(Clemalex)
March 7, 2021, 9:58pm
5266
Perfect in picture-elements card :
code
entity: input_boolean.wakestatus_1
show_icon: false
show_state: false
styles:
toogle:
- transform: translateX(26px)
card:
- width: 60px
- height: 40px
- background: transparent
- box-shadow: none
custom_fields:
toogle: |
return `
<div class="switch">
<span class="toggle-thumb">
<svg xmlns="http://www.w3.org/2000/svg" width="36" height="36" viewBox="0 0 24 24" style="fill:#4ADE80;transform:;-ms-filter:"><path d="M10 15.586L6.707 12.293 5.293 13.707 10 18.414 19.707 8.707 18.293 7.293z"></path></svg>
<svg xmlns="http://www.w3.org/2000/svg" width="36" height="36" viewBox="0 0 24 24" style="fill:#F87171;transform:;-ms-filter:"><path d="M16.192 6.344L11.949 10.586 7.707 6.344 6.293 7.758 10.535 12 6.293 16.242 7.707 17.656 11.949 13.414 16.192 17.656 17.606 16.242 13.364 12 17.606 7.758z"></path></svg>
</span>
</div>`
style: |
#toogle .switch {
width: 60px;
height: 34px;
position: relative;
.toggle-thumb {
position: absolute;
top: 0;
left: 0;
right: 0;
bottom: 0;
display: flex;
justify-content: space-between;
align-items: center;
background-color: #3f3F3f;
border-radius: 40px;
cursor: pointer;
.toggle-thumb:before {
content: "";
height: 26px;
width: 26px;
position: absolute;
left: 4px;
bottom: 4px;
border-radius: 50%;
background-color: #EFEFEF;
transition: .4s all ease;
.checkbox {
opacity: 0;
width: 0;
height: 0;
z-index: 100;
{% if is_state('input_boolean.wakestatus_1', 'on') %}
transform: translateX(26px);
{% endif %}
Source
another silly question, but ive simply never run into it yet… Need a button with default tap_action on a cover (group) and a hold_action to navigate. The tap action must be guarded (with the confirmation). The navigate should be without confirmation.
I tried it like this, but now it confirms both the tap_action And the hold action.
template:
- button_summary
- styles_summary_alert
entity: cover.bedrooms
confirmation:
text: >
[[[ return `Are you sure you want to toggle ${entity.attributes.friendly_name}?` ]]]
hold_action:
action: navigate
navigation_path: /lovelace/covers
You need to put confirmation
under the action , not in root of the card.
tap_action:
action: toggle
confirmation:
text: >
Leave it out under hold_action
so that skips the confirmation.
Yah, I hoped I could use the default tap action, but I guess using a confirmation on that makes it non default
Another thing I see is, when the tap action is executed, I get a pop up window with extra controls (which of course is the more-info popup of the cover entity in the card) instead of a direct toggle action on that entity… Is that expected?
That shouldn’t happen, since toggle and more-info are 2 different actions. When I toggle my curtains, it just toggles it, no popup. I use hold_action for popups. I have defined tap_action and hold_action. Perhaps it’s buggy when you don’t define them and want to use default?
guess it was my error of the tap_action. using
template:
- button_summary
tap_action:
action: toggle
confirmation:
text: >
[[[ return `Are you sure you want to toggle all covers?` ]]]
hold_action:
action: navigate
navigation_path: >
[[[ return (window.location.pathname.split('/')[2] == 'covers')
? null : '/lovelace/covers'; ]]]
now makes it all happen. thanks!
great this is! thanks for sharing.
Ive adapted my own alarm button with this, and it is almost like your example.
Skip that about the border, I missed the else…
Now I only need to figure out how to get the pulsating circle be more visible on my smaller button…
edit:
this will do for now
clemalex
(Clemalex)
March 8, 2021, 11:56am
5273
These css properties (color / opacity in percent)
.shadow_blue {
box-shadow: rgb(0 104 255 / 20%) 0px 0px 0px 0px, rgb(0 104 255 / 20%) 0px 0px 0px 800px inset;
} .shadow_red {
box-shadow: rgb(255 0 0 / 20%) 0px 0px 0px 0px, rgb(255 0 0 / 20%) 0px 0px 0px 800px inset;
yes, thanks, I will experiment there. Had a dark background that was in the way of the pulsating circle also, so I changed that already.
Its very nice to be able to do all these eyecatching stylings, so please dont hold back if you have more great examples
